Question about Nokia 5310 Cellular Phone
5310 failure when instert 2GB microSD
For abouth a mounth, phone and the card were working normaly.
In past two days it starts to freeze.
I remove the microSD card and it's working, but when i instert microSD it's freeze, white screen, keypad not working etc.
Help
Thanks
    Guru:
  • 832 Answers
Hi thanks for using fixya!!!
You know what, I experienced the same problem, What i did, I bought a new microSD card 2GB, and now it is working fine.
I suggest to you that, try to reformat your SD card, then insert it again, if still the same, buy a new one, it is very affordable I can say.
Good luck!!!
Don't forget to rate my solution!! thanks!
Posted on Mar 03, 2009
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
MEMORY CARD NOT SHOW........?
Hi. Nokia 3110 uses microSD card up to 2GB only. Please check the size/capacity of your memory card and make sure it is 2GB or lower. Higher capacity will not be recognized.
If your memory card is below 2GB, remove the card from your phone and use a card reader to connect that to any computer and see if you can see the drive. If your memory card appears in the computer but not on your phone, you may have a bad slot but if card did not appear in your computer, you may have to consider replacing the memory.
Good luck.
Sep 03, 2010 | Nokia 3110 Cellular Phone
I Place My Memory Card ( SanDisk 2GB ) Into Phone - Not Working
Not all phone support high capacity microSD, check your phone spec and capability of handling microSD
Apr 30, 2010 | SanDisk 2GB microSD Memory Card
PNY 2GB, Download computer stuff to the memory card?
simply copy stuff and paste them after opening ur card.
vote if find useful
Feb 20, 2010 | PNY 2GB microSD Memory Card
I bought a scandisk 2gb microSD for my Nokia 5310, but when I put it in my phone won't power on correctly. How do I fix this?
That card is not good, i think. Try any other card, if it works, then, go for the replace of the card.
Oct 09, 2009 | Nokia 5310 Cellular Phone
I CAN`T PUT MUSIC IN IT
Make sure that the microSD card is formatted. You may reformat the memory card using your phone and then try saving some music.
If that will not do any help, try using another microSD card to see if the card is defective.
Have a great day!
Jun 19, 2009 | PNY 2GB microSD Memory Card
How do I use the SanDisk 2GB microSD
Just put ur devices in then select the removable media drive which is max in fat system then copy ur files on the adaptor then paste to ur sandisk 2 gb drive
please vote for me
May 19, 2009 | SanDisk 2GB microSD Memory Card
Format the memory card on the computer. You must have an memory card reader. And also format your cellphone.
Mar 03, 2009 | Nokia 5310 Cellular Phone
SanDisk 2gb Micro SD stopped working
some card readers have a max memory size spec - iRock IR-5300 is 2GB - mine did the same thing when I put a 4GB card into it.
The other issue is that there is no drive letter assigned to the card reader - but that will show up as the "Removeable Drive" not even appearing in WE. For that u have to go to the computer manager and find the device and assign a drive letter to it.
Dec 03, 2008 | SanDisk 2GB microSD Memory Card
Nokia 5310 Cellular Phone Logo
70 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
