Question about HP LaserJet 2605DTN Color Printer
WHEN PRINTING THE COLOR IS VERY WEAK - HP LaserJet 2605DTN Color Printer
  • LADYCAGE Apr 26, 2009
    MY 2605 DOES THE SAME THING, IT PRINTS BLACK AND BLUE THINGS FINE BUT ANYTHING RED OR YELLOW WILL NOT PRINT
    Problem Solver:
  • 20 Answers
You have to disassemble the printer and clean the prisms inside the black box within the printer. The prism for the red and yellow colors are near the bottom and face up, so they easily collect dust buildup, thereby causing weak or striped printing of these colors.
Posted on Apr 05, 2010
    Problem Solver:
  • 6 Answers
Hello a possible cause for not printing in a correct way is the use of compatible toners for the printer.Or a combination of original toners and compatible.Possible cause might also be a psecific toner of the printer so a test could also be single print out in pages,blue,red,yellow,black.So to as to understand also if the problem occurs of a specific toner!
Posted on Nov 20, 2009
Help, color and clarity is weak what do I do?
You don't give a brand of printer, but some printers software let you go into print properties and set the printer clarity and darkness. Maybe yours is set light, because of someone trying to conserve ink. Please rate my answer so I get points for it.
Jan 22, 2012 | Office Equipment & Supplies
Colors not showing up
A firmware update for the Lexmark Impact S305 printer addresses print quality issues. Please visit the Lexmark website at http://bit.ly/guXLhl to download and install the update for your model. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Should the problem continue even after the update, please contact Lexmark Technical Support Center for further assistance.
Dec 13, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Roland SP 540v with Eco Sol Max ink. ... When printing large solid colors, especially blues and light blues, there seems to be an ink supply weakness that shows up in soft-edged stripes in the direction of...
Inhae had similar issues, I corrected it by slowing down the print rate to 250mm per sec and also doing a calibration to the messy used if all else failed calibration wise I used textile heat transfer profile for printing on both banner and vinyl hope this helps
Sep 21, 2010 | Office Equipment & Supplies
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
EasyShare 5300 colors are weak and tend to have a
No replace it, calll 1.800.421.6699 for a new free one.
Jun 30, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have an HP 6180 that works fine except the colors are WAY off -- everything is muted and dull and the blacks are very weak. I've tried everything in the print dialogue box -- switching to application...
Bugger! HP wants your printer to work, so you buy more ink! Mine works beautiful
Scan a good photo and print it out or insert SD card and print photo on PHOTO paper GLOSSY SIDE DOWN Inkypete
Apr 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Where to disable color management in printer driver dialog box
When you go to print.  In the box that say's print with printer/presets there's another that say's copies and pages, scroll down to Color Management. Then you will see a Off (No Color Adjustment). Try that and also in the same dialog box is Print Settings that's where you put your paper type selection. Hope this helps
Dec 18, 2008 | HP Photosmart D7460 Printer
Z617 has worked fine for a year. Black print went weak, bought new cartridge. Print still weak (too weak to read). any ideas? Thanks
If the color M Y C are still good try setting the drive within the OS back to factory default and run a test page, or it might be a setting on the printer, but I would start with the print driver 1st
Jun 01, 2008 | Lexmark Office Equipment & Supplies
HP LaserJet 2605DTN Color Printer Logo
333 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
