Question about NRS Efco 9" Swivel Hedge Clipper Attachment for 3600, 8370 and 8410 Trimmers
Changing pull cord on efco 8220 trimmer - NRS Efco 9" Swivel Hedge Clipper Attachment for 3600, 8370 and 8410 Trimmers
What is the fuel mix for efco tg2600xp
25:1
CAUTION: DO NOT USE AUTOMOTIVE OIL OR 2-CYCLE OUTBOARD OIL
Jul 28, 2017 | Efco Garden
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Gain access to the starter pull cord pulley efco 220 brush cutter
Hi, you have to undo the clutch spider off the crankshaft but you will need to lock the piston with a piston stop to do this. Regards Phil.
Jun 26, 2012 | Garden
Pull cord on homelite ut20006 trimmer
on the side where the pull cord was remove casing pull the cord through the hole on the casing wind the spring back on the strimmer not to tight but tight enough for the cord to return once pulled. Attach the cord onto the spring this will be obvious there is a little hole the cord goes through then pull a bit of cord through tie a nott then pull the cord back so the nott is tight against the spring ,let the spring spring back the gord shoul wind onto the spring reattach the casing and job done hope this helps
Apr 21, 2012 | Homelite Mighty Lite Lawn Trimmer
How to change the spool in the black and decker grasshog
Is this the cordless Grass Hog? Turn the trimmer upside down so you're looking at the bottom. There are two orange tabs on either side of the spool -- push these in and the head should pop up so you can pull it out.
On the new spool, feed the cord out several inches and stick it through the hole in the trimmer where the old cord stuck out. Then pop the spool into the cavity so that the orange cover faces out (toward you). Pull the cord taut and make sure it is not long enough to hit the plastic guard. If it is too long and it touches the guard, pull the spool off and wind the cord in a little bit. If the cord is too short, pull the spool off and thread out a little bit more length and try again.
Turn the trimmer right side up and turn it on to make sure it works. If you hear a loud rapid thumping sound that sounds sort of like a machine gun, the cord is too long and is hitting the plastic guard.
Jul 04, 2010 | Black & Decker 14" Grass Hog Xp...
I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Apr 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
Gasoline mix ratio for Efco 8753 brushcutter
if you buy the small bottles of oil mix it with one gallon of gas easiest way .
Aug 25, 2009 | Garden
Black & Decker Electric Edger (Corded) Died
It is just a matter of "process of elimination". Disassemble and continuity test each circuit until you find none.
Oct 05, 2008 | Garden
NRS Efco 9" Swivel Hedge Clipper Attachment for 3600, 8370 and 8410 Trimmers Logo
574 people viewed this question
Top NRS Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a NRS Garden Expert? Answer questions, earn points and help others
