Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Philips 37PF7320A/37 - no picture and no sound. blinks red 1-4
I have a Philips LCD TV 37PF7320A/37 - No picture and no sound.
It clicks than blinks green once, then red once, then four more times red. What error code is it? Power supply? Seems to be a common issue with this set. Fuses on power supply board are ok. I need a service manual and a diagrams... and help of course...
  • 18 more comments
  • s22nik Mar 03, 2009
    all caps seems fine
    anyone has service manual? what caps usually go bad on these?
    2315, 2316, 2320, 2321 look tiny bit raised on top, to the point that could be mistaken, their legs seems to be soldered good, otherones are rubycon and look good. buying a board is not fun. I just recaped mobo on dell sx270 - that was fun.
    one link to service manual didn't work other one is a user manual - i need service one with diagrams. earthing from board to chassis ok.
    i need more guidance folks
    i want a pdf manual not a hard copy. and how do i fix that power supply
    "these compononts are de ffectove and needs to be relpace; Q502, IC601, IC 1506, C612, T504. or replace the whloe G-board "
    what is the g-board and where are these components - why all of these? i have ordered a service manual hard copy but i need a pdf
    how should i check on the power board other than visually?
    some say it's the power supply some say not it is something else that is too hard to fix... come on... what do i check the capacitance with?
    thank you for your link. the "small fee" for PDFs there is not that small - paper one is $7. on my previous issue an expert emailed me all manuals and guided me step by step till convergence ic's were replaced along with dosen res and calibrated - that is what i called help... thank you for your attitude.
    $68 for PDF manual ?!
    can someone guide me through this tv set?
    no, i have BL2.3U AA chassis, my power supply looks like this
    Jaime867 is the expert who guided me through my Toshiba RPTV convergence issue
    i need to get a capacitor tester. these are rubycons, arent they the good brand? Is it worth replacing them with polimer caps since this is the common issue and they always blow...? is there a value change with those?
    what is NVRAM?
    by the way thanx for all your time here... we-re not done yet )
    what is scaler board?
    cheap to fix> which cap tester are you talking about? there are few...
    what is NVRAM?
  • s22nik Mar 05, 2009
    i have mixed info on what the error code mean if it mean anything? some say it's the audio... changing caps on p.s....
  • 1,800 Answers
Ignition board gone faulty.
replace it.
Posted on Mar 05, 2009
  • Philips Master
  • 19,396 Answers
NVRAM is non volatile ram, NVRAM is an eeprom chip installed on digital board that contains all basic data needed to start up your TV.
If you have 4 blinks the problem should not be power board.
Unless you find a defective capacitor, replacing caps on power board may not be necessary.
On the Service manual is illustrated the service mode procedure, in there you find a factory reset procedure, that will reset nvram.
If reset does not fix the problem, then you need to test voltages from nvram chip, one of the pins is diag, and must test +5V to ensure nvram is OK.
Posted on Mar 03, 2009
    Sergeant:
    Novelist:
  • 277 Answers
On the sides of the capacitors its values are correctly mentioned .you just adjust the multimeter on that mode and check out the capacitors which looks little bit bulged up or look loose on the board as little bit reading up or down from its mentioned value has to be replaced.also many a times some capacitor looks fine but internally they go short which liile bit seems like got leaked from its top or goes burnt with blackness got collected on its top.and also if you keep the pcb board connected to the tv and on the tv for a minute and shut down the tv then the faulty capacitos gets overheated which can be checked by touching it onits top with a fdinger tip for a second.as it will be too hot so be carefull.unplug the tv from main power outlet before touching any internal part.
    Genius:
  • 1,550 Answers
The 4 flash code(red light) indicates a problem with the 5v supply. The 1 flash (green light ) indicates the X-ray protection and/or the Vertical protection has been activated.
These sets are assembled using the wave soldering process they are known for having cold solder connections.
Over time the capacitors will change value, leak and become defective. Resistors will change value and burn. This will cause other components to become defective. This can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. For a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment.
You can get service manual from the link below and check for defective parts .
Service manual for philips
If you take to service center they will charge you $400-500 for repairing .
Hope this helps .
  • SAM ANDERSON Mar 03, 2009
    The above link is not opening
    Correct link
    Sorry for the above two links
    copy paste the link below in your address bar .
    https://www.completeservicemanuals.com/p...
    The service manual costs $7.99
  • 10,594 Answers
Ok,
Service manual in PDF file format is available in Manual Zone for small fee.
  • 5 more comments
  • Shahid Electronics
    Shahid Electronics Mar 03, 2009
    Very nice!
    I gave you service manual link and you rejected it without any reason or comments.
    good luck.
    Does your TV inside look like as shown in below image...
    OK, there are 4 black heat sink at right side of your posted power supply image, you should replace all 7 caps near to black heat sinks.
    Use same value and voltage ratings for caps replacement.
