Question about Cycling
Bike pedal arm keeps falling off as i pedal.
The whole arm falls off regardless of how tight i make the nut. what part am i looking for ?
    President:
  • 1,138 Answers
You need a new crank arm. If you ride with the nut loosened what happens is the square part of the bottom bracket shaft wears the hole out in the aluminum crank and it no longer fits snugly no matter how much you tighten it down.
Posted on Jul 11, 2009
Try putting Loctite on the thread then tighten them.
Posted on Mar 05, 2009
Remove a tight windshield wiper arm. the nut is removed but the arm is tight on the spline
Just put a little brake fluid on the area where the nut was and leave it for a bit. Make sure the fluid doesn't fall on the paint job. Just on the bolt. It should free the wiper. You can use your own car's brake fluid. Don't have to go looking for WD40. It will do the same work.
Feb 28, 2015 | 2008 Chevrolet Aveo
I cannot get my chain to stop coming off. How do I keep the chain from slipping off?
Loosen the nut that holds the back wheel and pull it back until the chain is tight and then retighten the nut. If when the chain is tight, the wheel is not on the rear frame, you need to take a link out of the chain.
Jun 25, 2014 | Mongoose 20" Mode 90 Boys Freestyle Bike
When Coasting chain rolls backwards and falls off
Chains usually fall off because the chain is not tight enough. With the bike sitting upside down on the seat and handle bars the nuts on the rear axle should be loosened and the axle moved rearward so the chain tightens. When it is tight the nuts can be tightened. In addition to having a tight chain the rear axle nuts adjust the alignment of the wheel to the frame. You know you have it right if both the chain is tight and the tire closest to the crank is centered in the frame. The nuts should be tight enough so they don't allow the axle to move when you ride it. I hope this helps.
Aug 16, 2011 | Schwinn Windwood 26 Men s Cruiser Bicycle
The seat keeps falling down when anyone sits on it.
If you have a look underneath the seat, at the back, you'll see a silver nut and bolt. Get the seat up to the height you want, and then tighten this nut and bolt VERY tight, and your problem will be fixed. Easy?
Jul 05, 2011 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Gave my 10 year old son a 20" huffy axis this past Wednesday for an early Christmas present. The pedal fell off Friday! How do I put it back on? The pedal, as well as the thing that screws into the...
Your pedal falling off is never a good thing, nor is the entire crank arm assembly.
For this one you are best taking it into your local bike shop and have them take a look at why both of these fell off. There are a number of reasons, from stripped thread to missing bolts and nuts to improper assembly. None of these are a good scenario with a childs bike, or any bike for that matter.
Alternative, and my personal suggestion - Take the bike back to where it was purchased and exchange for a new one. These parts should not fall off after years of riding let alone 2 days, and would constitute a warranty and safety issue.
I WOULD NOT RECOMMEND CONTINUING TO RIDE THIS BIKE, SINCE YOU DO NOT KNOW WHAT ELSE WAS IMPROPERLY ASSEMBLED.
Nov 29, 2010 | Huffy 20in Boys Axis Bike
Brake lights will not turn off
i've noticed this alot lately, the brake light switch goes bad or there a little round groumet that wear out and falls off the pedal causing a space between the switch and pedal, if this is the case then readjust the switch,just loosen the nut and turn in so it touches the pedal arm,if you look under the dash you will see the switch on a bracket in front of pedal arm.
Jul 21, 2010 | 1993 Geo Prizm
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
The crank arm is stripped on the left side of the bike
Yes, the crank-arm could be replaced.
1.You would need to remove the flat nut holding the crank to the frame. And then take out the bearing.
2. A special open-ended wrench is required to remove this nut. Please visit your local bicycle shop for a new crank-arm, and the required tools, also.
3. Put in new crank-arm and its bearing.
4. Grease the bearing.
5. Tighten nut.
6. Give it a test ride.
Dec 10, 2009 | Schwinn Mesa Gs Mountain Bike
I have a A40R Monegoose Mens It looks like the arms to the peddles are coming off How do I fix it?
There are usually plastic caps hiding a 14mm nut or bolt on the arms. Unsrew or snap out the caps and tighte n the bolts w/a socket wrench
May 07, 2009 | Mongoose Exile 26 Men's Full-Suspension...
The hook thing falls down
look for the nut in the needle holder and tight it.
Sep 29, 2008 | Brother LS-2125 Mechanical Sewing Machine
Cycling Logo
1,597 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
