Hoover 550M. Machine doesn't do anything when turned on. Power
Hoover 550. Machine doesn't do anything when turned on. Power point has been checked out as OK. Machine just sits there doing nothing no matter what program is tried.
  • Ronwyn Mar 04, 2009
    Plug & fuse are OK Is there an overload button on the motor?
  • fixer444 May 11, 2010
    Check plug, fuse in plug.
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
My hoover will not fill with water when the start button is pushed and three lights come on H G D and all three flash all the time .Can you help
It could be that the water pump is jammed with a coin or maybe a kirby grip or something of that nature , pull your machine out and switch off the power , then tilt the machine up at the rear and check to see if the pump is turning by hand , if it is not turning properly it could be hat coin or some other object is jammed in it , you will need to take the rear cover off the pump and check to see if there is anything in it , if you find anything in it this will probably be the problem , put the pump back together and try the machine to see if it fills , good luck , also if your machine is under 5 years old Hoover will replace any parts as you have a 5 year guarantee on parts
Aug 22, 2014 | Hoover Washing Machines
How do I fix a hoover 550m washing machine not is not pumping water to drain out and empty the wash bowl. Everything else works fine
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 20, 2011 | Hoover HTC243 Top Load Washer
Hoover 550M washing machine - taking ages to fill, water is just dribbling out. Was fine when started, lifted lid to put in clothes and now only dribbling out. Water pressure in rest of house seems to be...
Check the inlet screen on the hose connection on the back of the machine. This may be clogged with debris, also make sure you hose is not crimped. You can unhook the inlet hose and put it in a bucket and turn it on to see how much water is actuall coming thru that hose. I suspect some type of blockage in the inlet.
Nov 11, 2010 | Hoover HTC243 Top Load Washer
Cannot get agitator off shaft Hoover 550M washing machine
Had to cut agitator away leaving metal boss exposed will now use a puller to pull off drive shaft
Dec 22, 2009 | Washing Machines
I have a Hoover 550 MB Top Loader washing machine . The cycle won't move from wash to spin . it doesn;t progress out of wash cycle , it stays there forever .
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Oct 19, 2009 | Hoover HTC243 Top Load Washer
Hoover Washing Machine 550M. Cycle incomplete, clothes still wet with soap powder.
this sounds like the motor bushes have worn,check them,they are easy to replace for about £10.00
Jul 14, 2009 | Kenmore 44102 Front Load Washer
My Hoover 550 wil not stop filling with water
Possibly caused by a leaking water level sensor. Turn off the power, remove 3 screws at top back of control panel. Rotate the control panel forward and have a look at the white rubber hose on the left hand side. Check that it is connected at both ends and not perished. Also check that the adjuster cam (turn the level knob and look behind) is not broken.
May 01, 2008 | Hoover Washing Machines
Hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
May 04, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
210 people viewed this question
Top Washing Machines Experts
