Question about Singer 132QRFB Mechanical Sewing Machine
I have a singer machine model no 4830C, can u explain to me how to do buttonholes, do i need to make the holes first or how it has to be done.
If you can't get the hank of using that buttonhole foot and attachment, go to your stitch length dail turn dail to red #1 this will make the right side of your buttonhole(the length) If you move the dail following number sequin 2-4 this will give you beautiful buttonhole without using that attachment. Remember that you don't move your fabric let the machine do its job, just check to make sure that it is lined up . Practice very easy. I use this machine for anything I sew. Love it.
Posted on Dec 19, 2013
  • Gail Lewis
    Gail Lewis Dec 19, 2013
helale
SOURCE: One step button Hole V for Singer Sewing Machine
Hi, I had the same problem, but I finally found my manual. The solution is that you have to use the presser foot for buttonholes but the most important part is that you have to lower the buttonholer lever. It is located right next to the needle to the left. It is a metal lever with a little square white plastic end. You need to pull that down in order the the buttonhole feature to work. My button was too big for the buttonhole presser foot, so I had to use the regular presser foot, but hit the buttonhole lever with my had to make it go up or down.
Posted on Oct 28, 2008
SOURCE: Buttonhole instructions needed for Singer 7422 Advance
Hi Amanda, if you look up behind the presser foot, there is a white tab. pull it down. It's for buttonhole. The tab can be tapped as you sew to change the direction of the stitching. I am still trying to get the hang of it. When I start to sew I tap it back, when I reached the length I wanted I tapped it forward. It will take some practice. Good Luck. Lindy
Posted on Jan 03, 2009
  • 23 Answers
SOURCE: Button hole maker on Singer Quantum Futura CE-200
Try to adjust the stich width on the machine maybe it can help
Posted on Mar 31, 2009
  • 323 Answers
SOURCE: one step button hole instructions Singer model 3827
Insert the button into the special button hole foot. put the foot on the machine.Pull down the button hole lever( It's near the presser foot lever towards the back of the machine). Place your needle where you want the button hole to be. Select the button hole pattern and press on the pedal. Watch for the end of the button hole.
sewman7
Posted on May 16, 2009
  • 139 Answers
SOURCE: have a Singer 4830c sewing
This machine uses a Singer Class 66 plastic bobbin.
Posted on Sep 29, 2010
Instructions for making a buttonhole
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
How to Use an Automatic Buttonhole Foot
Sew Buttonhole in 4 Steps on your Singer Sewing Machine
Sewing Buttonholes Without Buttonhole Foot
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith
How to sew buttonhole with an old machine
How to Sew Button hole tutorial
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Be sure there is a stabilizer between the fabric where the buttonhole is located so the fabric will not stretch or tear.
Jan 09, 2017 | Sewing Machines
Need instructions for Singer buttonhole attachment 103233.
I found a manual for several Singer Buttonholers here: http://ismacs.net/singer_sewing_machine_company/manuals/singer-sewing-machine-manuals.html . I'm not sure of the part number for the Professional Buttonholer Model, which looks like the one for my Singer Touch & Sew. Mine is part #161829 (if I read the box correctly).
I hope these help.
Feb 06, 2016 | Singer Sewing Machines
For the Singer Advanced 7422 machine. I put on
have you got a buttonhole lever on the sewing machine that has to be pulled down first before starting the buttonhole?
Aug 29, 2013 | Singer 5050 Mechanical Sewing Machine
Just purchased a Singer 4423 machine, need more detailed instructions for buttonholes
when you press the button hole option & then pull the button hole lever
down it will rest against the button hole foot, having the button in the
button hole foot help the machine gage the size the button hole needs
to be, if the machine keeps on sewing & doesn't stop automaticily then
there is something wrong with the button hole option.
Jul 18, 2012 | Singer 4423 Sewing Machine
I have a singer 4830C. Is it possible to lower the
No, but it does come with a cover for them so you may do free-motion sewing.
Sep 19, 2009 | Singer Sewing Machines
Can't adjust button hole width
Only the stitch length is adjustable in Buttonhole mode on that model.
Jan 02, 2009 | SINGER 7470 Sewing Machine
These are the exact instructions from the Manual. 1. Select one of buttonhole patterns.
2. Replace the presser foot with the buttonhole foot. (Install presser foot with little red mark towards the front)
3. Insert the button into the buttonhole foot. (the part located in the back crescent shaped)
4. Lower the buttonhole lever (to the left of the needle) so that it drops down vertically between the stoppers A and B.
5. Carefully mark the position of buttonhole on your garment.
6. Place the fabric under the foot. Pull out the bobbin thread underneath the fabric to a length of about 4 inches to the rear.
7. Align the buttonhole mark on the fabric with the mark on the buttonhole foot, and then lower the buttonhole foot.
8. While holding the top thread, start the machine.
*Sewing will be completed automatically.
9. When sewing is finished, use a buttonhole opener to open up the frabric in the center of the buttonhole. Be careful not to cut anyt of the seam thread.
I hope this helps.
Mar 28, 2008 | Singer 7422
Singer 132QRFB Mechanical Sewing Machine Logo
246 people viewed this question
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
