Question about Frigidaire Washing Machines
LINKING WATER WASHING MACHINE LINKING ON THE FLOOR FROM BOTTOM?
    Problem Solver:
  • 14 Answers
Pump or hose broken
Posted on Mar 03, 2009
I have to empty about 1 ltr of water when I remove the pump cap each time I do a wash. No foreign objects and whell rotates OK.
washing machine pumps do not pump all the water out as you will notice if the hose falls on the floor
there will always be water in the bottom of the bowl and hoses up to the level of the bottom of the bowl
Jun 15, 2015 | Washing Machines
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Water runs out of bottom of drum through machine onto floor
The first thing to check is the bellows, also called the front seal. Look for any tears, if any found, that would be your problem. If not, then the next thing is to take the top off the machine by removing the screws in the back of the upper part of the machine and checking the lines that run from the water valve to the dispenser.
May 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from bottom of machine onto floor during fill and wash cycle
there are 3 bolts are bottom front compartment, may be taken off with a phillip screwdriver, or it may be a torx. when you take it off, cut your washer on and see where it is leaking, your gasket could be broken, your hoses or pump.
Sep 07, 2009 | Kenmore Elite HE4 Electric Dryer
Water is leaking on to floor checked all
Does the machine have a filter that needs cleaning at the bottom front of macine
Jun 06, 2009 | Roper RAX4232KQ Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Washing Machine Emptying
Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
May 27, 2009 | Washing Machines
The water will not drain out of the wash tub
The water drains out of the washing machine but the other day when I moved the washer I noticed that I could feel water sloshing around in the bottom of the drum but nothing is leaking on the floor.
Mar 21, 2009 | Kenmore Washing Machines
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
