Question about Toshiba Satellite A100-S8111TD Notebook
I had to replace the keyboard on my tosiba satelite A100. This was due to a spillage which stopped the old one working. I am in UK and ordered one from USA, the keys are set out slightly differnt on it but i didnt think this would be a problem. The problem is the keyboard still does not work. Any ideas?
  • 1 more comment
  • melsey2006 Mar 03, 2009
    yes its exactly the same.
    I was thinking same about the connector.
    When i check on properties of keyboard it says working properly.
    so i am presuming it is recognised.
    Caplock light does not come on.
    The on screen keyboard works in all programs.
    Is the connector something I could replace myself?
    The caplock light worked on the old one.
    I shall try removing keyboard etc. then try the spray i actually used this before but didnt spray the connector used it on the old keyboard. it dried out and a couple of the keys worked every now and then but some were sticking.
    ty for your help
    Master:
  • 404 Answers
Bad keyboard. does the connection fit exactly? compare it to the old one see if it matches
Posted on Mar 03, 2009
  • 1 more comment
  • lotfi bouakaz
    lotfi bouakaz Mar 03, 2009
    is it recognized in device manager?
    is the caplock light on when you click caplock?
    is the "onscreen keyboard" working from all programs, accessories, system accesebility, onscreen keyboard?
    the thing is, it could mean the water spill has made your keyboard connector faulty. u neva know unless u hook the new keyboard to another similar laptop.
  • lotfi bouakaz
    then if it is in device manager it means the connector is fine. what you can do it "bit risky" to buy Aerosol 50 and spary the connector then clean it off with kitchen paper. this removes liquid spill inside and out.
    does caplock light works with your old one?
    try this, remove the keyboard start the laptop, go to device manager
    and see if it finds a keyboard "without one attached"
  • lotfi bouakaz
    if the old keyboard works partly and the new keyboard doesn't work at all then the fault is with the new keyboard. have it replaced.
How do I remove keyboard in Tosiba Satelite 1715XCDS?
you might have to take some screws out from the bottom of your laptop to do this.
May 26, 2014 | Toshiba Satellite 1715XCDS Notebook
Lenovo laptop keyboard won't work
Try a USB keyboard as a workround. This will allow you to try and re-install the keyboard drivers.
Apr 12, 2013 | Toshiba Satellite A100-S8111TD Notebook
Sticky keys dell latitude e 4300
If it is due to spillage, replace the keyboard. See utube for video instructions on how to change it and fleabay for a replacement keyboard.
Mar 04, 2013 | Dell Latitude E4300 PC Notebook
How do I remove and replace the keyboard on my satelite A 120 laptop. Can I have some instructions please.
Step one: Remove the two screws from the bottom of the computer that are holding down the Toshiba Satellite A100-S8111TD Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Toshiba Satellite A100-S8111TD Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Toshiba Laptop Keyboard.
Final step: To insert the new Toshiba Satellite A100-S8111TD Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Toshiba Satellite A100-S8111TD Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
Regards,
G33k
May 09, 2011 | Toshiba Satellite A100-S8111TD Notebook
Keyboard not working due to a spillage over keys
Very possibly, yes. Usually the internal parts of RF keyboards are heavily customized and a shop would need to keep tons of parts for every different keyboard under the sun.
Also, replacement plus spares will often cost more than a new keyboard, so there's little advantage in repairing.
Depending on the spillage, sometimes you can repair the keyboard. RF keyboards are much more difficult to fix because the spillage may have shorted circuits or oxidised contacts and tracks.
But if you've nothing to lose, and especially if some keys are working (indicating that the transmitter electronics, the most delicate part, is still alive), then you can take apart the keyboard (screws underneath, and retainer clips too). Under the shell there are other screws holding the typing surface. Removing them, the back of the surface comes off, revealing a contact membrane and a wealth of printed curlicues.
Wipe the curlicues with a lint-free cloth and alcohol to remove coffee and sugary liquids. Inspect carefully for oxidation and rust; sometimes you can remove it with a pencil rubber. Spray with a contact enhancer spray such as DeoxIT.
The membrane is the tricky part: usually lukewarm water or alcohol will do, but it depends on the formulation of the contact pads (usually black round thingies). Sometimes you can see which pads have been affected by the spillage and clean them with a cotton swab.
With RF keyboards priced around US$ 30, frankly I'd do that only for the fun of it.
Oct 28, 2009 | HP CPQ175KB Keyboard
Wireless download in tosiba a100-590
download the drivrs for toshiba frm www.driverscollection.com
Aug 26, 2009 | Toshiba Satellite A100-S8111TD Notebook
Tosiba saterlite A100 pro- how do i dimantle
1. Release the following 10 latches on the switch cover, in that order:
- Six bottom latches (near LCD/ Hinge side)
- Four front latches
2. Remove the speaker cover.
Remove 2 screws holding keyboard in place lift up and
Remove the connector CN11 on main board and keyboard.
The odds of "Repairing" the keyboard are practically nill, I would use an external until a replacement could arrive. LINK
Jun 03, 2008 | Toshiba Satellite A105 Notebook
Wireless connection
With the computer facing towards you - on the right side, first switch there (looks like a slide) is the wireless (on/off) switch.
Next after that is to check if any other wireless computer is reading your wireless signal - for it could be your modem/router.
Mar 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
