Question about JVC SR-VS30 Mini DV/S-VHS VCR
My JVC SR-VS30U dosen't work any more only on firewire port.I can't communicate with my computer,dosen't matter my Mac ou PC,stop.Any thing else works fine. Were i can by a part for replace?thank you
  • braziliancap Mar 03, 2009
    I did everything.Sent to a repair shopping in Seattle WA, but the guys there only took my money and did not fix .
    Now i living in my country Brazil,and wold like know were i can buy firewire port to my VCR.Thank you.
  • Michael Innes Sep 19, 2013
    Which shop in Seattle should we avoid?
  • 24 Answers
Its broken
Posted on Mar 03, 2009
  • Michael Rouse
    Michael Rouse Mar 03, 2009
    Have you swapped out cables? Maybe its a simple thing like that
I have a apple computer with a broken screen how
You need a simple LCD monitor attached to the monitor port on the back of the Mac. A PC Laptop is not a Monitor. Check your port connector type. Adapters are available.
Also... a Mac can be booted up in Target Disk mode which allows you to attach it to another Mac or PC via the FireWire port (not sure about USB Port) just like an external Hard Drive. Be careful not to erase or partition the drive though. Also a PC might not be able to read or write to a Mac Formatted drive. But it works great with other Mac's and allows you to get access to your files until your screen is fixed or an add on monitor is located.
Just reBoot your Mac with the "T" held down and you will see a FireWire Logo bouncing across the screen.
Use a FireWire Cable to another Mac's FireWire port and your drive will mount on it's desktop.
See http://en.wikipedia.org/wiki/Target_Disk_Mode
Good Luck
Cheers
Sep 06, 2014 | Computers & Internet
Step by step instructions to transfer recorded videos from jvc gr-d370u to Pc, please.
First, you need a Firewire connection (also called IEEE 1394). Most of PC computers don't have it, including mine. I bought a cheap Firewire card and installed it into an empty PCI slot, costed about $15.
I hope you don't have the USB cable and the firewire cable plugged into your computer at the same time. That can break things.
With the firewire cable plugged into the DV port of the camcorder and the firewire port of the computer and the camcorder is in Play mode (and plugged into the wall AC power with the power adapter), are you saying that when you launch MovieMaker and "Capture", the video camera is not recognized?
There are only two conditions that can cause this:
1) The firewire400 port on the computer is not working properly (how do you know it is working?). If you are using Vista Home Basic, chances are good that the IEEE1394a firewire port drivers were never loaded... so, that will be your first step. Get that port working and you'll be ready to go.
2) The DV port on the camcorder is not working properly. This could be for several reasons, but lets hope the DV port was not fried if you ever had the USB and firewire connections to your computer at the same time... Reset the camcorder to factory defaults by disconnecting all cables, removing the rechargeable battery and removing the little date/time button battery inside the camcorder. Wait for about 20 minutes. Put the button battery back in, then put the rechargeable battery back on. Set the date and time. Connect the firewire cable to the DV port, connect the AC power adapter to the wall, connect the other side of the firewire cable to the firewire port on the computer, launch MovieMaker - will it "Capture" from the video tape?
Anyone you know nearby with an Apple Macintosh and iMovieHD? You will need a 4-pin to 6-pin firewire cable and the AC power adapter. If it works with the Mac, we know it is not the camcorder's DV port. If it does not work, chances are good the camcorder's firewire port is bad.
Hope this was helpful?
Jan 30, 2011 | JVC GR D370US camcorder Mini DV
Hi, I have a JVC GR DVX 707EK Camcorder and wanted to know whether I can buy anything thyat would enable me to downlaod the videos done directly onto my PC or MAC. Any assistance would be appreciated
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. As you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
Nov 30, 2010 | JVC GR-DVX707 Mini DV Digital Camcorder
Je veux pilote de jvc gr-dx37e
Donc, pour résumer, la méthode que vous utilisez sera très dépendante de la configuration de votre ordinateur. Vous pouvez utiliser une interface Firewire uniquement si votre appareil dispose d'un DV "in and out" (Firewire, IEEE1394, iLink) et votre ordinateur possède une carte FireWire et d'entrée. Sinon, vous aurez besoin d'une carte de capture vidéo analogique pour votre PC capable de capturer des vidéo. JVC (Royaume-Uni) ne vend pas de telles interfaces ou logiciels de montage vidéo en plein mouvement sur un PC ou un Mac d'Apple. Ci-dessous sont des liens vers les fabricants de produits adaptés. Avant d'acheter, s'il vous plaît n'oubliez pas de vérifier que tous les produits que vous achetez sont appropriés pour votre application particulière.
www.matrox.com
www.dazzle.com
www.adobe.com
www.belkin.com
www.pinnacle.com
www.apple.com
www.roxio.com
www.ulead.com
Aug 11, 2010 | JVC GR-DX37E "PAL" Mini DV Camcorder
JVC incompatible and useless
if it has a firewire connection then it should work with your video editing software as an AVC-compliant device, provided you have a 1394-compliant port on your PC/Mac.
Jun 12, 2009 | JVC Video Cameras
JVC SR-DVM600 not recognized by Adobe Premiere Elements 4.0...
I HAVE SAME PROBLEMS AS FLUING PUFFIN ANY SOLUTION EMAIL AT tahirpm@yahoo.com
Jun 01, 2009 | JVC SR-DVM600
Transferring camcoder to computer form
Had same problem...although manual states you can transfer via USB, it doesn't work and won't no matter how many drivers you find. What does work is a Firewire cables. You have three options but I only have tried and proven one. Options:
1. 4-Pin to 4-Pin Firewire transfer cable. The camera has a Firewire port directly below the AC Power adaptor port. This worked fine pulling the video to my PC using Windows Media Transfer. No drivers necessary...at least for Vista. As soon as I plugged in the camera, a window opened asking what actions I wanted to take. Only my HP Laptop equipped with 4-Pin Firewire.
2. 4-Pin (Camera) to 6-Pin Firewire (PC). My Laptop or Desktop not equipped.
3. 4-Pin Firewire (Camera) to USB (PC). Might work but since I couldn't pull data through Camera USB, didn't want to invest in this cable configuration.
Solution in future is buy a bunch of SD Media cards (Not SD-HC) and stop using tape. Transfer direct to PC from SD Card.
Nov 11, 2008 | JVC GR-D271U Camcorder
Jvc gr-d72u
use firewire cable from your dv port to stream video-4-4 pin for laptop 4-6 pin for mac or tower
May 17, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
JVC GR-D275 not seen as connected to computer
Many Camcorder users have faced problems while connecting their camcorder to their PC. One of the most common problems is ?no activity? after connecting the camcorder to the PC. The found new hardware wizard does not run and fails to detect the camcorder. This can mean two things. Either the DV port on the Camcorder is not working or the FireWire cable is faulty. Try using a different FireWire cable. If the camera is still not detected by the PC, try connecting it to a different PC. If the Camcorder is still not detected, then your camcorders DV port is most likely at fault. Confirming that the FireWire Port on you PC is working fine You can check the status of the FireWire port from under Device Manager. To access the Device Manager, Right Click on My Computer and then click on Properties. Select the Hardware tab and click on Device Manager. If you cannot see the FireWire port in the list, then it is not inserted properly into the motherboard. If you see a Yellow exclamation mark, then you need to install the drivers, which are usually bundled with a Floppy or CD with the FireWire card.
Dec 21, 2005 | JVC GR-D275 Mini DV Digital Camcorder
JVC SR-VS30 Mini DV/S-VHS VCR Logo
669 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
