Question about Keurig B50 Coffee Maker
Clogged filter?? I have to open and shut the compartment several times to get a cup of coffee. It almost seems like the filter is clogged. Is the some way of cleaning the filter with some type of product that will unclog the filter.
  • bret777 May 11, 2010
    These units give small amounts of coffee. small is only about 5-6 ounces. Check that first. It is very doubtful that the filter would cause this, there really isn't one on most models.
    Problem Solver:
  • 25 Answers
You can try to clean out the pic and glides on the K-cup receptacle. Let me know if this works. It should.
Posted on May 14, 2009
I cant get the water to come through and brew a cup of coffee. it beeps 3 times and shuts off? is there anything I can do its only a year old.
Use a coffee pot cleaning additive (used to descale irons too) and run it through the brewing cycle.. flush it well afterwards with the brew cycle 2X more and it should be fine. Mineral deposits from hard water have clogged the line. Otherwise, get a new coffee maker as the valve in completely closed with mineral deposits and there is no way to open it to remove them and reseal it. An under sink water filter to remove hardness will prevent this from happening again.
Jun 16, 2015 | Applica Black And Decker 12 Cup...
Hamilton Beach brew station dispenses very slowly. I have cleaned it twice but still takes a long time to fill a cup!
Try to have a look whether there is a limestone layer built up on the element.
That will slow it down, while most probblems will stop it alltogether.
Remove by leaving white vinegar in it overnight.
Sep 04, 2011 | Hamilton Beach BrewStation Deluxe 47474...
When the brew button is pushed machine hums and no coffee comes out. The first time you puch button water moves, but every other time it hums and nothing happens. It may take several times before a cup...
Keurigs are known to have issues. I love them, but hate them. It sounds like your water line has clogged up. I can be wrong, but I have helped many people online fix this problem. Make sure the system is cold as not to scald yourself. Take a thin paperclip, unfold it straight and gently stick it in the k-cup piercer(where the water usually comes out of). This is done because calcium build-up and other debris causes that line to get clogged, and this method is to unclog it. If this method works, start a habit of running the coffee maker without a k-cup once in a while to prevent this. Good luck =)
Aug 18, 2011 | Keurig Platinum B70 Coffee Maker
My Keurig coffee maker seems to be clogged - it spits out just a little bit of coffee, or none at all. How do I fix it?
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 17, 2011 | Keurig Platinum B70 Coffee Maker
Coffee grounds in the coffee pot. It appears water does not flow into pot quickly enough, so filter basket overfills and causes grounds to go up and over the filter, then flow into pot. Also heat plate...
From what you described, it sounds like your carafe isn't fitting properly. The lid of the carafe is supposed to open a valve on the bottom of the filter basket. If this valve is clogged or not opening completely, that will produce your symptoms. Also, the warming element will not keep carafe hot if the carafe isn't sitting properly.
Sep 29, 2017 | Black & Decker BCM1410B 12-Cup Coffee...
I put in 12 cups of water but only get 4 cups of coffee. what is wrong
Are you sure 8 cups of water is a lot to LOOSE it has to be somewhere i am used to loosing 1/2 cup in the grounds if i make 8 or more cups i have 2 of these coffe makers one in each house the only times i ever loose more is when the filter isnt properly seated and it flows around it and makes a major mess get your coffee maker into a good light and pour water into the filter(coffee maker off) with the carafe out fill it about 1/2 way no water should leak thru then slip the carafe into place the filter should empty if the water flowed when the carafe was out your filter basket and holder arent seated or the valve on the bottom of the holder is clogged and/or held open
Dec 26, 2010 | Cuisinart DCC-1200 Coffee Maker
My Keurig was running fine and recently I purchased a box of Timothy's coffee which seemed to have bubbled lids...since then my machine doesn't brew and entire cup of coffee and it shuts off when its...
I have the same problem. Timothy's seem to be the culprit. I hate to blame a specific k-cup, but I can run a cup of my wife's favorite (non-Timothy's) through right after I have the problem and they work fine - so that clearly points to the k-cup as the problem. Maybe they are more full of grounds or manufactured weaker...when I have the problem, I took apart a k-cup and the filter had broke, therefore all grounds were clogging water exit... I love the Timithy's coffee - best taste and strong, but maybe they aren't designed the best.
Nov 18, 2010 | Keurig B60 Coffee Maker
Cuisinart Coffee on Demand?12-Cup Programmable Coffee
Hello crystalmeikl,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, crystalm. Positive feedback is appreciated. Good luck. NormanZ
Jun 16, 2009 | Cuisinart Coffee on Demand 12-Cup...
Can only make a cup of water without single serving in.
I had similar results and figured that the outflow needle, which punctures the bottom of the cup, might be clogged. The outflow needle can be accessed by just opening the top and removing any existing K-cups. I slid a narrow, stiff wire into the needle, and reamed it out a little bit. The coffee maker now seems to work as well as ever.
Apr 22, 2009 | Keurig B100 Coffee Maker
Weak coffee is the result of brew
Since it is "brand new out of the box" check for plastic burs (pieces of plastic improperly hanging around
openings along flow of water) throughout unit, and use more coffee than recommended for your taste of
what a good cup of coffee should taste like, since that varies from individual to individual. If you are using
packets, try using TWO. Experiment, Experiment...........
Apr 17, 2009 | Regal Ware 15-0264 Polished Aluminum...
Keurig B50 Coffee Maker Logo
204 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
