Question about Nokia Bluetooth Headset Headset
Can not remember how to pair my nokia bh208 headst
Can not remember how to pair my nokia bh 208 headst to my phone could you help me please.
Try this:
Pair the headset
1. Ensure that your phone is switched on and the headset is
switched off.
2. Press and hold the power key until the green indicator light
starts to flash quickly.
3. Activate the Bluetooth feature on the phone, and set the phone
to search for Bluetooth devices.
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing.
You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the
phone menu where you can view the currently paired Bluetooth
devices. The headset is now ready to use.
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-208_APAC_UG_EN.pdf
Posted on Mar 03, 2009
How do i pair bh-108 headset with a nokia c5
on the bh-108, press and hold the power button till its completly off, then press and old power again till it turns on but dont leave the button even when its on, after about 10 seconds you should see blinking light of 3 different colours, that is pairing mode.Open your phone settings, connectivity, bluetooth and click on add new device, search and you will find bh-108, click on it, password is 0000 saved. click it again and click connect or just press the answer button on the bh-108 and it will auto send a connection request to the nokia, press yes thats all.
Nov 09, 2011 | Nokia C5 Cell Phone
Is symphony FT 40 support nokia BH 503
Please activate the bluetooth on your phone and see if it is pairing . use the pairing code to confirm.
Please check for details from manual:
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-503_apac_ug_en.pdf
Oct 24, 2011 | Nokia BH-503 Bluetooth Headset
BH 503 bluetooth headset is detected on my phone but it doesn't get paired with the 0000 pairing code. Is this a comparability issue. My phone model is Sony Ericsson Satio U1i with Symbian OS.
vsidharth I had the same problem with my satio.. i fixed it,
what to do is pair your bh-503 then click on auto connect.. now click on bh-503 a menu pops up look for set unauthorised.. turn it on
now turn off your ear phones and back on, your satio will say connect, and will now give you the option to enter your pair code 0000.. once you done that, your ready to go.. hope this helps
Jul 14, 2011 | Nokia BH-503 Bluetooth Headset
I m not able to connect my BH 208 headset to nokia E71 set
Make sure that the headset is properly charged before following the instructions below.Please follow the detailed instructions in the correct manner to successfully pair your Nokia E71 with the BH-208 Headset.
Charge the battery
The headset has an internal, non removable, rechargeable battery.Do not attempt to remove the battery from the device, as you may damage the device.
1. Connect the charger to a wall outlet.
2. Connect the charger cable to the charger connector. The red indicator light is on while charging.
It may take a while before charging
Switch the headset on or off
To switch on, press and hold the power key until the headset beeps and the green indicator light is displayed. To switch off, press and hold the power key until the headset beeps and the red indicator light is displayed briefly.
Pairing the headset
1. Ensure that your phone is switched on and the headset is switched off.
2. Press and hold the power key until the green indicator light starts to flash quickly.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the phone menu where you can view the currently paired Bluetooth devices.The headset is now ready for use.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex.
Jun 14, 2011 | Nokia BH-208 Wireless Headset
Why i can't pair my bh-108 with my nokia 6500 slide?
Try searching for the nokia 6500 from the bh-108 phone if that does not work then try searching for the bh-108 phone from the nokia 6500 phone.
On some phones this happens.
Hope this helps!
Thanks
Mar 01, 2011 | Cell Phones
I cannot pair by Nokia N8 with my Nokia bluetooth headset bh 108. Please any advise. Thanks.
bluetooth headset BH-108 not connect and not pair to NOKIA_N8
king give the solution as soon as possible.
Jan 05, 2011 | Cell Phones
What is the passcode for BH-208 When I try to connect the headset, it asks for a passcode, which i dont know
the passwode is 0000 zeros trust me I have one and they never change!! I hope this helps please make sure you leave quality feedback and ratings for your quality answer today.
Apr 23, 2010 | Nokia BH-208 Wireless Headset
Bluetooth connection
flash quickly.
Feb 09, 2010 | Nokia BH-208 Wireless Headset
Can't pair up Nokia N95 with Bluetooth BH-102
Your code is most likely 0000, with a small chance that its 1234.
Jun 30, 2009 | Nokia N95 Cellular Phone
Radio Communications Logo
1,231 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
