Question about Bunn CDBCF35 (DBC) Digital Brewer Control
How do I set the amount of water dispensed w/ Bunn CDBCF35 Digita
Bunn CDBCF35 Digital
How can I set the amount of water dispensed. I only get about 1/8 of a pot when the brew button is pressed.
  • Anonymous Mar 21, 2014
    Not dispensing the same amount of water as placed in the machine
  • 125 Answers
Hello. You will need to set the timer, this is done, if the settings are not locked out, using the brew button on the front, holding it until 3 clicks are heard, then just let it brew until you are satisfied with the level, and turn the brew off. This does take a little practice, and may need to be done repeatedly, and you should be prepared for overflowing, just in case :) Here is a link to your manual, please read the section that is for your unit, as it is for several.
Hope that helped, thank you.
Posted on Mar 15, 2009
Bunn CW Coffee Brewer not brewing enough coffee - amount is half
Have you cleaned lately, put in an empty filter and fill with cold water with a tablespoon of white/clear vinegar. Run the brew cycle, empty pot and while still worm fill with cold water again with out vinegar. Than check filter to see how much hard water chunks are in the filter. Repeat with and without vinegar tell filter is clean. One question though is there a lot of steam coming out of the top during the brewing cycle if so inside there is a tube that may be cracked, broken or came loose, have to look inside. requires opening or disassembling unit to check. REMEMBER when taking apart UNPLUG unit first.
Nov 17, 2015 | Bunn CW Aps Single Airpot Coffee Brewer,...
Bunn hot water heater has a slow flow of water
Try brewing a few pots of white vinegar solution, no coffee in the system.
Jan 22, 2013 | Bunn 125000024 Hot Water Dispenser 5...
How do I know how much water is in the reservoir tank?
You don't. If you pour water in and it dispenses then it is full.
Jan 02, 2013 | Bunn NHBX
Have a Bunn NHB. I cannot get more than 4 cups of
I work for BUNN. Has your issue been resolved? The rocker arm is inside the pour in bowl (where you pour in the water for brewing). To get to it you have to take off the entire top lid (not just the spin lid above the pouring area). That can be removed by lifting it up and then you simply snap it back on when you are finished. Hope this helps.
Jan 03, 2010 | Bunn NHB Coffee Maker
CDBCF15 Brewer seems to have a stuck solonoid - not completely open, or closed. Can it be taken apart and cleaned - or just replaced?
lime and scale can build up in the unit and cause this problem
Best thing to do is replace the solenoid.
Also replace the in-line water filter.
If no filter, it would be best to add one to the water supply line.
Jan 02, 2010 | Bunn CDBCF15, CDBCF35 automatic coffee...
I have a Bunn Dual SH coffee brewer that does not dispense the same amount of coffee every time
The problem is either the liquid control board or there is something blocking the solenoid, or drawing water from the same line pressure. Also check the sprayhead for buildup.
Oct 26, 2009 | Bunn Dual SH DBC Coffee Maker
Set flow amount on Bunn STF 35
Remove the top panel and look for the yellow float, this controls the amount of water brewed, to adjust remove some of the washers on the float and test until you get the amount needed.
Jul 24, 2009 | Coffee Makers & Espresso Machines
Inconsistent water amount being dispensed
It sounds like there is some build up in the brew line, find the nearest bunn dealer and get a delimming spring, then remove the shower and run spring through brew line.
Apr 26, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
Bunn CDBCF35 (DBC) Digital Brewer Control Logo
139 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
