Question about Microsoft Windows Vista Ultimate Edition
How to register ocx on vista - Microsoft Windows Vista Ultimate Edition
    President:
  • 392 Answers
[Solution # 1]
Drag and drop it onto regsvr32.exe in Windows\system32 folder. Make a shortcut for regsvr32.exe in the same folder the OCX is in and drag and drop it that way
[Solution # 2] Just run cmd.exe as administrator and try again. This is the key.
Here, step by step:
1. find the folder of cmd: it is usually on C:\windows\system32\cmd.exe
2. Do right click over cmd.exe and click on "run as Administrator"
3. now just use regsvr32.exe as you used to do!
For example, to register most Blackd Proxy ocxs, you might need to type this in "Administrator" cmd:
regsvr32.exe c:\windows\system32\richtx32.ocx
regsvr32.exe c:\windows\system32\comdlg32.ocx
regsvr32.exe c:\windows\system32\mswinsck.ocx
regsvr32.exe c:\windows\system32\msflxgrd.ocx
regsvr32.exe c:\windows\system32\msinet.ocx
regsvr32.exe C:\windows\system32\comctl32.ocx
A side result for Visual Basic 6.0 users: this seems to be the way to use components in Windows Vista properly. Just register the components of your proyect with "Administrator" cmd before adding them to your proyect (or before opening a proyect that already had such components)
[Solution # 3]
use this in command line
REGSVR32 /V then ur ocx or dll name
ex:
REGSVR32 /V CRPAIG32.DLL
[Solution # 4]
right-clicking the batch file and selecting
'run as administrator'.
richtx32.ocx
comdlg32.ocx
mscomctl.ocx
dxtmeta2.dll
Good luck
Posted on Mar 03, 2009
Comdlg32.ocx
You didn't provide a question, but I can offer this:
Re-Register the file:
You can Re-register this file it by typing "regsvr32 comctl32.ocx" from the command line in the system32 directory.
Perform the following steps to make the changes:
1. Click Start
2. In the Search bar type CMD
3. In the programs pane right click on cmd and "run as an Administrator"
4. Put in your credentials for UAC prompt
5. In the command prompt type in "regsvr32 comctl32.ocx" then press ENTER
Oct 22, 2013 | Burton Tsang Key Presser
I get an error message that says Component 'MSCOMCTL.OCX' or one of it's dependencies not correctly registered: a file is missing or invalid.
Hi
first make sure you have the file MSCOMCTL.OCX in your system
if not you can search and download the file copy to system32
then run this command -- regsvr32 mscomctl.ocx
it should solve this problem
Sep 18, 2010 | Coby CX-R190 Digital Voice Recorder
I am getting an error syswow64macromed lash lashpf.ocx failed to register hresults-2147220473
Hi
Insert the CD and exit out of the Welcome screen. Now explore the CD contents and open a folder named 'setup'. now look for a folder named SolutionCenter and open it. Look for a file named SolutionCenter.msi. Right click on it and click on 'Repair'. restart the PC if required. Good luck
Apr 14, 2010 | Microsoft Windows Vista Home Premium...
Htmlmarq.ocx unable to register in systems registry
Open regedit and browse to this key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
You should see htmlmarq.ocx and htmlmm.ocx separate keys. Rename them to something else, ie. htmlmarq.tmp and htmlmm.tmp.
You will now be able to install Office 97, including the HTML option, without incident.
Mar 05, 2010 | Microsoft Word 97 Upgrade Version for PC
There was a runtime error 339 on my pc. component 'MBPrgBar.ocx' or one of its dependencies not correctlt registered: a file is missing or invalid
1->download the file . google it.
2-> copy this file to system directory then type the following in run command
3->regsvr32.exe MBPrgBar.ocx
Jan 12, 2010 | Audio Players & Recorders
QV ver6 (Win 95/98/NT) compatible with Vista?
If you right click on the shortcut and go to the Compatibility tab you can check the Run this program as an Administrator option. This worked for me.
Jun 23, 2008 | Parsons QuickVerse 2005 Expanded Edition...
Error with Vista
If you are using any other operating system than Vista please see this article: http://www.rebrandsoftware.com/admin/supportEdit.asp?article_id=53
This error indicates that a file is not correctly installed on your system. In some cases it may be correctly installed for all standard users but not for the "Administrator" account, and you may only see this error when selecting "Run as Administrator".
The built in Administrator account is not intended to be used as a user account. It is very secure and will not allow program components to be registered. Instead you should create an account with administrative rights, and use it instead of the built in Administrative account. This will help solve runtime error 339/429 on our software, and lots of other software that you may install in the future. If you do not want to create a standard user account (not recommended) you can follow the instructions below:
If the problem started suddenly then a reinstall may fix it. If not, follow the directions below to register each file that is producing the error. You generally will only have to repeat the instructions 3 or 4 times:
Click start
In the search box type "cmd" without the quotes
When CMD.exe appears above the search box right click it and select "Run As Administrator". This will open a command prompt with admin rights.
Repeat the following for each file that is causing this error, replacing [filename] with the actual name of the file that is causing problems:
    -Type "regsvr32 [filename] /u" without the quotes
    -You will receive a prompt saying the file has been unregistered. Click OK.
    -Type "regsvr32 [filename]" (shortcut: press your UP ARROW and delete /u)
    -You will receive a prompt saying the file has been successfully registered.
    try this
    Go to Start
    click Run
type in cmd
press enter
type in the black screen
regsvr32 MSWINSCK.OCX
Press enter
it will come back the c: prompt
then
Restart your PC
Jun 02, 2008 | Microsoft Windows Vista Ultimate Edition
1)error message upon clicking on an .exe/it says my Msinit.ocx is wrong/more details ff; 2) what program do I need if i wish to open a .ppl thingey
What was the error message, also you are stating only problems, not questions, please be more specific into what you want to do so people can help you.
the only solution I can think of for the OCX error is to re-register it
Go to 'Start' -> 'Run', type (or copy/paste from here) 'regsvr32 C:\Windows\System32\MSINET.OCX' and press Enter (a message box normally appears containing 'DllRegisterServer in C:\Windows\System32\MSINET.OCX succeeded.')
Also you might have to update your .net frameworks (check microsoft update.
I went to the bridge barron site and only found this
http://www.greatgameproducts.com/weeklydeals/dealoftheweek.cfm
please link to the PPL file.
Mar 03, 2008 | Computers & Internet
Registering msdatlst.ocx and msdatrep.ocx in Vista
This may help to find the reason why msdatrep.ocx is not registering. Try http://www.dependencywalker.com/ download, run it and tell it to be associated with .ocx files too. Than you can right mouse click on msdatrep.ocx and say "View Dependencies" - any missing dlls will be in red. This may help to find the reason why regsvr32 is not working.
Sep 09, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows Vista Ultimate Edition Logo
732 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
