Question about Yamaha RX-V800 Receiver
I have an old but "pretty" Yamaha CR-620 receiver that died abruptly 10 years ago. I dug it out the other day and have removed the outer shell. I've got power light, signal strength on meter but no sound. Others with similar symptoms have been steered to examine protection circuit and saying that speaker relay not closing? Should I be checking power output transistors as the next step? I'm pretty much a rookie though I used to built heathkits so I do have some equipment. Thanks Bob in Golden Valley
  • David Dunn
    David Dunn May 11, 2010
    You would hear the relay click after a short delay once power was applied. No click, no speakers. Protection means heat, shorts or opens.
    I'd recommend getting a better high level feel for what is and isn't working before doing surgery. I have fixed things til they were broke in my time.
    Try using the FM tuner as a signal source. Make sure it has something to send to the speakers. If you have an external device that takes Line Level like a tape deck you can trace the presence of a program within the receiver by using its record meters.
    Don't let the old Tape Monitor fool you, either.
techman
  • 3130 Answers
SOURCE: Double clicking sound- no power
The relay contacts are most likely bad in the relay and will most likely happen again. If you know how to solder, take out the relay and look up the numbers on the internet and see what you can find. If not, try to find where the manufactuer is located and call them to see where you can get a new relay. Good Luck
Posted on Mar 28, 2007
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
Posted on Jul 30, 2007
  • 4234 Answers
SOURCE: Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
Posted on May 12, 2008
SOURCE: my yamaha htr 6050
Make sure your audio output on your PS3 is configured properly. You have the ability to chose which port the audio is coming out of.
The 6050 does NOT process audio signals coming in on the HDMI port. The amp is weak, I had one. With the 6050 you will have to use the AV multi coming out of the PS3 and use the special cable that came with the PS3 to convert that signal to the RCA and connect that to the 6050.
Posted on Jul 27, 2008
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX V 657 - No Sound Output, and No input detection
Bad DSP chip. The only other possibility is if you have the "Direct" on. On the front of the receiver it's a small button. Also make sure your "Speaker Select" A/B is "on" You will see it on the display, it's also a small button on the front of the receiver. If all this is correct and you still have no audio, it's a bad DSP chip. Not worth repair, it's 400-500 repair. Not very common in a Yamaha RX-V series, but I have seen it. I'm a Yamaha Dealer. If you need further help, post a comment and I will be glad to help you further.
Posted on Aug 23, 2009
Free mechanical advice online
it sounds like your mechanic didn't put the splash guard on, properly. You'll need to buy a set of splash guard clips. https://www.hondapartsnow.com/parts-list/2003-honda-cr-v-5dr_lx_2wd_side_srs-ka-4at/front-fender.html
You can take the splash guard off by removing the clips that were installed. You will need a 10 mm socket to remove the clips. They are two parts - an inner plastic bolt, and an outer anchor. Your car will run and perform pretty well without the guard- it's just there for aerodynamics. I hope that helps.
Apr 29, 2017 | 2003 Honda CR-V
I have a 70's era Yamaha Natural Sound Stereo Receiver CR-620. It just recently stopped working. It turns on, but doesn't transit sound. Can it be fixed or is it terminal?
If there is no audible physical click from the speaker output relay, after about 10 to 20 seconds, there is an electronic fault in one or both amplifier circuits, which will require repair. If you like the sound of this unit enough to pay maybe $50 give or take, get it repaired. Otherwise, you can pick a similar unit up at a thrift shop for a few dollars.
Aug 29, 2010 | Yamaha Audio Players & Recorders
I have a 7 year old toro timecutter zero turning radius 16/42" mower. It starts and mows fine but after about 10 minutes of mowing it loses power and dies abruptly. After sitting for 10 or more minutes it...
could be a ignition unit (s)breaking down when it getts hot ?
could be a tank breather not working or a restriction in flow of fuel
could be a valve not opening fully or closing fully ie tight valve
fit in line ignition tester and run unit and see if spark disapears when unit gets hot if so ignition prob if not its other problems
worth a look
cheers
Jun 30, 2010 | Garden
Microwave suddenly died in the middle of cooking
The only 2 user replacable parts in a microwave are the lightbulb,
and the 20 amp ceramic fuse. if you have checked the power cord outlet it's pluged into and both are fine. It's possabbe the fuse behind the controls is bad. Theese fuses look the old car fuses only
not made of glass they use white ceramic. A philips screwdriver will normally remove the outer shell of the microwave make shure it's not plugged in! After removing the outer shell look behind the controls on one of the power lines there will be a snap in fuse the above mentioned removal is easy it will pop right out replacment is oppsite of removal. If the fuse is bad replacing it cost about $3
warning don't mess with any thing else if you do this!!! microwaves contain radioactive meteral If you don't think you can do it safely take it to a pro or buy a new one
Hope This Helps gota lot of good years out of microwaves by changing those fuses. Most people just throw them away microwaves that is
If this helps ya
please leave feedback
Nov 19, 2009 | Dryers
Rx v2095 receiver - No sound from either front main speaker
I have had similar problems on a Denon. I suspect your DSP needs repaired and/or replaced. Need to contact authorized Yamaha repair shop or a competent local repair facility. I have a Yamaha RX-V2092 which is similarly designed. I have had it for 10 years. Hope this helps.
Nov 29, 2008 | Yamaha RX-V596 Receiver
It keeps goin to protectin mode
Well I have an Onyyo TS SV515 Pro II receiver that is quite a few years old. I have lived in several houses and have moved it with me. For as long as I can remember it has been going into 'protect mode' when I turned it over 6 on the volume knob. I have a subwoofer and 4 infinite speakers and a yamaha center channel speaker.
I got on the internet the today to see if I could figure out why it did this. One person suggested cutting my speaker wires and resplicing it making sure no hanging wires where there.
I had been using the same speaker wire since I puchased it (10 yrs ago). I feel pretty stupid, cause I just did the wires to my front 2 Infinite speakers and WaLa...It works flawlessly. I can now turn up my receiver...after 10 years of dealing with no 'full' volume.
*****Check those speaker connection, they are the key*****
Sep 18, 2008 | Audio Players & Recorders
Washer GLTF2070DS0
warranty varies by manufacturer some stainless steel baskets had 10 yr warranty but suspect you may need more than just basket outer shell has a bearing in rear that is pressed in only repair is replace rear shell and basket.. 2 men 2 hrs plus outer shell price and labor.. only 1 yr labor and other parts
Jun 21, 2008 | Frigidaire ATF6000ES Front Load Washer
RX-V1500- front panel lights not working
The display on an amp has two components.
A small Lamp (light bulb)
A LCD display with a color filter.
Normally when the display goes out the problem is with the lamp
The lamp on my RXV 870 died after about 9 years of use.
I called Yamaha and was able to by a replacement.
The lamp is an odd voltage 14.5 if I recall.
Looking at the receipt i should have bought 3 for the cost of shipping. It cost about 10.00 cnd,
Apr 02, 2007 | Yamaha RX-V1500 Receiver
Yamaha RX-V800 Receiver Logo
76 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
