Question about Sony TA-N9000ES 5-Channel Amplifier
The word protect keeps coming up on the screen
  • jason May 11, 2010
    have you looked for crossed wires on the speaker connections ? also when did it start hapening ?
  • 2,335 Answers
This most likely is referring to a protection fault - ie a short circuit. Usually in the speaker wiring, it can also occur inside the unit.
Posted on Apr 02, 2010
KDC-MP2032. Why is PROTECT being displayed?
Look to the right of the SRC button in the corner, and you'll see a small button that you can press with a pen tip or paper clip. This is the reset button, and pressing it will turn off the protect mode. If it keeps coming back, there may be a wiring problem, or the head unit may be defective.
http://manual.kenwood.com/files/B64-3290-10_En.pdf
Jul 13, 2015 | Car Audio & Video
I cant take pictures write protect keeps coming up on screen
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 06, 2014 | GE X5 Digital Camera
The green light keeps blinking on my WD 52725
Install The C26 DM and V26 Power repair kits available from www.tvrepairworld.com the kits contain the replacement capacitors and the CD with detailed repair instructions.
Dec 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Flashing protect
the protector comes on to keep the amp from further damaging itself or the speakers. The buzz you heard was probably 60HZ line buzz from the main DC supply conducting full current through one of your speakers through a damaged amplifier transistor. Your stereo will need professional repair. The protect circuit basically opens the speaker relay (and sometimes shuts down the unit) to prevent this DC voltage and current from getting to your speakers until the problem is corrected.
Jun 17, 2009 | Onkyo TX-SV727 Receiver
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
Protect keeps displaying
you will have to disconnect power and reconnect it
May 08, 2009 | Car Audio & Video
Screen saver keeps poping up if i stop typing and i have 2 keep unlocking screen everytime i get back on computer and also slide show comes up when its sitting 4 awhile
xp:
1. right click on unused space on your desktop and click properties to bring the display properties, (you can also go into start>control panel and double click on display)
2.then go to the screen saver tab and click on it
3. modify the time for screen saver to come up and uncheck the box that says "on resume password protect" so you're not asked for a password everytime your screen saver is on and you're returning to work on your computer.
vista:
it's a bit different than xp but similiar in some sense..
when you right click on the desktop go to "Personalize" to bring the display properties and then go to screen saver and modify the wait time and password protected settings.
hope that helps!!
post back if you have any problems
Dec 13, 2008 | Gateway Computers & Internet
SD PROTECTED keeps on screen. Can't use an SD card. How do I take the SD protection off ? Thanks, Bill
just check your sd card lock key... there is a small swith on the left side of moemory card; if if it is in down position, it's protected. so turn it to un protected mode. I hope this helps...
Oct 31, 2008 | Cameras
It keeps restarting on me
Without more details I'm going to make a guess on this. It sounds like you have the HP Protect tools installed. If you do have the HP Protect tools installed and that was the password prompt from HP Protect tools giving you problems, your best solution may be to do a hard reset. I had problems with the **** HP Protect tools and had to hard reset to remove it. NOTE that a hard reset will also clear all the files and data on your pda
Dec 12, 2007 | HP iPAQ hw6515 Pocket PC
57S715 Hitachi HD RPTV protective screen removal & cleaning help.
Research at www.HitachiServiceUSA.com ...........
Generally, front speaker grill cover comes off , then
screen frame assy. off , then take apart, remove protect
glare screen. Reassemble ( keep same order - position )....T.
Please rate solution to problem........
Aug 21, 2007 | Hitachi 57S715 57" Rear Projection HDTV
Sony TA-N9000ES 5-Channel Amplifier Logo
160 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
