Question about Everex StepNote NC1500 Notebook
Windows could not start because of the following file is missing windowssystem32configsystem
  • mybrowneyes1 Mar 03, 2009
    I don't have a cd
    President:
  • 1,073 Answers
Easy to fix M8!
Just boot up from your windows cd, and when you been asked it you want to reinstall or repair your OS, select REPAIR.
Windows will put the missing/bad files back again and you pc will run as before
Good luck
Nic
Posted on Mar 03, 2009
  • Nicolas
    Nicolas Mar 03, 2009
    If you have a friend who has one, borrow it.
    Nic
Windows could not start because the following file is missing or corrupt:WINDOWSSYSTEM32CONFIGSYSTEM
restart in safe mode, if you can, and attempt a recovery. If this does not help use the repair facility from your windows disk
Jun 05, 2015 | ASUS Eee Computers & Internet
My computer wont boot windows but say's: windows could not start because the following file is missing or corrupt ;windowssystem32configsystem. What can I do?
Boot to you XP CD< press R for recovery console, run CHKDSK /R see if that resolves.
If not, hold Fn While powering on the system and run diagnostics the Hard Drive might be failing
Jul 27, 2010 | Dell Inspiron 1501 Notebook
I get a message that Windows could not start because the following file is missing or corrupt: /WINDOWSSYSTEM32CONFIGSYSTEM I bought this thinkpad preloaded with Windows XP and do not have an original set...
About the only thing you can do is buy or borrow another Windows XP install disc as this is the only way you'll be able to extract the missing file using the repair console. Hope this helps.
Sep 19, 2009 | Computers & Internet
I HAVE NEW ASUS 1005HA ON STARTUP IS SAYS WINDOES COULD NOT START BECAUSE THE FOLLOWING FILE IS MISSING OR CORRUPT: wINDOWSSYSTEM32CONFIGSYSTEM. IT THEN ADVISES YOU CAN ATTEMPT TO REPAIR THSI FILE BY...
This shouldn't be your problem; if the unit is new, go back to the source from which it came and let them deal with it. Any new machine should start without that kind of problem. Since it is missing a critical file, you may not be able to start it in the so-called 'Safe mode.'
Jul 16, 2009 | ASUS Eee PC 2G Surf Notebook
Computer does not boot
you have to installed a new Windows xp but when he ask the repair and new installation the go for the repair you got the old files as it is
Apr 15, 2009 | Sony VAIO (PCWA-A200)
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
Apr 08, 2009 | Acer Aspire 5610-2328 Notebook
Windows xp corrupted
This is supposed to be caused by some missing registry entries in your windows installation. Not exactly sure why this is happening. May be you have some important files that cannot be copied due to a damaged CD. Microsoft replaces the media for you so that you can try installing using the replacement. Click here for more details
http://support.microsoft.com/default.aspx?scid=kb;en-us;326246
You can also try to recover the PC using recovery console. To do it follow the steps below
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:windowssystem32configsystem c:windows mpsystem.bak
    copy c:windowssystem32configsoftware c:windows mpsoftware.bak
    copy c:windowssystem32configsam c:windows mpsam.bak
    copy c:windowssystem32configsecurity c:windows mpsecurity.bak
    copy c:windowssystem32configdefault c:windows mpdefault.bak
    delete c:windowssystem32configsystem
    delete c:windowssystem32configsoftware
    delete c:windowssystem32configsam
    delete c:windowssystem32configsecurity
    delete c:windowssystem32configdefault
    copy c:windows epairsystem c:windowssystem32configsystem
    copy c:windows epairsoftware c:windowssystem32configsoftware
    copy c:windows epairsam c:windowssystem32configsam
    copy c:windows epairsecurity c:windowssystem32configsecurity
    copy c:windows epairdefault c:windowssystem32configdefault
  6. Type exit to quit Recovery Console. Your computer will restart.
Source:http://support.microsoft.com/kb/307545
Dec 29, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Dell dem 3000 will not turn on
Reinstall the missing or corrupted file
May 25, 2008 | Dell Dimension 3000 PC Desktop
Everex StepNote NC1500 Notebook Logo
43 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
