Question about Datalogic Gryphon M100 Handheld
Gryphon M100 - RS232 communication problem
After scan barcode - gun send barcode to cradle, but cradle don't send barcode to computer (through RS232).
No error indicated, no barcode received on PC.
I try 'free serial port monitor' - no communication between Gryphon M100 and PC.
  • abeber Mar 20, 2009
    I have a PC with Datalogi Gryphon M100 connected with RS232 and it works fine. I have to write a new program (with VB.NET) for a second PC. I write a program that read data from serial port, but I recive only "? ? ? ? " from th Datalogic M100 reader. Any suggest?
5 Suggested Answers
SOURCE: Gryphon M100
Hmmm are these falling apart after 2 years? A customer of ours seems to be having that problem for about 1 or 2 months. Close to our date. I saw you are from America. We're located in Europe. I havn't seen it yet, but got told the red light / beam isn't rectangluar. Seems it more V shaped. Like at 1 end a piece is missing. A new pc installation didn't help. We still want more information before we drive there. So we know what to take with us. The clean the glass every now and then, so it should be clean. Wondering if it is the scanner if there is a led broken or some lose wiring or something. Then they probably need to buy a new one. IF someone knows any other tests to try or know the solution please let me know at niels@technico.nl
Posted on Aug 07, 2007
SOURCE: Need a motherboard with DB25 male RS232 serial port
to get ur motherboard just go to the website of that ,,u can find it bt surfing
Posted on Dec 06, 2008
rdiodoro
  • 13 Answers
SOURCE: Reset on Datalogic Gryphon M100
Hello
you've solved? Do you want to reset the online? Roberto
Posted on Dec 17, 2008
SOURCE: To use the Gryphon D100 barcode scanner to work with windows XP
Thanks guy's. Overcame the problem by scrapping the whole idea and leaving it up to our "IT" experts. A resolution will be forth coming in due time by purchasing a whole new inventory system. Their solution.
Posted on Apr 02, 2009
SOURCE: no connect to rs232 serial, ports PC
df1c50d.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Posted on Aug 25, 2009
Testimonial: "Tanks a lot, i obtain solution"
HOW I WANT TO DISABLE ENTER AFTER I SCAN BARCODE..... I USE SCANNER MODEL GRYPHON GD4400
Just download print the GRYPHON quick reference guide (print on laser printer without zooming) and program the scanner to factory default.
Otherwise, you will need to download the FULL reference manual. Then print out the relevant programming barcodes that will remove the last character.
Dec 14, 2013 | Datalogic Gryphon Computers & Internet
Gryphon gm4100 ean 128 ]c1 identifier
1. Download Product Reference Guide (PRG), Gryphon I GD4100/GBT4100/GM4100 and Gryphon L GD4300 (English) Manuals .
2. Go to Page 80, Section titled GS1-128 AIM ID.
a. Scan the Enter/Exit Programming Mode code.
b. Scan the GS1-128 AIM ID=Disable code.
c. Scan the Enter/Exit Programming Mode code.
Feb 22, 2012 | Datalogic Gryphon I GM4100 Barcode Scanner...
When my scanner ls4278 is on the cradle it has a solid red light? I can't find in the manual a meaning for this.
I was also unable to find a solution for you. There are only supposed to be 2-leds in the cradle, 1-green and 1-amber. Maybe it is a battery temp fault, and it has somehow been misread. If you have another docking station and another gun, try swapping them to see where the fault lies. If on the good station the gun shows the same error, you know the fault it with the gun, not the cradle. Hope this has helped!
Mar 03, 2011 | Symbol LS 4278 Barcode Scanner
I need set header Ctrl+B. Could you please instruct me. Thank you.
Hi you can send a Ctrl+B with a one character header with values 02.
Page 63.
Enter Configuration
one charachet header
0
Exit and save configuration
Oct 12, 2010 | Datalogic Gryphon M100 Handheld
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Sep 07, 2010 | Symbol LS3578-ER Rugged Barcode Scanner
Hello
Nov 27, 2008 | Datalogic Gryphon M100 Handheld
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
Not reading anymore
The only thing I can assume is the problem is is that the COM ports have become mixed up. I believe the scanner needs to use COM3 and it could be that this may be being used by another device. We had this problem a while back and no matter how many times we re-added the device it would take a COM port higher than 4 or 5 and not any lower. If you can reset all the COM ports and re-add the scanner device then that should work.
Mar 14, 2008 | Datalogic Gryphon M100 Handheld
Wont scan The tracking number for FedEx Packages
hi You must identify the codec fedex. Then see if Manual can 'read. Roberto
Mar 13, 2008 | Datalogic Gryphon M100 Handheld
Gryphon M100
May 23, 2007 | Datalogic Gryphon M100 Handheld
Datalogic Gryphon M100 Handheld Logo
150 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
David Payne
David Payne
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
