Question about Numatic HHR-200 Henry Hound Bagged Canister Vacuum
I have a Henry 200 and the red on/off switch is stuck in the on position can it be fixed
  • Dee Rogan Mar 04, 2009
    thank you for your help please let me know where I can get a replacement switch
    President:
  • 389 Answers
Well... It probably can't be fixed, but it can easily be replaced. Depending where you are, spares are usually readily available. If you need more guidance, please post here again, and I'll see what I can do to help. Good luck!
Posted on Mar 04, 2009
  • Philip Gaut Mar 04, 2009
    Where to get a new switch?  It depends where you are!  If you are within reach of a vac repair shop, they should be able to get one if they haven't got one in stock. Alternatively, you may just want to Google "Numatic Henry Spares" and see what comes up.
Power switch
here is a video that will give you full instructions how to replace switch
Feb 22, 2013 | Numatics Numatic Hhr200-2 Henry "Hound"...
New Henry Numactic Moter - How to wire?!
on the motor there are 2 connection together and one on it's own and on the brushes 1 each ignore these .and on the motor fix to the 2 tab one that you can see a wire connection on and then fix to the other side of the motor .this worked for me
Mar 11, 2010 | Henry Numatic "" Canister Vacuum
My hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
Oct 30, 2009 | Numatic HHR-200 Henry Hound Bagged...
Power head stopped working could it be the switch? could it be the motor? thanks
If its an electric head switch it off and remove the screws underneath or if it has a slide out cartridge check that the brush isn't clogged with dust. Sometimes the toothed belt can come undone if there's an obstruction.
Jun 13, 2009 | Miele S514 Solaris Turbo Plus Vacuum
Electrical Burning Smell from Henry HVR200 Vacuum Cleaner
Hi! Highly unlikely that you need a new motor.  Highly likely that you need new carbon brushes.  The smell is caused by excessive sparking between the worn brushes and the copper commutator segments.  Most carbon brushes (and from memory I suspect this includes Henry's) have a copper wire buried in their last few millimeters, and you really need to change them before that becomes exposed.   The longer you run it like this, the more likely you are to damage the commutator, so change them sooner rather than later.  When you change the brushes, you can smooth off the commutator with very fine abrasive paper (the objective is to smooth it, not scratch it!), and then blow all the dust away (or **** it away if you have another vac, of course).  Incidentally, you don't say if you are using a paper bag in your Henry. Some people, because the top-hat filter is so good, try to manage without a bag.  This is false economy!  You should always use a bag. I hope this helps! I value feedback, so please remember to rate this response.
Feb 28, 2009 | Numatic Henry Bagged Canister Vacuum
Numatic Henry Micro HVR-200
motor is over heating. you need to clean bag, filter and hose first then re test
Aug 21, 2008 | Numatic Henry Bagged Canister Vacuum
Numatic HHR-200 Henry Hound Bagged Canister Vacuum Logo
235 people viewed this question
Top Numatic Vacuums Experts
Chris Nomland
Chris Nomland
Andrew Taylor
Andrew Taylor
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
