Question about Car Audio & Video
I have a 2002 Chevy Silverado with factory stereo. My radio will not pick up a signal unless I am within a few miles of the transmitter. Is there a solution for this before buying a new stereo?
    Novelist:
  • 110 Answers
DID THIS ISSUE JUST START HAPPENING? HAVE YOU CHECK THE BACK OF THE RADIO THO MAKE SURE THAT ANTENNA IS PLUGGED IN ALL THE WAY. IF IT IS YOU MIGHT STOP BY CHEVROLET AND SEE IF ITS UNDER WARRANTY. SOUND LIKE THE UPLINK INSIDE THE DECK IS LOSING CONNECTION. NOT SURE IF THIS WILL HELP OR NOT BUT LET ME KNOW IF IT DOES. GOOD LUCK
Posted on Mar 03, 2009
NO AM STATIONS IN MY 1998 JEEP GRAND CHEROKEE, BUT NO PROBLEMS WITH FM. DO I Have to change or repair the radio or the antenna?
A.m. radio stations have a very limited range and honestly modern units include am reception as an after thought. Unless you are within a few miles of the station you probably won't pick it up. That being said if you are close enough and still cannot pick it up then the radio is probably faulty.
Oct 29, 2016 | Jeep Cars & Trucks
Only picking up radio stations on headphones after plugging into tv audio
you have to go through the channels til u find the tv signal but the signal only goes to about 4 yrds
Sep 21, 2013 | Meridian Point 6 in 1 Wireless Headphones...
2007 chevy radio weak signal. Iknow being out of range is not the problem.
it could be a loose antenna is juest come loose from the back of the radio the antenna is for long distant stations
Dec 18, 2012 | Spyder 07-11 CHEVY SILVERADO 1500 PICKUP...
Manual for SkyScan atomic clock -model 86742 I need to know how to change the clock to eastern time.
Hello
The SkyScan ATOMIC Clock
With the Skyscan Atomic Clock, you have the most accurate timepiece within the continent. It can receive the time signal transmitted by the National Institute of Standards and Technology (NIST), which is regulated by 3 atomic clocks and deviates less than 1 second within 3,000 years. The NIST broadcasts the time signal (WWVB, 60kHz) continuously from Fort Collins, Colorado. This signal can be received anywhere in the continental USA that long wave (AM) radio reception is possible with a portable radio. It is expected that the signal can cover a distance of over 2,000 miles from the transmitter. Therefore, your clock will receive the signal within the broadcast range anywhere an AM signal can be received; generally the signal cannot be picked up in massive metal and concrete structures unless near a window. In addition, some environmental effects (see next page) may affect the transmitting distance.
Nov 08, 2011 | SkyScan 86742 Digital Atomic Wall Clock
The radio just stopped picking up any signal unless I'm within a few miles of the tower
If your lucky the antenna cable has just come loose at the radio or somewhere along its route to the antenna, more likely that it is an internal problem in the unit
Sep 30, 2010 | 2003 BMW 3 Series
Super Boss FM HI-FI Wireless Headphone SF878 no sound from the tv
Hi - the tv sound will be picked up like an fm radio signal at 83 mhz. To get there, press the reset button the side of the headphones, then press scan. the first signal to be picked up will be the tv signal. This assumes, of course that you have fresh batteries in the transmitter and headphones, and that the volume is turned up on the headphones and the TV. Worked for me. The signal is not stereo, though.
Dec 30, 2009 | Televison & Video
2004 chevy truck factory radio needs to be cleaned on the inside
Read the car manual, in the page were it shows the dashboard fuse panel find the radio fuse pull it out and put it back in with the fuse tool. This resets your radio, it did the trick for me with.
Just make sure if you disable the radio security lock if it enabled before you pull the fuse. It may lock you out, all the information is in the manual.
Good luck and hope this helps.
May 27, 2009 | 2004 Chevrolet Silverado 2500HD
2002 Oldsmobile Intrigue w/ bose stereo how to hook up Ipod
I woudnt reccomend a direct feed to your system unless it has a input on the stereo such as a aux in with an 1/8" plug. The other reccomended way is from an FM transmitter that plugs in to your Ipod and brodcasts it to your car stereo. They work great and you wouldnt know theye are not hard wired. Walmart, Radio Shack all have these transmitters. If your stereo does have an aux in with an 8th inch plug on it then simply go to radio shack and get a 1/8" male to 1/8th male stereo adapter and plug it in. Wiring the ipod without these two features will destroy both the ipod and car stereo as it creates a loop feedback against each other.
Joe
May 26, 2009 | 2002 Oldsmobile Intrigue
Ipod to radio
their are cigarette lighter adaptors that u can plug your ipod into that produce a signal that you tune your radio to and enables youto listen to your ipod threw your factory radio  simple   cheap  and sounds good    can purchase at bestbuy or  many store  possibley walmart
Feb 16, 2009 | 2002 Chevrolet Silverado
2002 CHEVY BLAZER
Can purchased an adapter kit at Best Buy or Circuit City that is color cordinated with the factory wires for about 12.00. This will go right into the factory plug.
Radio 12v orange + radio harness
Radio Ground black - radio harness
Radio Ignition dk. green + radio harness
Radio Illumination gray (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- tan - gray +,- radio harness
RF Speaker +/- lt. green - dk. green +,- radio harness
LR Speaker +/- brown - yellow +,- radio harness
RR Speaker +/- dk. blue - lt. blue +,- radio harness
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 457G, 555L, or 555T
Notes: The Passlock 2 wire colors are yellow, orange/black, and red/white (not used).
Sep 21, 2008 | 2002 Chevrolet Blazer
Car Audio & Video Logo
130 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
