Question about ViewSonic VA702B 17" LCD
My biewsonic va702b, when powered up flashes for one second the screen. it's bright in all the corners, just wont stay on, power light changed to orange. do I have inverter problems??
    President:
  • 2,992 Answers
The power light turning orange means the monitor isn't getting a signal from the computer. Or the monitor has a problem. If the screen shows light in the corners, the inverter is working. (If the inverter stops there is no light at all.)
The first thing to try is connecting another monitor to make sure your computer is actually starting up. If that monitor also shows nothing, you have a computer issue to take care of. Otherwise the monitor needs service.
Posted on Mar 03, 2009
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
My viewsonic va702b will flicker on for less then a second then goes off. The green light stays on but has a black screan. Whats goin on.
This is a common problem with this model. The capacitors in the power supply board have failed and are preventing the unit from powering up. Here is a link to a repair kit with the correct capacitors and a pictures showing where the one are located that need to be replaced. Very easy repair.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=218
Jun 23, 2012 | ViewSonic VA702B 17" LCD
No Image on screen, Faint inage on the screen when held in front of a light, Outputs to external monitor, when you toggle Fn & F2 screen flashes on for a second
Hi
This is an inverter problem normally. But still there are ways to diag. the problem please follow the below steps just to rule out the bad inverter.
1. Try to check if the small button used by the LCD to turn off the LCD back-light is stuck. you can find it in some corner or little adjust-cent to the power button.
2. The signal cable connecting from motherboard to the LCD may be loose.
3. If your power adapter is not supplying enough power to the motherboard will also effect the brightness.
4. Make sure you have used the option to bright the back-light by using Fn+f4 or f7 in some laptops.
Jul 19, 2011 | Lenovo G550 Notebook
How do i dim the screen brightness on a dell inspiron 1525 laptop
Look at your keyboard some of the keys have blue symbols on them, that's the second function. At the bottom left of your keyboard next to the control key there's a button that says Fn on it hold that down and then press one of the other buttons to use the second function. The brightness control is the up and down arrows. Hold Fn and press up or down to change the brightness.
Also if your laptop is set to a lower power setting the display wont be as bright. Click on the little battery symbol at the bottom right hand corner of the screen a little menu will pop up that says select a power plan if its set to power saver your screen wont be as bright.
Jan 19, 2011 | Dell Inspiron 1525 Notebook
Screen will not stay bright
That's the battery saver feature of that Philips portable. If you use an A/C power adapter, the light will stay bright.
Hope this helps!
Sep 10, 2009 | Televison & Video
Nintendo DS lite power light comes on but both screens stay dark?
When you boot the Nintendo DS you can change the illumination settings in the main menu.
One the main menu, you will find a sunny symbol in the lower left corner of the screen. Click on that and you should be able to change the level of illumination. If you are also wondering if you can change the brightness during game play, you can't. Games such as Mario 64 DS come with support for brightness change but otherwise you have to do it before game play.
Sep 20, 2008 | Nintendo DS Lite Console
Flashing on and off
your TFT monitor haveing Power supply Problum please contact if you are in mumbai india on 9820068101 he will come and change your supply
Aug 15, 2008 | ViewSonic VA702b 17" LCD Monitor
Viewsonic VA702B
Monitor going black after a few seconds can be caused by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Jul 28, 2008 | ViewSonic VA702b 17" LCD Monitor
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
Powers on shuts off after 10 seconds- red/green flash
its probably the bulb. if the red and gren lights are flashing simultaneously, than that means the bulb is burnt amd you need to order a new one and replace it.
hope this helps
Sep 22, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
ViewSonic VA702B 17" LCD Logo
261 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
