Question about Toshiba Satellite 1415-S173 Notebook
Toshiba 1410-S173 battery charging light blinks amber
I purchased a new battery from an online source and when installed it doesn't take a charge. The battery/charge light blinks amber. When I disconnect the AC power the laptop will not function at all. If I install the old battery (that just won't hold a charge for more than a half hour anymore) the light will glow a steady amber - no blinking.
What is the blinking amber indicating?
    Master:
  • 404 Answers
Did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
Posted on Mar 03, 2009
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
I purchased 512MB PC2700 333 Mhz memory module on ebay.... put it in my toshiba satellite 1905-S301 , would not work right removed module and nopw it will not power on, and when i push power button with...
remove the ram and battery try to power on. also you can power off add install ram without battery if power up .
if battery light is amber and blink speed. pls check the battery .if not battery charge pls check the battery and charge circuit
Sep 09, 2017 | Toshiba Satellite 1905-S301 Notebook
Orange battery light is doing a double blink right now... Does that mean the battery is being charged??
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
or you may try If an AC adapter is not connected to your computer, the computer's power source
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
Yes. Your original battery is defective - please look for a replacement. Hope it helps.
Jun 25, 2010 | Sony VAIO PCG-K35 Notebook
Toshiba SP 6100 Battery problem
If the charge light shows a blinking amber, then the battery is dead. If the charge light shows a solid amber, then it's charging.
Which is it?
Dec 31, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to manual on replacement of cmos batter in Toshiba 1410-S173
cmos battery is present inside the motherboard...go to tosibha website and enter ur model no...der u can download the hardware mannual for the particular model
Jul 04, 2009 | Toshiba Satellite 1410-S173 Notebook
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
Power up problem
it has nothing to do with the ram, it is the issue of the adapter or battery for toshiba laptop, if the output volatge form the adapter is not steady, the light will get yellow and blink,try it on another toshiba laptop. if it is normal, u should test the toshiba laptop battery by the multimeter, connect the electroprobes wiht the anode and cathode, if the pointer does not fixed in a short time ,the battery is the issue. change it for a new one.
Jun 27, 2008 | Toshiba Satellite 1410-S173 Notebook
Toshiba sat 1410 power charging
Categorises exactly what is/not happening. Appreciate that you have reformatted the system. So what is the situation now.? Operating system in or not in? Switch on --screen lights up to POST yes /no Machine dead or alive- ie when switched on do fans/drives run ?[listen out for them] How do you know battery is OK or power supply to computer is good?
May 28, 2007 | Toshiba Satellite 1410-S173 Notebook
Toshiba Satellite 1415-S173 Notebook Logo
797 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
