Question about Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case
I show the Ex. HD, But I can't show data
When i connect the external hard disk to the computer i can see its icon on the hard disk, but i can't show any data and give me " H: is not accessible.
when i make right clik to see its properties, it give me "used space 0 bytes and "free space" 0 bytes.
Thank you in avance for your help,
Amira
  • 702 Answers
Are you sure the disk is formatted?
If not, then partition and format it. If it is, the MBR (master boot record) could be corrupt.
Have a look at external hard disk troubleshooting.
Posted on Mar 03, 2009
Coolmax HD-360B-U2 USB 2.0 External hard drive shows up on computer but I can't see anything that is saved on it. computer shows that there is data being used on device but when I open it, it says the...
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
Feb 16, 2014 | Coolmax HD-360B-U2 USB 2.0 External Drive...
I have an 500GB toshiba external hardrive,it still has 50G more space left..however when i tried to open it again..it wont open...it only shows the properties and said that windows cannot correct the bad...
There is no way to fix a bad sector. A bad sector is like a scratch on a cd that can't be fixed. You should run a program like "HD Tune", when you use a program what it does is it will read the disk and when it can't read a certain spot it marks it as a bad sector. After that the hard drive will move the data from the bad sector to a spare area of the hard drive. The spare area will store the data from a bad sector and will be usable like the old one. However if you get too many bad sectors you will run out of spares. When that happens your drive will crash.
You Can Try These Steps: Windows comes with a built-in hard disk utility software that scans your hard disk for errors and attempts to fix them.
  1. On My Computer, select the disk drive that you want to diagnose and repair.
  2. Right click on it and select Properties
  3. Go to Tools tab.
  4. Click on the "Check Now" button under "Error Checking Status".
  5. Depending up on your choice, choose either "Automatically fix file system errors" or "Scan for and Attempt Recovery of Bad Sectors."
  6. Then click on Start.
Jul 10, 2011 | Toshiba 640GB USB 20 Portable External...
I can't get the computer to find the hard drive. Turn on hard drive in makes a ticking noise sounds like something is spinning. Then it stops and nothig ever happens. HD Extreme HD2-U2 How can I...
This hard drive is faulty. The ticking sound is the read/write head banging back and forth - known as the click of death.
There are companies that can recover data from hard disks BUT it will cost you an arm and a leg for their services.
May 11, 2011 | Alpha Digital 1 Bay HD2-U2 (hd2u2) USB 2.0...
This was bought from a friend who no longer has the manual and I am still not quite sure what it is or what it does.
This is a case for 3.5" HDD that make any 3.5" HDD become external Drive. Here's the product description from Amazon :
The CoolMax HD-360-U2 USB 2.0 3.5" External Hard Drive Enclosure is portable size and excellent quality. The 3.5-inch hard drive aluminum external enclosure is specially designed for high capacity hard drives. And its aluminum material design is great for heat dissipation, so you don't need to worry about your hard drive overheating anymore. The HD-360-U2 Series gives you the freedom to work anywhere, no matter if you're in the office, at home or on the plane. This portable 3.5" HDD external enclosure provides maximum durability, flexibility and portability with various interfaces. Once you download your information to the HD-360-U2 series, you can connect it to any system and gain access to your programs and data files anywhere. With built-in hot swap technology, you can connect and disconnect the drive any time.
Features
  • Supports high speed data transfer rates up to 480/400 Mbps
  • Fully compatible with 3.5" IDE 133 HDD
  • Soft-start for slow turn-on feature prevents high inrush currents when initially powering capacitate loads
  • Anti-shock design, protect the hard disk from damage when moving it
  • Insulating designed PCB
  • Aluminum case transmits the heat quickly
  • Powered by a DC 12V-2.0 A transformer
You can visit the website : http://www.coolmaxusa.com/extenclosure.asp?item=3.5 for more details
Feb 07, 2011 | Coolmax HD-360B-U2 USB 2.0 External Drive...
How do I delete all the info backed up on my irocks external hard drive?
Usually hard drive disks are erasable so long as was an an empty space. However, the type of setting chosen during data encription causes the situation of erasability. For example, using an external harddrive disk as back up media storage media has specific requirements. The computer provides an integral means of least being compromised where data permanent encription may have been the options available during backup copying. The compoter provides the procedures of recording data into any connected external devices. Once the external device is reconnected to the computer, the options of requesting the user to either erase what has already been copied becomes one of the several displayable promps. Also, backup disks usually on connection to the computer assumes a necessity to restore to functioning mode. However, a least malfunctioning computer would simply display prompts asking the computer user to perform the most recent backup, or disregard because of least disfunction recognised from the system. Attempting is erase what has already been recorded becomes appropiate whenever the computer recognises any curroption of the files. A prompt is display asking to fix errors soon after connection. The computer user simple chooses to restore to default functionality the external hardrive. Amongs the options usually provided of the program prompt are format, delete, restore, or backup computer files once connection is recognised. keep in mind that, an external hard disk may be default rrecordable proving no options of erasing. Refer to the hard disk drive user guide as reference to achieve the process. Also, the user guide would have specified if the device is capable of alternations or not.
Jan 14, 2011 | i-rocks External Hard Drive Enclosure -...
My external hard disc moder no : TS80GSJ25S shows there is no disc in your drive
If you have used this drive before then the drive is malfunctioning and my need to be formatted. If not, then the disk could need initializing and then formatting. You can check the status of the disk using the windows disk management utility. The directions to use this utility are shown below, If the disk does not appear in the manage disks section, check the connection to the computer, and try to power cycle the drive by unplugging it, waiting for about 20 seconds and then plugging it back in. This may renew the connection and restart the drive.
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments. Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives
Jan 09, 2011 | Transcend StoreJet USB 2.0 External Drive...
My Mad Dog external hard drive does not show up as a drive. How do I get this to show so I can access my information.
Connect it to a different computer, to see if the device is working at all.
If not, and if the Mad Dog is still under warranty, then exercise the warranty to get it repaired/replaced.
Otherwise, disassemble the casing, remove the disk-drive,
and connect the disk-drive as a "slave" disk-drive in a desktop computer, to see if the disk-drive is OK. This would imply that the USB-to-disk-drive interface inside the casing is the problem.
Aug 18, 2010 | Mad Dog Multimedia MegaVault USB 2.0...
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
I have WD 160GB external hard drive. when i plug in to the computer.it shows on the taskbar as USB storage device but without an assined letter . on my computer window shows nothing about the external hard...
Attach your external HD with some other computer, that will definitely appear normal, the problem is due to a virus in ur HD. Your computer's antivirus software stops it to appear. Back up your data on the other computer, format ur external HD, remove un-necessary files and run a virus scan to the files u copied from HD, Hope this will solve the problem, if not, let me know and tell me what would be the response on the other compuer
Sep 20, 2009 | Western Digital 160GB 7200RPM HDD WD1600BB...
Reduced Hard Drive Capacity with Internal to External Kit
Problem can be tricky.. though i offer my two cents.
1. some BIOS have upper limit of hard disk capacity. check that out. try connecting IDE device to IDE connector in same comp and see if it is being detected properly.
2. seagate guys are true .. IDE to usb conversion can be tricky ... a lot depends on card convertor.
my advice would be if you have precious data on it ... first take a backup of it, if possible connecting the disk to nomal ide connector.
Aug 06, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case Logo
247 people viewed this question
Top Vantec Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
