Question about Ricoh Aficio 450 Copier
Aficio 551 - error code SC124
My photocopier mechine Aficio 551 show the error code SC124 and the suggestion to turn the copier off and on. I did it and I read the message on the display "copying will start after warm up" , but it never start. When I turn off the main switch, and on again, I read the error code sc124 again. Is there any suggestion;
  • 162 Answers
Definition- [B]
No encoder signal from the scanner motor
-Possible cause-
• Scanner motor connector defective
• Scanner motor defective
• MCU defective
• Scanner wire, timing belt, pulley out of position
• PSU defective
The screws of the pulley usually are cut that moves the scanner this causes that the car is crossed and that the sensor does not detect the home position. check and corect this defect.
Posted on Sep 13, 2009
    Problem Solver:
Most likely its the scanner drive motor...I would try this first...
Posted on Mar 03, 2009
When firing machine ricoh 551 immediately get an error SC124. I took off the engine scanner, scanner plate and main board power, all joined to another machine and everything is correct and working. In what...
tell me more please did machine do main scan or no and this proplem belong to hp sensor check built of scanner move or not possible causes 1-Harness between the SBCU,
scanner motor drive board and scannerm motor diconnected
2- close machine and unplagged all harness and plagged again and notice some in home position sensors
Feb 12, 2011 | Ricoh Aficio 450 Copier
Please show me how can I unlock the error code SC305 for Photocopier Ricoh Aficio 1224c
This is a Corona cleaning unit error. You either need to get the issue with the corona cleaning unit fixed or have a service technician turn off the automatic cleaning function. SP Mode 2 801 3 (technican will know what this code means) I can not tell you how to do this as you can total mess up the machine if the service mode is not used properly.
Turning off the cleaning will solve the error code. Technician can clean the coronas himself on service calls so automatic cleaning is not required.
Good Luck
Dec 07, 2009 | Ricoh Aficio 2015 Copier
there soesnt seem to be an error 890 on system but 880 is mlb you could try and go into the service mode by pressing clear yellow button and then press 107 and hold down the stop button.. thsi lets you into the service screen you want copier sp select 5. mode and go to 5-810 sc reset press execute and turn machine off wait and turn back on it coul djust be a signal error for the address book.. good luck A
Jun 12, 2009 | Ricoh Aficio 1018D Copier
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
How to Solve Error code SC496 for Aficio 551
hello Sir; You have to empty the waste toner bottle it located right hand side bottom, open the doorlook at "A" area you will see a big narrow plastic bottle pull out a black buckle slide out the bottle, dump the toner,the code will be disappear!
Jan 06, 2009 | Ricoh Aficio 450 Copier
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 450 Copier Logo
1,201 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