    You said 4 blinks of red light as error code. Below is table of error code and 4 blinks shows NVRAM error.
    NVRAM = Non-Volatile Random Access Memory
    Shahid Electronics Mar 05, 2009
    Related service manual will give you details of all error codes. You already have website link to buy service manual.
  • Philips Master
  • 13,433 Answers
Hey,
theres a service manual available for you
https://www.manualsparadise.com/MainSearch.do?brand=269&model=37PF7320A%2F37&elementChanged=Find
I beleave this is pdf format but im sorry its not free. I don't own this manual.
The service manual generally includes a list of error codes and their reasons behind them. But imafraid that some service manuals don't provide any support, some provide only diagrams etc. Hopefully the above will have all you need to solve the problem.
    Master:
  • 404 Answers
These compononts are de ffectove and needs to be relpace; Q502, IC601, IC 1506, C612, T504. or replace the whloe G-board
  • 2 more comments
  • lotfi bouakaz
    lotfi bouakaz Mar 03, 2009
    it isn't the power supply, those numbers are for the capacitors in your TV its also to do with the BULB this is far far hard for you to fix unless you have a capacitor tester and see which ones are deffective (if they read less uf then what they should) "without power connected, you can kill yourself)
    usualy you can see the brown spill out "when they explode" but they can also be damaged without any outside damage.
    I wouldn't try to fix it myself, you need various parts to test with to find out exactly which one is deffectibe like a tv repair shop has.
    but this is common and its quite expensive to repair I think they charge $600 for something like this, or if you have warranty then great!
  • lotfi bouakaz
    you need a capacitor tester to check all capacitors have the right uf amount (expensive device anyway)
    a voltmeter can help you define if power is going to chips, resistors circuits ect...
    also check if cables are not cut using a multimeter.
  • lotfi bouakaz
    there is a cap testor on ebay for like $20 its the cheapest and it works for me. maximum uf is 2000 uf and 2000 pf so makesure your caps are not more than that and this will tell you if your caps are gone or not, there's no point replacing them if nothing is wrong with them. if they read under what their capacity then they're faulty.
    but i am pretty sure its not power its bulb and scaler board
  • lotfi bouakaz
    lotfi bouakaz Mar 05, 2009
    remind me again the red light is on the actual screen or just on the small led bulb? you mean the whole screen flashes red? there's too much writing
    capacitor tester looks like a multimeter, it's digital and it costs less than $30
    Novelist:
  • 149 Answers
Here is the service manual for you television. It will only cost about $8 but is well worth it instead of buying a new television. From the way it sounds you could be very correct it does soound like a power supply issue.
https://www.completeservicemanuals.com/philips/magnavox/lcd-television/37pf7320a/37-service-manual/prod_683.html
    Genius:
  • 1,913 Answers
Check your main power supply and voltagea reproeprly.also check earthing wotrking fine.
http://www.devicemanuals.com/guide/Television/Philips/Philips-LCD-flat-TV-37PF7320A-37-User's-Guide-TWprd016RT.html
downoad maual from here.
  • 495 Answers
    Brigadier General:
  • 8,619 Answers
Hi!
First change the power socket and use a grounded supply. This due to short inside your tv circuit board. Also check for any swollen capacitors.
  • Rylee Smith
    Rylee Smith Mar 03, 2009
    The issue you are facing is due to faulty capacitors on power supply circuit of your philips tv.
    Please ask for further clarifications.
    ThanksRylee
  • Rylee Smith
    You can check out for the 4 capacitors, are they burnt? Are the capacitors loosely soldered on the power supply board. You can look and can buy the power supply for your Philips 37PF7320A/37---
    Philips Power supply board
    You can also download the service manual from this link----
    Philips Service manual
Philip tv no picture no sound
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 30, 2011 | Philips 52PFL7422D/37 TV
Philips tv model number 50PFP5332D 37 wont power up
JUST A SUGGESTION..
Oct 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
Screen goes black but still sound
JUST A SUGGESTION..
Oct 23, 2011 | Philips 37PF7320A 37 in. HD-Ready LCD...
No picture or sound just six red blinking lights
Use your warranty in a hurry before it expires. Your TV when into protection mode to prevent further damage. Most TVs have a 1 year warranty. Good Luck.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blinking Red Lights
Sound like an error code 14 (Audio supply) is beeing blinked...
You probably would want a qualified technician to take a look at it.
Jan 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37' lcd tv 37mf231d/37
It is the low voltage power supply. I just had my set repaired and it had the same symptoms. My set is out of warranty. The repair cost is around $200.00.
May 19, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37pf7320a/37 picture issues.
The problem is the small signal board that is the video processor.
Mar 27, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Red light flashing
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that would help a lot, I can send it to anyone who wants it via email/gmail. Let me know if anyone want one.
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Nov 27, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
519 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
