Question about Intel D845GVSR Motherboard
CMOS bad message being displayed
Hai friends,
when I switch on the plug My system is getting started though I didn't switch on the CPU, It starts soon after I switch on the plug switch and a message being displayed as"
Cmos/cheksom bad press F4, to set date and time",
I have changed my CMOS battery, even after that also, same message being displayed, every time it is asking to enter date and time,
earlier when I switch on plug switch(Switch board) my system was not getting started untill I press( switch on) the CPU on/off button ,
what should i do?
- psvr22
  • my_d21 May 11, 2010
    sounds risky but might have to reflash bios with either an update or same version. some more information to computer specs to motherboard model would help..
    Scholar:
  • 157 Answers
What you should do? here is what you do.....a simple idea....replace the CMOS battery and 100% it will work good...it will not bugging you everytime you open the pc....check,i need to share only my experience.
Posted on Mar 03, 2009
I have a msi g41m-p26 board and it turns on but doesn't display also the lan orange light lits up as soon as I connect power and it doesn't go off
The orange light is okay. It is just telling you that the other end of the cable is connected to a device that is powered up. The light will turn green once the LAN driver are loaded.
The display not working can be any number of problems. Make sure that the cable is plugged into the right port...some systems have more than one and since only one can be active at a time if the video is plugged into the inactive one you get a blank screen. Second, make sure the screen is working. Usually if you turn it off and then back on it will display the logo of the manufacturer or something about "no signal." Most displays also have a light telling you they are on or off. Make sure it's lit up.
Now, if the display works and displays the logo when you turn it on or at least a message saying "no signal" AND if you have the cable from the video to the system connected to the right place, but you still get no video, then the problem is in the system.
To test this we usually open the system and remove everything that can be removed because it is absolutely not needed to get the system started. We disconnect the hard drive and optical drives. We disconnect any devices, including keyboard and mouse, And we remove as many expansion cards (the ones in the pci or pciExpress slots) until we get the system stripped down to it's core.
The core of the system includes the power supply, the mainboard, the cpu, one ram module and the video components....onboard if it has onboard video (which I believe it does if my memory serves me), but a video card if it does not.
Once we are at the core we test. If it works we begin to add one thing at at time, testing as we go, until we find the bad part. If it does not come on we re-seat everything and switch to a second RAM module.
Once we have re-seated the CPU and RAM, if the thing still does not work we remove the CMOS battery for five minutes, put it back and try again.
If at that point, having tested about everything you can test, if it still doesn't come up, if we have a spare CPU we change that. If that too fails to fix the problem we consider the mainboard DOA.
Hope this helps.
Feb 20, 2017 | MSI Computers & Internet
HP Compaq dc7600 convertible minitower version. CPU clock slow. Replaced CMOS battery twice just to be sure I didn't get a bad one the first time around. Get a new CPU? Get a new MB? Trash it and...
Try installing the system board driver and chpset driver.
You can also try setting the BIOS to factory default settings.
If you have a volt meter check to see if there is votage at the battery connector, and the power supply connectors are plugged into the mother board, which I suppose you are, just an idea, if the above suggestions don't resolve your issue.
I hope this helped.
Good luck and have a fantastic day.
May 24, 2011 | HP Compaq dc7600 Convertible Minitower PC...
I have an Intel D845EPI/D845GVSR Motherboard with 512MB PC266 Hynix DDR1 RAM. When i switch on my PC, the system starts but, fails to display even the first screen that it is supposed to display...
Couple of items to try. First disconnect everything except the power and the CPU. Does it give you a beep code?
If not your either have a bad power supply, motherboard, or cpu. (Only if everything else is disconnected.)
Second, If you did get the beep code then put the memory in and see if the system starts to boot. (Try without the screen connected first. If it acts like is going to start turn it off, plug in the mouse, keyboard, and monitor and try again.) ** I have seen where an add on video card would keep the computer from starting so try with the on board video first.**
Third, start adding one extra piece at a time starting with the hard drive.
Let me know if this helps or not.
Apr 22, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
I have no display by using this mercury P1865D7 motherboard,CPU fan,CPU,RAM chip,Video connector are alright...
remove CMOS battery and the harddisk, then start ur system. It will shows the msg plz insert the boot device. Now connect the CMOS and harddisk. You will get the display...
Apr 20, 2010 | Computers & Internet
Rebuilding my computer, won't load past ''press f11 for bbs popup''
Has the motherboard got a new BIOS battery?
Check the voltage of the battery, if it is a lithium battery CR2032 then the voltage should be 3 volts, if it is less than 2.98 volts then replace the battery.
Feb 17, 2010 | EliteGroup ECS Socket AM2+/ GeForce 8200/...
CMOS setting distrubed for mercury PVM7 ver 1 board
just press del to enter to the cmos and then change the date and time of cmos and press F10 to save your configeration if you start the cpu again and if you see the message "press F1 to continue and del to enter bios it time to replace your cmos battery inside of cpu is like a coin inside of your computer
Nov 24, 2008 | Abit AB9 Pro Motherboard
Boot problems
hi friend
Keep pressing F2 or del soon as you start up your PC u have to go in cmos setup by perssing f2 or del key when windows stat then press it there was option in go in boot there is boot device pryority set there cd dvd rom by press f10 to save cmos settings & exit then after pc was reboot u will able to boot from cd
Apr 11, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Asrock P4i45gv motherboard problem
it sounds as though your cmos chip is damaged; if you are unable to get as far as the bios when pressing F2 or Del on boot up, then you may need to replace the motherboard. Also reseat your memory as that is another cause and check the Cr2032 cmos disc shaped battery as this may be flat and the original cause of constant reboot cycle. Lastly this also happens if you have changed any hardwre in your pc as windows will not boot if there have been major changes to hardware and windows will have to be repaired using your XPcdrom.
Aug 22, 2007 | Asrock P4I45GV R5 Motherboard
Intel D845GVSR Motherboard Logo
90 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
