Question about Toshiba Televison & Video
Transistor d2553 blown and replacement transistors blowing. TV not coming on.
maatmartin7
  • 1213 Answers
SOURCE: power supply transistor transistor no. C4237 replaced 4 times. each replacement didnot sustain for a week. which transistor can i use instead.
I have worked to repair a few of these. When the transistor is burned, you most likely have a bad flyback transformer and bad picture tube. In this case you replaced this (transistor) component four times. This TV cannot be saved. Thanks for asking.
Posted on Oct 21, 2011
ladywinn
  • 5138 Answers
SOURCE: Replaced Flyback Transformer and Horizontal Output Transistor
I am proud to see you got your set working Good job!
Posted on Aug 26, 2008
  • 4234 Answers
SOURCE: sony color TV model kv-c29 11d blown power supply ic and transist
There should be circuit designations printed on the PC board. Without those, there are too many possibilities to give you anything useful. Can you provide those please?
Thanks,
Dan
Posted on Jan 21, 2009
SOURCE: can I use the transistor d1878 horizontal instead transistor c5148, I have the specifications for c5148, but I can not find the specifications for d 1878,someone can help me?
I have Sony TV, transistor D1878 is damage, can i use the another type for replacemen?
Posted on Apr 01, 2010
  • 18 Answers
SOURCE: Tevion 42
I ha ve Q101 Q102 and D101 in s/c! is this a normal problem?.
Q101 and 02 are the above w20nm60 d101 is a s20lc60us
Posted on Jun 01, 2010
The tv power light comes on but I have no sound or video
your tv might have blown out some resistors so that the horizontal output transistor doesnt recieve any power and most likely the transistor has blown please send me the tv model for more help
Jan 20, 2013 | Televison & Video
Transistor c3807 blown tv
Your TV need a through checkup. There sill be a reason for the blow up to this transistor. Find the reason first, rectify it, and then replace the damaged component. Contact any experienced service technician.
Aug 19, 2012 | Hisense Televison & Video
Mitsubishi tv 50604 worked fine, then it shut off and wont turn on
you have shorted power transistor on power supply
Jun 25, 2012 | Televison & Video
Tv wont turn on?
first you have to open the back cover of the television to check for blown fuses.
A blown fuse is a very common type of fault due to poor design very often triggered by power surges due to outages. However, the most likely parts to short are easily tested, usually in-circuit, with an ohmmeter and then easily removed to confirm.
Note that it *may be* useful to replace a fuse the *first* time it blows (though it would be better to do some basic checks for shorted components first as there is a small chance that having a fuse blow the second time could result in additional damage which would further complicate the troubleshooting process). However, if the new one blows, there is a real problem and the only use in feeding the TV fuses will be to keep the fuse manufacturer in business!
Sometimes, a fuse will just die of old age or be zapped by a power surge that caused no damage to the rest of the TV. However, it must be an EXACT replacement (including slo-blow if that is what was there originally). Else, there could be safety issues (e.g., fire hazard or equipment damage from too large a current rating) or you could be chasing a non-existent problem (e.g., if the new fuse is not slo-blow and is blown by the degauss circuit inrush current but nothing is actually wrong).
If the fuse really blows absolutely instantly with no indication that the circuits are functioning (no high pitched horizontal deflection whine (if your dog hides under the couch whenever the TV is turned on, deflection is probably working).) then this points to a short somewhere quite near the AC power input. The most common places would be:
Degauss Posistor - very likely.
Horizontal output transistor.
Power supply regulator if there is one.
Power supply chopper (switchmode) transistor if there is one.
Diode(s) in main bridge
Main filter capacitor(s).
You should be able to eliminate these one by one.
Test the rectifiers individually or remove and retest the resistance.
If these test good, use an ohmmeter with the set unplugged to measure the horizontal output transistor. Even better to remove it and measure it.
C-E should be high in at least one direction.
B-E may be high or around 50 ohms but should not be near 0.
If any readings are under 5 ohms, the transistor is bad. The parts sources listed at the end of this document will have suitable replacements.
If the HOT tests bad, try powering the set first with your light bulb and if it just flashes once when the capacitor is charging, then put a fuse in and try it. The fuse should not blow with the transistor removed.
Of course, not much else will work either.
If it tests good, power the set without the transistor and see what happens. If the fuse does not blow, then with the good transistor (assuming it is not failing under load), it would mean that there is some problem with the driving circuits possibly or with the feedback from the voltages derived from the horizontal not regulating properly.
Look inside the TV and see if you can locate any other large power transistors in metal (TO3) cans or plastic (TOP3) cases. There may be a separate transistor that does the low voltage regulation or a separate regulator IC. Some TVs have a switchmode power supply that runs off a different transistor than the HOT. There is a chance that one of these may be bad. If it is a simple transistor, the same ohmmeter check should be performed.
If none of this proves fruitful, it may be time to try to locate a schematic.
A blown fuse is a very common type of fault due to poor design very often triggered by power surges due to outages or lightning storms. However, the most likely parts to short are easily tested, usually in-circuit, with an ohmmeter and then easily removed to confirm.
But if otherwise your power supply board is dead, It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps....
Jun 05, 2010 | Zenith R57W46 57" Rear Projection...
Our TV suddenly stopped working and will not come back on
A blown fuse is a very common type of fault due to poor design very often triggered by power surges due to outages.However, the most likely parts to short are easily tested, usually in-circuit, with an ohmmeter and then easily removed to confirm.
But if otherwise your power supply board is died, It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck....
Jun 05, 2010 | iLO 3200 32 in. LCD Television
Mackie 1200/1400 blows all 4 10 amp fuses
missmatched impedance, insufficient ground, blown transistor.
Jul 20, 2009 | Bob Mackie Mackie M-1400i Power Amplifier...
NAD C350
Take a ohm meter and measure resistance from emiter to collector should have a few kilo ohm on output transistor.
If no ohm meter available , remove output transistors from circuit.
note position of transistor . you have a NPN and a PNP for each channel.
Replace fuse and power up. If fuse blows check bridge in the power supply.
80% of the time output transistor burn and blow the fuse.
before replacing output transistors check driver transistors they probably burnt also
Apr 29, 2008 | NAD C350 2-Channel Amplifier
Have sound and no picture
HI I HAVE THE SOUND BUT NO PICTURE BAT WHEN I BEND THE POWER BOARD OR PLAY WITH IT LEFT OR RIGHT THSN I GET THE PICTURE
Oct 02, 2006 | Toshiba 50HX70 50" Rear Projection...
Trouble!!
If you have sound and no picture you either do not have any high voltage, the CRT emitters are not powering up or there is no video drive to the crts. A long shot would be the brightness is turned down but unlikely. The most likely problem is no high voltage. Odds are the Horizontal Output Transistor is open. This is easy to check with a vom if you are familiar with TVs. If not have a professional do it. TVs are dangerous and complicated. If the HOT is open it will need to be replaced along with either/and the flyback and HV divider block. If the Horizontal Output is ok the problem could be just about anywhere. First you need to make sure that all necessary voltages are present and correct. After that you need to determine which circuit or section is not working. At this point the sound is the only thing you know works. Good Luck.
Jun 22, 2006 | Mitsubishi VS-5059 50" Rear Projection...
Have sound but no picture
Do you know if the High Voltage comes on?? Sometimes a vert sweep falure will cause your complant. also a poor solder connection on the horizontal driver xformer is cold connections.. If you understand this then your quilifyed to troubleshoot this set. If you dont PLEASE dont open set as you could not only cause more damage to the set but to yourself as well!
Apr 06, 2006 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
550 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
