I have a Philips Freevents 12NB5800, and after using it for about 2 hours the other day, i put it into hibernation mode. Now the damn thing will not turn on. When i plug in the charger, the charging light illuminates, but when i press the power on button, nothing happens! The power button presses like it should, and is not blocked, loose or broke! So please peep's, before my good lady thinks i broke it, whats the problem???
    Master:
  • 404 Answers
Remove the hard drive, and start it
then put back the hard drive and start it.
Posted on Mar 03, 2009
My laptop keeps saying hibernating and i cannot get to menu screen.
Definition: Hibernate is another option for powering down your laptop. When you use Hibernate all data will be saved to the hard drive in a compressed form. Once you start up from Hibernate mode you will be able to work with the applications and documents you left open before putting the laptop into Hibernate.
Hibernate is best used to conserve laptop battery power when you will be away from the laptop for more than a few minutes. You can put your laptop into Hibernate overnight or when you will be away from it for a few hours. Examples: Rather than shutting down my laptop each night, I use Hibernate to help conserve battery power and enable me to access my open files quicker in the morning.
If you are not going to use your computer for a few hours, it is a good idea to put it to sleep (also known as mode) to save power. If you are not going to use the computer for more than a day, it is usually best to turn it off.
hope it helps.... please rate if you like my post...thanks
Jun 06, 2011 | Computers & Internet
Should I Leave my PC in sleep mode after use?
Go green & use hibernate instead.
Well, actually a lot also depends upon what is the duration of you not using the system between breaks. Hibernate anyways is quicker than a normal boot process. I would highly recommend hibernate.
Sleep - is a combination of stand by and hibernate. Be default most of the newer system will write the memory info into hibernation file & put your system to stand by mode. After certain period say 2-3 hours your system will go into hibernate mode. (these are standard settings & unless you keep coming back in 15-20 mins you should use hibernate & contribute towards environment too)
Oct 07, 2010 | Computers & Internet
The DVD Drive on my philips freevents 12NB5800 isn't working. The problem is that the draw opens but the laptop isn't recognising the disc. I had tried going onto my computer and double clicking on the dvd...
Either your CD/DVD drive is dirty & needs to be cleaned, or the drive has gone bad & needs to be replaced.
First, try to take the drive off the laptop. Open the drive & blow compressed air into it (from a can of compressed air) to clean it. You could also clean the lens (the small round glassy object inside the drive) using lens cleaning tissues & lens cleaning fluid.
If this did not fix the problem, you will need to replace the CD/DVD drive with a working one, or use an external CD/DVD drive
Aug 29, 2010 | Computers & Internet
Want to format the current hard disk in my laptop
Mmm, sounds like somone has pass worded the BIOS.
If thats the case you will have to strip laptop completely to remove cmos battery for 1 hour.
Apr 27, 2010 | Microsoft Windows Vista Home Basic Edition...
I would Like to downoad the drivers for a Philips 12NB5800. Where can I find them?
Copy & Paste this Website (URL) to your "search engine"
  • www.recovery-cd-disk.com/Driver-Restore/Philips/Philips-12NB5800-Driver-Recovery-CD...
  • Jan 23, 2010 | Computers & Internet
    I have a philips freevents 12nb5800 laptop and the keyboard doesnt work properly. Some keys dont work and some only work intermittently
    The Philips Freevents 12nb5800 is actually a Twinhead J12S
    The XP drivers are hard to find but they are on the Twinhead Austrailia website here;
    http://www.twinhead.com.au/downloads.asp?MainCategory=J12S
    I installed the intel VGA driver from this which allowed we to use two screens.
    Jan 11, 2010 | Computers & Internet
    My sons philips freevents x57 will not boot up. when the power button is pressed the fan whirls for a couple of seconds, the wifi and hdd light blink then nothing even though the power is still on. the...
    hi
    i think you must do a whole system restore.
    because this thing may be because of some changed bios setting..
    and if this dont workout...
    just put the bootable OS disk in the CD drive and repair the OS.
    select the repair option carefully dont select FORMAT option.
    if you find the solution helpful dont forget to rate me carefully..
    thnx
    Jun 25, 2009 | Computers & Internet
    Cannot start built in webcam on laptop,philips freevents 12nb5800
    check the driver is installed. right click my computer - click manage - click device manager on the list - check for any device with a yellow symbol , that device is missing a driver .
    Jul 25, 2008 | Computers & Internet
    Start up problem
    Hi
    Uninstall the software or hardware which you have recently install
    Jyo
    Jun 19, 2008 | Computers & Internet
    Computers & Internet Logo
    1,104 people viewed this question
    David Payne
    David Payne
