I have a Kenmore washing machine and so far I haven't have a problem with it...the problem is that most of the time when we do laundry a horrible sewer smell comes out. It doesn't seem to be coming from the washer machine but it happens when we do laundry. Can you help me figure out why that horrible smell sorrounds the whole house?
  • damarina1960 Mar 03, 2009
    Thank you so much...I will be checking on this today. Hopefully this will help the problem.
  • 117 Answers
You are probably correct with the idea the sewer smell is not coming from the washer but rahter then drain line. Was this recently installed or has a slow drain down the pipe? There is suppose to be what is called a P-trap installed in the drain pipe to restrict the gases from coming back into your home. Check the drain line. If I can help further, I am here. Eric Campion
Posted on Mar 03, 2009
Why is my kenmore 90 series model 20912 flooding wall drain pipe when it drains
If the water ios coming out of wall drain time to call a plumber your drain is blocked, laundry drain is usually lint from washing machine.
Feb 10, 2018 | Kenmore Washing Machines
We purchased our Kenmore front loader when they first came out. Shortly after,...
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
on Apr 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Enamel finish exensive chipping. Revealing 1/8 inch thick coorosion underneath. Problem is over 50% of the machine.
Horrible, horrible, horrible expensive machine. I finally had to buy a really cheap machine as a substitute, and it works perfectly. Sometimes expensive does not mean quality. Sorry!
Jul 04, 2014 | Kenmore Oasis HE 27082 Top Load Washer
LG Steamwasher after wash cycle left dirty marks on clothes.
You may have some detergent residue inside the tub assembly. You should run a tub clean cycle and use some washing machine cleaner. You can get that at any hardware store. If you don't have a tub clean setting, use the sanitary wash cycle without any laundry inside. You must use the hot water setting for this to work. If you haven't done this in a long time, you may have to run this cycle at least once a week for a month to really clean the machine properly.
Jun 23, 2011 | Washing Machines
We have a Samsung WF8802 RPZ washing machine with a 5ud fault code. What is the problem?
We have a Samsung WF8604NGW front loading dimond 6kg washing machine. We had the 5ud error message. It turned out the filter was clogged with fluff from a new set of bathroom mats my wife washed. To fix: Put the machine on to drain (if poss) - should be 1 minute on our machine however as the machine was so clogged it took around 15 to finish. Also use the draning tube located next to the filter (on our machine) to get rid of as much water as poss. Now remove filter and clear (warning some water will remain in the system) Before spinning any laundry run the rinse cycle (with an empty drum) a couple of times and clear the filter each time. If the filter is still clogged the laundry will spin heavy as the water will still be in the drum leaving you with no very dry laundry and a horrible noise during the spin. Regards Rik.
Nov 14, 2010 | Samsung Washing Machines
Machine does not spin, it only makes a horrible racketing noise
Sound like you have a busted coupler .It is located between the motor and trany.Cheak inbetween .hope i helped.:)
May 18, 2009 | Kenmore 22422 Top Load Washer
1) laundry smells bad after wash & 2) leaking conditioner
Check that your overflow pipe is higher than the pipe it goes into. As sometimes waste water, as it drains from the sink after washing up etc, will leak into your machine, and stagnate.
Best of luck.
Mar 31, 2009 | Washing Machines
Kenmore washer humms and smells horrible....
You have a bad motor. ( very common) If you take your model number to a local used parts store you may be able to find a good used motor for cheap. If no luck finding a used one, Order it from sears. (the motor is deffinately your problem, I replace them all the time.)
Nov 13, 2008 | Kenmore 24032\24036 Top Load Washer
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
215 people viewed this question
Top Washing Machines Experts
