Question about Galaxy Radios DX-2547 40-Channels Base CB Radio
Squelch circuit can i get a detailed description of squelch control circuit with the circuit diagram ?
  • 40 Answers
Ok here is the awnser you are looking for you acn download the service manual here.
cbtricks.com go to the radio info section go to the g section look for galaxy dx radios scroll to your radio look for service manual, schematics and download what you are looking for.
Posted on Mar 11, 2009
Where is the safety fuel shut off switch 2005 pt cruiser with 2.4 liter turbo
Doesn't have one . Looking at a wiring diagram to view fuel pump electrical circuit would show that . Do you know what automotive electrical wiring diagrams are ? Do you know how to use one along with a DMM - digital multi-meter to test electrical circuit's ? The fuel pump is controlled by the PCM - engine computer by energizing the fuel pump relay .
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model ! Under system click on engine ,then under subsystem click on fuel controls . Click the search button then the blue link. Scroll down to the fifth diagram .Fuel pump electrical circuit .
Fuel Pump Electrical Circuits Description and Operation
Jan 15, 2018 | Cars & Trucks
DC-1040 Digitech, squelch control does not squelch. Help please.
change the switch and see if the problem goes away.If not it could be one of the filters.
Jan 18, 2016 | Radio Communications
How to reset e001
An error E001 should have a detail code with it.
Detail Code 0001:
Cause
The fixing temperature has increased abnormally
  • The main thermistor (TH1) has a short circuit.
  • The fixing heater drive circuit has a fault.
  • The DC controller PCB has a fault
  • The image processor PCB has a fault.
Description
The output of the main thermistor has exceeded 220 C.
Detail Code 0002:
Cause
The sub thermistor has detected overheating.
Description
The output of the sub thermistor has exceeded 235 C.
Detail Code 0003:
Cause
The sub thermistor has an open circuit
  • The sub thermistor has an open circuit.
  • The SSR has a fault.
  • The DC controller PCB has a fault.
Description
I would suggest calling the copier repair personal.
Feb 21, 2014 | Canon imageRUNNER 400S Copier
Wireing
I would buy a Haynes manual. They have detailed diagrams descriptions to help you along. Just by looking at a video of cables doesn't really help us to help you solve your problem. However you can follow the Haynes manual circuit diagrams and compare it to your bikes and change cables if they seemed weathered, damaged or just incorrect!
Feb 16, 2013 | Motorcycles
Pls can i get circuit diagram and description about Mifi...?
Electronics engineer student that can't spell Engineer??? I feel sorry for you man! Also, you wrote "Pls" for Please .....are you a lazy student?
Stop using shortcuts if you intend to be an engineer, and be methodical with your writing as well as your work.
Jul 12, 2012 | Novatel MiFi 2200 Mobile WiFi Hotspot...
Squelch control of ic-2000 does not function
In what way. Does it never receive? If that's the case, chances are the CTCSS (Tone Squelch) is on. If it never mutes the speaker, the squelch circuit may be defective.
Jan 11, 2011 | Kenwood Radio Communications
Scanner acts like it doent have squelch control
If your scanner is open squelched on one channel, try blocking that channel out. Some times a channel can get jammed if someone has a mic cue button stuck or something similar.
Try locking out that particular channel and see if you get your squelch control back.
Apr 07, 2010 | Radio Shack Pro-2052 Scanner
Pro 95 scanner squelch does not silence receiver regardless of knob position,subsequently receiver will not scan.
Your squelch control may be back or your control needs to be aligned properly on the circuit board. Ship it in for repair if you wish. dodgem250.com
Mar 31, 2010 | Radio Shack Pro-95 Handheld Scanner
Scanner wont scan
provided you turned the squelch know and it didnt help, i would trace back from the squelch control to the first and second transistor you come to and that should be the squelch circuit. if you know how to check them with an ohm meter you can find out which one it is, if not you can just replace them both for under 5 bucks.
Oct 02, 2008 | Uniden BC278CLT Base Scanner
Squelch control on Galaxy DX-2547
You may have a bad transistor or detector diode that feeds the squelch circuit.If you can read a volt meter and Ohm Meter, and can solder ( Make your own repairs ) you may want to call Galaxy as the Techs there are normally very helpful.
Good Luck
Ed
NC Electronic
Mills, Wyoming
Nov 20, 2007 | Galaxy Radios DX-2547 40-Channels Base CB...
Galaxy Radios DX-2547 40-Channels Base CB Radio Logo
238 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
