Question about Logitech QuickCam Connect Webcam
Quickcam for SKYPE
How to connect Locitech Quickcam for use with SKYPE?
    Novelist:
  • 90 Answers
Hopefully you have not loaded the quickcam software yet. If you have, hopefully you only loaded the drivers for the cam and not the logitech control panel for the camera. If you loaded the control panel, it loads everytime you start your computer and runs minimized in the bottom status bar. When you start Skype, it activates the camera and so does the logitech control panel. Thus you have two programs trying to control the cam at the same time and you have nothing but problems thying to get it to work. You will need to right click on the logitech control icon and exit the program before starting Skype. After you start Skype got to tools, options and set your camera and mic. settings from the drop down menu. You can then go to Skype test call and see if the settings are correct. Skype allows you to turn on the video or off when you make calls to others. This is so they can't see you, but you can see them during the call unless they have theirs turned off also. Good Luck, RAC
Posted on Apr 04, 2009
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Sep 03, 2012 | Acer Aspire 5500 5570-2609 Laptop
Hi, i tried using skype with logitech quickcam but pup-up told me this message: Another application (communications helper.exe) tries to access Skype but we are not able to respond. Try to restart the...
The easiest thing to try is just disabling "Communication_Helper.exe" in Skype. Go to Skype / Tools / Options / Advanced, and at the bottom you will see text that says "manage other programs' access to Skype". Click that and you'll get a window, which should list "Communication_Helper.exe". Deny access to that (don't remove it, because it will just come back), and try your call again.
Be aware, however, that this is only a quick fix and does not solve the problem. When Logitech and Skype have problems like this, they can be pretty big ones, and can cause performance problems as well as interface problems.
The Logitech QuickCam application software is not required for the Logitech Camera to function properly in Skype. If you are not using the QuickCam application for anything else, then you should seriously consider uninstalling it.
That will solve this problem, and various other potential problems and performance issues, permanently.
To uninstall it just go to Control Panel / Add or Remove Software (or Uninstall a Program in Vista/7), find "Logitech QuickCam" (NOT Logitech Camera drivers), and uninstall.
Then reboot to get rid of the background processes, and test Skype again.
May 05, 2011 | Logitech QuickCam Connect Webcam
I have a logitech Pro 9000. It works completely fine with GChat, but not for Skype. Skype complains " bad internet connection" and the video I transmit is mostly frozen. On the other hand the...
hi freeman319
you might want to try and uninstall the quickcam application. as i've researched skype is having problems with certain cams compatibility. just try and uninstall the quickcam application but not the drivers. with this you may still be able to use the quickcam with other applications.
you can uninstall it through the control panel>add remove programs
also if you are using a headset or separate mic and headset with the video call you would want to disable the mic on the quickcam
go into Device Manager and disable the microphone in the Pro 9000
ofcourse this is just some things you can try but is not guaranteed to solve your issue. please let me know if this works. thanks.
hope this helps
janc30
Feb 11, 2011 | Logitech QuickCam Pro 9000 Web Cam
I have a Logitech QuickCam 6.0 and it has been working perfectly for months with Skype. Now I am still receiving incoming video but outgoing no longer works. I reloaded QuickCam without improvement. ...
Try to check if this issue occurs on Skype only or with all programs
If it is for Skype only:
You need to check the Video Settings in Skype.
Start Skype > Options > Video Settings > select the webcam that you are using.
If the webcam is not on the list, download and install the driver from the manufacturer website
Try to set Automatically Receive Video from - select Anyone or Only people in my contact list.
Jun 01, 2010 | Logitech QuickCam Connect Webcam
I am not a computer person.I was wondering if logitech webcam C250h will work with skype?
Yes, I have a Logitech WEBcam (not the same model) and I use Skype.
After you installed Skype then :-
Mar 09, 2010 | Logitech Webcam
My camera quit working in skype, any suggestions in troubleshooting? the green light isnt coming on at all, it was working like 5 minutes ago
To test if the Logitech QuickCam is functioning, check the USB cable, make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
Dec 14, 2009 | Logitech QuickCam Connect Webcam
Hi, i would like to take live picturs and/or video while i am chating with skype and dont know how to do it. will you help me ? thanks, eddie
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Skype issues with your QuickCam Communicate STX trnsp.gif Detailed Description 1754.1.0.jpg This article explains what to do if you have problems using Skype with your QuickCam Communicate STX.
Model Number: V-UBK45
trnsp.gif Answer If you are experiencing difficulties using the QuickCam Communicate STX with Skype, check the following:
Verify the QuickCam Communicate STX is functional:
  1. Launch QuickCam software (Start > Programs > Logitech > Logitech QuickCam)
  2. Verify that you can see yourself in the QuickCam window as shown below:
  3. Close the QuickCam window.
Verify that the QuickCam Communicate STX is selected in the Skype Settings:
  1. Launch Skype (Start > Programs > Skype > Skype)
  2. Click Options from the Tools menu as shown below:
  3. Select the Video Settings option from the Skype sidebar as shown below:
  4. Check the Enable Skype Video checkbox as shown below:
  5. Check the "Start my video automatically when I am in a call" checkbox as shown below:
  6. Verify that your QuickCam Communicate STX is selected from the Camera drop-down menu as shown below:
  7. Verify that your QuickCam Communicate STX is selected from the Microphone drop-down menu as shown below:
  8. Verify that the "Let Skype adjust my audio settings" option is checked in Audio Settings as shown below:
If you still cannot see or hear the other person, it can be due to a variety of possible issues, including:
  • Windows or third-party firewalls
  • Your internet service provider (AT&T, Comcast, etc) could be blocking certain services.
  • Missing Windows system components.
Jan 10, 2009 | Logitech Quickcam Chat Webcam
Connecting Webcab to SKYPE
I could help you but would have to get on Skype and talk you through the setup. Bud
Jan 07, 2009 | Logitech Quickcam Chat Webcam
Logitec quickcam problems
Seems not a problem of your camera as the image it records of you is transmitted clearly to the folks you call. Maybe those people should get the same camera you use.
Or it their/your internet connection upload/download speed
Or it is skype - i use skype, but some of my friends move to MSN as they say it supports better quality experience of video chats
Sep 14, 2008 | Logitech Quickcam Chat Webcam
QuickCam and SKYPE on MAC OS X
Try macam http://webcam-osx.sourceforge.net/
Aug 07, 2007 | Logitech QuickCam for Notebooks Pro...
Logitech QuickCam Connect Webcam Logo
124 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
