Hp g6000 laptop keeps switching off
Hi i have a hp g6000 laptop and it keeps switching off like its overheating then when i try and turn it on it wont stay on unless i leave it off for a while! then it will come on then switch back off again after about 20 mins.. can u please help me?
  • 3 more comments
  • Anonymous Mar 09, 2009
    same as yours
  • Anonymous Mar 31, 2009
    Same problem
  • Anonymous Apr 25, 2009
    same
  • Anonymous Apr 26, 2009
    My friend has the HP G6000 and it has the same problem, the graphics chip overheats and shuts the laptop down, in America HP extended the warranty on the G6000 series due to this problem. There is nothing you can do to resilve this as its down to bad design.
  • Anonymous May 04, 2009
    Try paying for it, scumbag!
    President:
  • 1,223 Answers
Actually hp DV series have over heating problem after some time the cooling fan on the back of laptop gets weak, try to service the fan on the back of laptopwhile switched off with an air blower used to clean out dust see if it works other wise i think the fan motor has got weak it also gets noisy by time try replacing the fan or get it replaced
pls do rate me
Posted on Mar 03, 2009
I have the same problem, after opening up several times and cleaning out the fan it still continues to do it.
On the last opening of the laptop i noticed the heatsink for the nvidia graphics chip floats approx 5 mm above the chip (very bad design) and to save money they have just stuck a thick heat transfer pad in the gap which is not transferring the heat from the chip to the heatsink. This is a very bad design and I am searching a way of bridging this gap in a way that will disperse the heat from the chip.
Posted on Jun 23, 2010
    Problem Solver:
  • 12 Answers
You can get a really Good Flowchart at: www.powerjackrepair.com I found this very useful to diagnose all sorts of laptop issues.In Your case the CPU Fan needs looking at: Heatsinc and Fans cleaned and re-paste CPU, re-pad or paste GPU
Posted on Oct 18, 2011
No tpm or tpm has a problem
"Keeps switching off 2 seconds after pressing power button"
It is doing what it is supposed to do but most computers take about 13 seconds to power off. as far as the rest you could have a bad motherboard change the laptop.
Terry
Feb 13, 2013 | HP Compaq Presario F500 F700 and G6000...
Hi my HP G6000 laptop wont turn on, when i press the power button on the lights flicker for a second and then nothing
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD is faulty and need to replace.
Aug 23, 2010 | HP Pavilion dv6000z Notebook
Compaq Presario F500 F700 and G6000 Motherboard - 442875-001 : motherboard of my laptop is gone. What can I do?...
If you sure that your Motherboard is gone and wont work at all, sorry to tell you that but you need a new Motherboard and a new laptop.
May 17, 2010 | HP Compaq Presario F500 F700 and G6000...
Hi
The problem is from either the battery or the adapter .This is how to know;
First remove the battery of your laptop,plug the adapter,connect to electricity and put it on If the laptop turns on, then the battery is faulty and should be changed
If it doesn't come on,test it with another adapter. If it comes on then the adapter is faulty and you should get a new one
Cheers!!
Mar 03, 2010 | HP Pavilion dv6000z Notebook
HP G6000 laptop wont start
Extract your battery from your laptop for 12 min, then start your computer using your power cable (don't use your battery), if not try pressing F2 rapidly when opening, after you open your operating system try changing your graphics card drivers.
Jan 31, 2010 | HP Pavilion dv6000z Notebook
My HP G6000 Laptop switches off at different times. I have run the diagnostic programme and it tells me to change hard drive???
well change the hard drive, the software (diagnostic)is detecting hdd failure backup your stuff fast and replace the hdd
Nov 16, 2009 | HP Compaq Presario F500 F700 and G6000...
Computers & Internet Logo
2,966 people viewed this question
David Payne
David Payne
