Question about Panasonic PT-F200NTU Projector
Bleached out Image with Laptop Sources
I've a panasonic PT-F200NTEa that has a what looks like a bleached out image, but only when a Laptop is connected. You can see the image for the most part but if you use Excel you can really see the higher contrast. The grid lines are barely visible. I also have a PC in the room hooked up to the same projector and the image is fine. I've tried swapping the inputs but the same problem with both so can't be the inputs. I've also changed cables with the one used for the PC. Still same result. All settings on the projector are fine and are set to similar rooms.
3 Suggested Answers
  • 17 Answers
SOURCE: Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Posted on Jul 17, 2008
  • 25 Answers
SOURCE: have panasonic pt l701u projector using RCA input
Pleeaes connect Rca cable in Yellow port for video and white port for audio.
Also check input settings in projector Menu. it should be "video".
For your ref, diagram is below
Posted on Mar 26, 2010
My Panasonic PT LC76U has horizontal pixelated lines. See image at this link
you need to check:
the Vga cables if the image shown is that from a computer
firstly check if the Panasonic logo comes ok in the beginning
if ok then try connecting a laptop directly thru a short patch cable to the computer port of the projector[i am assuming that the projector has been installed to the ceiling]
if this works ok , then the projector is fine!
you need to figure out the problem with the vga cabling and switchers if any of them are used!
Dec 30, 2012 | Panasonic PT-AE900U Multimedia Projector
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar.
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
PT L711U + all my black colors are blue
Your projector needs to be aligned and serviced, normal occurrence
after 6 years since service.
Apr 18, 2009 | Panasonic PT L711U Multimedia Projector
3D image on panasonic 53''
Sounds like the red and green images have shifted.
In your settings menu there should be an option for it to self adjust or manual adjust of the red and green images alignment.
Apr 02, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Double image the second showing in red PT 53TW53G
replace the convergence ic's or look for loose connections that should do the job
Dec 16, 2008 | Panasonic PT-53TW53 53" Rear Projection...
**L@@K** How To Connect Laptop To Projector To Receiver!! HELP!!!
"the PT-AE900U supports a full range of input sources, including DVD and video players, PCs and game machines. An HDMI input provides compatibility with HD digital sources, while component video input terminals deliver full-quality, detailed images from high-end, progressive-scan DVD players. The PC IN terminal can be connected to a game machine or PC. Other terminals include composite and S-video, as well as a serial terminal for connecting a touch panel controller or similar device." You can go to Dell support to either read your manual, but your laptop model's manual is there for the reading. It lists all the outputs. if you have a problem figuring which to use, they will tell you. your manual can be found at
You may either have to connect the laptop directly to the Panasonic, or you may be able to connect it through the Harmon Kardon, but I doubt if there will be any advantage to doing that.
Mar 14, 2008 | Dell Inspiron E1705 Notebook
Please Help... Strange blue reflection across screen (See image)
Convergence ICs are bad and posibably th eresistors that power them. Its an easy fix if you can solder
Feb 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Pt-53tw53g March 2004
Dec 14, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-F200NTU Projector Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
