Question about Toshiba REGZA 47HL167 TV
Toshiba 37xv555db tv stand
I have just bought a toshiba 37xv555db tv and cant seem to fit the base stand it coms with any iedas on how to fit it???
3 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: toshiba 37xv555db no picture
Its a LCD set--try in a dark room (very dark) to shine a small flashlight at the screen with set on-------------do you see a very faint image or picture on the screen?
Posted on Oct 30, 2012
  • 38003 Answers
SOURCE: where can i find the base stand for toshiba plasma tv 42hp84
You might be able to obtain a stand from Toshiba
Posted on Jan 29, 2013
I lost the base stand screws to my Toshiba 40SL412U TV - what size are they so I can replace them?
Sorry but you must take it to a parts store or hardware store and see what fits.
Nov 08, 2016 | Toshiba 40SL412U LCD TV
Need base stand part#75016165
Toshiba have now discontinued that part, this claims to be an exact equivalent and is widely available:
TVserviceParts com MultipleBrand STAND 2632 Stand Base Universal TV Table...
Jan 02, 2016 | Toshiba Televison & Video
How do I remove the stand from a toshiba 32hl57 tv
  • 1 & 2 Remove all cables and lay down towels on a clear space.
  • 3 Set the 32HL57, screen side down, onto the towels gently.
  • 4 Locate the four screws at the bottom center of the TV. These screws attach the stand to the Toshiba 32HL57.
  • 5 Using the Phillips screwdriver, unscrew all four screws, one at a time.
  • 6 Once the screws are completely removed, grab the base of the stand and gently pull away from the TV.
  • Read more : http://www.ehow.com/how_7318172_remove-stand-toshiba-32hl57.html
    Jan 20, 2015 | Toshiba Televison & Video
    Toshiba TL515U base assembly
    there are few educational videos at "u-tube" about your particular TV set.
    Try to watch those. It might help you to assemble the base. Generally speaking, most TV stands are identical in design. Some requires assembly, using screwdriver, some snapping in together. But all of them are attached to the TV via screws. Manufacture won't take a chance to attach 51" TV to the stand, just by snapping it into. cnettv.cnet.com/...tl515u/9742-1_53-50108300.html
    Good luck,
    Alex.
    Dec 17, 2011 | Toshiba Televison & Video
    I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
    1 PointsProblem with Toshiba TV Accessories I lost my screws that goes to my tv stand the base I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
    Nov 02, 2011 | Toshiba Televison & Video
    I can not get the base off
    Follow the below instruction on how to the base off your Toshiba LCD TV;
    1. Turn off your Toshiba TV if it is on.
    2. Unplug your TV from the wall and any other devices (like DVD players or Blu-ray players) that it is connected to.
    3. Put a blanket, towel or some other kind of soft object down on the floor (if you have hardwood floors and not carpeting in your home).
    4. Set your Toshiba TV down onto the soft surface with the screen facing downward toward the floor.
    5. Use a flat-head screwdriver to remove the two large, plastic bolts on the rear of the TV stand's base. These bolts are holding the stand onto your Toshiba TV. Set the bolts aside.
    6. Use your hand to pull the base off of the Toshiba TV. You will now be able to set your TV completely on the ground. Put the base (as well as the accompanying bolts) aside for safe-keeping, in case you ever need to use them again.
    I hope the above helps.
    Good luck.
    Feb 02, 2011 | Toshiba REGZA 52RV530U LCD TV
    How do you remove the base stand from a toshiba 46lx177?
    First, carefully lay the face of the TV down on a soft surface with the stand protruding over the edge of the surface, then remove jack panel cover on the back of the TV to expose the 5 screws holding the base on. Remove those screws and slide the base away from the unit. These instructions are also found on page 5 of your owners manual.
    Jan 29, 2011 | Toshiba 46LX177 46 in. LCD HDTV
    How does one remove the Toshiba TV stand. There does not appear to be any levers etc to release it. We want to mount our TV on the wall so the stand needs removing.
    ya we put four screws in the base of the stand you have to lay t.v. on a flat surface protect the screen from getting damaged by putting a blanket over it when u flip it over or lay it flat on the bed you will see the 4 screws that hold the base to the t.v., but if it's a model that's having trouble just leave the base on as you will probably be returning it the store where you bought it lol
    Aug 24, 2009 | Toshiba 40RV525U 40 in. LCD TV
    Toshiba REGZA 47HL167 TV Logo
    70 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
