Question about EPoX EP-8KRAI-X Motherboard
I have a new 8ogb sataII Exelstor hardisk which i
I have a new 8ogb sata II Exelstor hardisk which i put in my old motherboard EP-8KRAI-X. The motherboard has two sata slots. The bios did not detect any hardisk that's why I can't install my windows xp sp3. What should I do so that the bios can detect my sata II hdisk. There is no jumper in sata lI hdisk.
Thanks!
Mr. dreamboy
    Sergeant:
    Champion:
  • 315 Answers
Windows XP does -not- have native SATA support and therefore will not recognize a SATA drive without first installing 3rd party drivers.
To go around this problem without installing drivers check your BIOS. There might be something in there where the bios will emulate an IDE controller.
If not, you'll need a floppy and the sata drivers. A flash drive will also do if the motherboard bios supports legacy USB. To find the drivers, simply go to the motherboards manufacturers website.
Posted on Mar 03, 2009
  • Roger Gantner Mar 03, 2009
    Oh, and, to install the drivers, just let the computer boot the windows installation cd. Once it does that you will see it load all kinds of third part drivers etc on the bottom of that nice blue screen. There will come a point where it prompts you to press F3 or F9 or whatever to install 3rd party storage device drivers. That's what you need to do. Then once that is done the drive will show up and you can partition and format it properly.
EP-8KRAI motherboard does not see WD2500AAKX SATA HDD
check the cable
make sure the hd is getting power
try another sata connection by swapping the cable from dvd device
make sure you set the drive select some drives require it
do not use cable select
make sure the battery back up has 3 volts
you could try shorting out the bios to reset the motherboard - there should be a jumper on the board, turn power off, the jumper or connect the two pin so the short out, than turn on machine, just for few seconds and turn off, remove the jumper.
xxxxxxxxxxxxxxxxxx important xxxxxxxxxxxxxxxxxx
before or when booting the system push F10 to access bois
setup all devices, dvd, video card, if that dont work you can try F1 or F2 when you start the system
when you exit the bios make sure to save it i think F10 save and reboot. so save new changes and device ID.
Apr 16, 2015 | EPoX EP-8KRAI-X Motherboard
EP-8KRAI PRO MOTHERBOARD manuel
http://uk.asus.com/Motherboards/AMD_Socket_754/K8V_SE_Deluxe/#CPUS
Aug 16, 2012 | ASUS K8V-SE Deluxe Motherboard
Epox EP-8KRAI manual
How is your Chinese? The old employees of Epox are in China. http://www.supox.cn/pr_old.php?lm1=1
https://en.wikipedia.org/wiki/EPoX They do support the Epox boards however.
Feb 25, 2012 | EPoX EP-8KRAI-X Motherboard
No display, video card and memory is working but with no dispaly
check your computer monitor to the other desktop.. maybe that's the problem. or else flash your CMOS jumper settings. then turn it back to its original settings..
Jul 12, 2011 | EPoX EP-8KRAI-X Motherboard
SATA Hardisk canot read into bios.. the sata cable is brandnew and SATA hardisk is also new
You will need a RAID driver for your motherboard. Contact your motherboard manufacturer for assistance.
May 23, 2011 | Computers & Internet
Connection of DVD writer having SATA cable
The blue ports on this motherboard are SATA ports.
This is a SATA cable:
Mar 30, 2009 | Intel Motherboard
I need drivers to my motherboard EP 8KRAI-X
Drivers for this motherboard can be found at the following website:
http://www.epox.com/USA/downloads.asp?class=DRIVERS&item=EP-8KRAI-X
Mar 12, 2009 | EPoX EP-8KRAI-X Motherboard
Flashing Toshiba satellite 1800-S204
Hi
You query did not give any clues abt the PC/Motherboard and its BIOS revision.
That said if the PC/BIOS will not "see" the HDD then its is unlikely a cause of a virus.
Some old motherboards can't recognise a HDD if its size is more than 137GB. Some older motherboard also require than you set the HDD jumper correctly (Master or Slave).
At this stage, i am assuming the HDD in question is PATA or IDE (Old Spec). If the HDD is SATA (New Spec), then you will need a SATA port to connect the HDD. Ensure not to use both "old" molex power connector and "newer" SATA power connector together.
If the HDD is SATAII but the SATA spec for your motherboard is SATAI (initial spec), some motherboards and SATAII drives require that you jumper the HDD to allow it to work at the lower SATA speed.
If none of the above points apply try upgrading your system BIOS of the latest version. Also review the mortarboard's manual for more info.
Regards
Mike
Mar 23, 2008 | Toshiba Satellite 1805-S204 Notebook
ASUS VIA KT133
Your motherboard does NOT support SATA drives, without an added SATA controller. It does support PATA drives, such as the Samsung SP2514N and the Seagate PATA drive you listed, as well as any other PATA drive. A PATA drive may be referred to as PATA, IDE, ATA100, ATA133, or even ATA66, but not SCSI, Ultra320, U320, or SATA, SATA II, SATA100, SATA300, etc.
The Seagate drives are easy to identify, their model number ends in AS if it is a SATA drive, and just A if it is a PATA drive.
Dec 05, 2007 | ASUS VIA KT133 Chipset A7V133 Motherboard
EPoX EP-8KRAI-X Motherboard Logo
296 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Alun Cox
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
