The above problem was tried on two(2) cards with the same results. The LCD monitor shows message (no image). In using one of the above cards and took a picture (as an experiment), to my surprise, picture was shown on the LCD monitor but turning the dial did not advance or move back the image
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
SOURCE: Camera image does not show up on LCD
This model has had problems with the CCD element that acts as the eye of the camera. I would recommend that you return the camera to Canon in New Jersey and let them replace it at no charge to you. Good luck to you. Joe Weibel customelectronics.org
SOURCE: Memory Card Error-Won't take Pictures
Hi momincali - I posted a solution for someone that seemed to have the same problem as you. If you didn't see it, this is what I wrote:
I had the same problem on my PowerShot S400 as well as I couldn't reformat the compact flash
when using the feature on the camera. The solution that worked for me
was reseating a small battery (about the size of a watch battery) in
side the camera. To get to it you have to take the case apart.
I found this solution by googling and typing:
powershot S400 E50 error
I'm not sure if this site will allow me to add the web link - but this link had a picture of the camera and where the battery is located.
http://www.pinoyhack.com/2006/09/14/canon-powershot-s400-fix/
I decided to try it, since I figured I had nothing to loose, becaues otherwise I'd be looking for buying a new camera. To my surprise it
fixed my problem, but I do not know if this is a permanent fix. If you do try this - take note of where each of the screws come from. There were 4 different size screws around the case.
There
seem to be a lot of complaints about this problem though.
Good luck.
SOURCE: no image in the LCD, its black
restore the factory settings
turn camera on, press the menu button for 5 seconds and the default setting comes up. select ok and it all goes back to normal. I think that the exposure was wrong, therefore not letting enough light so the screen always appeared black.
SOURCE: memory card error
Solution:
1 set date to 31-12-2030 23h59 and switch camera off.
2 wait two minutes, day will be 01-01-2003 and camera asks you to set the date
3 take away memory card
4 set the date to today
5 insert memory card again
Now your error should be solved.
Sucess, Jonny
SOURCE: Problems trying to play back images on my CF card
Sometimes if you take the card from the camera to the computer and the computer rotates the file from landscape to portrait it will no longer playback on the camera.
