Question about Intel D102GGC2 Motherboard
I have intel 945GCCR motherboard which is giving me ''FF code error'' and does't give the beep after processing the processor eventhough processor is heating, could plz solve this problem? frazonline@gmail.com
  • sharan.n72@g May 11, 2010
    ucan start than motherboard heating than restart com.
    after 10 minut thna restart..
    Sergeant:
    Champion:
  • 315 Answers
Few things to try... unplug all hardware that you dont need and clear the CMOS on your motherboard. Then go from there..
If the problem persists, chances are you have a fried motherboard.
Posted on Mar 03, 2009
Product Name : Intel Motherboard Dg31gl Type : Mother Board Problem : 3 beeps continously then space then sham four then space again space again its repeating d same give me any solution
Replace the processor. The 3 beeps means its the processor at fault..
continuous beeps with space in between means its the rams.. No beeps at all means its the clock speed.
from what your saying it sounds like the processor.
Dec 28, 2012 | Computers & Internet
Intel845 mb 3ghz processor no beep for ram no display motherboard restarting b4 it was giving display ok but when i tried to install antivirus it stuck n when i tried restarting theirs no display n when i...
Just check the motherboard manual because I think you just got problem in hardware compatibility.Remember if your processor and memory are not compatible the first thing that might happen is your process will be damage. But since you it start only when you install antivirus, you have to reformat your disk, to solved the problem.
May 02, 2011 | Intel D845GBV (BOXD845GBVL) Motherboard
My board does not turn on and its beeping. Ive counted 7 beeps. i tried replacing the memory with known good ones but still the beeping persist.
MSI states that 7 beeps means "Virtual mode exception error "
Explanation: Virtual mode is one of the different modes that the processor can run in. The system is reporting an error when testing this mode.
Diagnosis: There is a problem related to the processor or motherboard. Note that this doesn't mean that the processor is necessarily dead, since the system won't boot at all with a dead processor.
Not knowing the price of either your processor or the board it is hard to say what to do for the best
Good luck
AMI Beep Code Deep Code Description 1 short DRAMS refresh failure 2 short Parity circuit failure 3 short Base 64k RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed AWARD Beep Code Deep Code Description 1 Long, 2 Short A video error has occurred and the BIOS cannot intialize the video screen to display any additional information
Jun 19, 2010 | MSI K9N6PGM2-V Motherboard
Error beep sound on server, conf:Intel server motherboard se7520bd2 2 gb ram scsi harddrive problum:long beep sound in LSI LOGIC CARD
I don't think SCSI card give beep error codes. If you listed this item, most likely this is the problem and your MB is telling u this. Your SCSI card is most likely damaged. Try to make sure it is inserted in the pci slot properly. If it is....buy a new one. We rarely use SCSI cards any longer as most Servers have plenty of HDD space and the Hot Swappable options make them easy to replace if they get damaged.
As a tech, I would first check the Mother Board (BIOS) Beep Error codes to determine exactly what the problem is. Those beeps tell u what hardware is malfunctioning.
Jun 06, 2009 | Intel Xeon, 3.6 GHz (bx80546kg3600ep)...
945GCCR Motherboard Problem
Dear user,
If you are clearly checked Ram and Smps so problem from mother board pl Give *********** board to Chiplevel Repairer vendor to repair your Motherboard.
Regards,
Ravindra Shah
Jun 01, 2009 | Intel D945GCCR Motherboard
MSI MS-6754 mother board won't boot and beeps when I swap processors
your motherboard has the chipset of 845GL series
so the specification of your motherboard is as follows read it carefully there may be some error in the manual or it might not be your motherboard model just have a check with that . here are the specifications as per i saw in the net ...
CPU • Support Intel® P4 (Socket 478) processor up to 2.6 GHz. Chipset • Intel® 845GL Chipset - Support FSB 400 MHz. - Integrated 3D/2D graphic core (Core frequency= 200MHz, 350MHz integrated 24-bit RAMDAC). - Support PC266/133 Technology. • Intel® ICH4 Chipset - AC'97 Controller Integrated. - 6 ports Hi-Speed USB 2.0 controller, 480Mb/sec. - Support both ACPI and legacy APM power management. - Legacy free support.
Sep 06, 2008 | Computers & Internet
Intel D865GBF motherboard in not giveing beep,display
if your motherboard does not give beep and display; remove your processor and ram and try working processor and ram on your motherboard, should there be no beep and display, your motherboard is dead.
Uzowuanya
e-mail:uzowuanya@yahoo.ca
Feb 15, 2008 | Intel D865GBF Motherboard
Service
INTEL = http://www.intel.com/
Sep 18, 2007 | Intel AOpen AX3SP-U 815EP Chipset Ultra...
Intel D102GGC2 Motherboard Logo
190 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
