Question about Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer
Spin cycle makes washer rattle too much
Whenever the washer ends in the spin cycle, it rattles too much to the point where the washer will move.
All the legs are balanced. It is sitting on even ground. I suspect something loose or missing in washer??
    Novelist:
  • 117 Answers
Open the door and then reach inside the washer and grab the front of the inner tub with your finger tips. Can you wiggle the inner tub inside the outer tub? If so, your spider shaft supporting the inner tub is cracked and needs replaced. It is quit a job for the average handyman. Most often the professionals mustr be brought in for this repair.
Let me know if I can help further,
Eric Campion
Posted on Mar 03, 2009
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
Fridigaire fwb9200es1 washer making rattling noise when spinning
Hello terilym - From what you have described it sounds like you possibly have foreign objects such as coins or safety pins in the tub or pump. I suggest unplugging the washer and carefully check the tub and to verify that the drum is also not damaged. If noise continues after washer is restarted, objects may be in the actual pump. Contact a professional to accurately diagnose and repair the unit.
Sep 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer makes a rattling sound when it starts the spin cycle. Sounds like gears stripping or something loose rattling around. Now it won't spin after the wash cycle. It will spin if I put it on the...
Sounds like you cannot activate youre imagination maybe Ill do this for you one time here goes ~: You or someone left coins in your pockets jeans cardigan whatever they got out of garment while in the wash spin and worked themselves into the machine and now its bug-gerred innit?
Jul 30, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Excessive spin
I had this issue when I first purchased my stackable washer.. Because it was still under warranty, I had someone check it out. Apparently when it was installed they forgot to take out the security clamp that secures the unit during delivery.. duh!!
Jul 20, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Admiral makes rattling noise during spin
Hello, could be a possible bad pump. I would lean the washer back so you can see the belt. take the belt off and spin all of the pulleys. the pump pulley has a s leave that sometimes makes a grinding noise.
Jan 05, 2009 | Admiral AAV7000A
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer Logo
206 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
