Question about Whirlpool AWM8123 Front Load Washer
Whirlpool washing machine awm 8123/1 stopped during wash
FH flashing up on screen water still in bottom of machine
SOURCE: Whirlpool AWM 8123/S washing machine has died.
It turned out to be nothing more than one of the spade connectors shaken loose. Even I could handle that!
Cheers anyway,
Mxxx
Posted on Sep 02, 2009
  • 3 Answers
SOURCE: my AWM 3000/5 whirlpool washing machine is leaking
check and see if the tub has a crack in it
Posted on Apr 23, 2009
SOURCE: whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
Posted on Jun 02, 2009
Krazytech
  • 725 Answers
SOURCE: washing machine whirlpool awm8123/1 stopped and FH on display
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR If the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. Press PAUSE/CANCEL twice to clear the display.
check the fill hose screens or you my have to repalce water valve make sure water is turned on....
Posted on Sep 19, 2009
SOURCE: Front loader washing machine AWM 6100 Whirlpool
check brushes on motor. how old is machine?
Posted on Feb 01, 2010
How do I fix a whirlpool washing machine with the 'door locked' light blinking?
The door lock needs to be replaced. I would recommend using a technician to replace the part just to be on he safe side.
Sep 28, 2015 | Whirlpool Washing Machines
Hello, I have an whirlpool machine AWM 6105 and this morning when I started the washing program it gave me FH error. I stop it and start again and it worked. what thoes this error means? can you give...
'FH' for Whirlpool decodes as 'no water fill'. Providing that the taps are fully on, the hoses are not kinked or squashed, I suspect this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Also do you need a manual? I have to assume that most manuals have the decodes in them.
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 28, 2011 | Whirlpool Washing Machines
Whirlpool AWM 045-1000 washing machine has suddenly stopped working and warning light "WATER STOP" has come on. Any ideas for a fix?
Sep 19, 2009 | Whirlpool Washing Machines
Washing machine whirlpool awm8123/1 stopped and FH on display
Sep 19, 2009 | Whirlpool AWM8123 Front Load Washer
Cheers anyway,
Mxxx
Aug 27, 2009 | Whirlpool AWM8163 Front Load Washer
Whirlpool awm 8125/3 fault code FH
Feb 07, 2009 | Whirlpool AWM8123 Front Load Washer
We have a whirlpool 6th Sense AWM 6145/3 which has just started stopping during the wash cycle and on the digital display the letters F H come up. We rent our property and have moved several times and have...
FH is the code for no water flowing in...
is there water flowing in?
if there is none, the water solenoid is the problem,
if there is water going in, then the flow switch is the problem.
here is the transcript from the web..
FH ERROR CODE
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves
Or
detected 48liters of water passing through it, but has not detected the pressure switch
and here is their solution
water source opened
flowmeter
pressoswitch
wiring to valves, pump,
flowmeter, pressoswitch
hoses
either one of those parts...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Whirlpool Washing Machines
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
Whirlpool AWM8123 Front Load Washer Logo
494 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
