Question about LG WM1814CW Front Load Washer
LG washer won't spin
Cycle starts normally, but when it needs to spin faster, the tub doesn't move. A noise sounds like something rubbing... as if the motor is trying to spin the drum.
Diagnostic mode shows this:
-- Clock-wise tumble, low-speed spin and high-speed
spin do not work.
-- Counter-clockwise tumble works, but the machine makes
an unusual r-r-r sort of growl when it does.
-- All other cycles seem to work as normal.
Other observations:
* If I spin the drum by hand slowly it makes no noise.
* If I spin it fast I hear a "click-click" and then the electonic notification "bings" play (the four sounds that get higher in pitch, like when it starts). I'm not sure if this is a problem, although kind of interesting that it does this when unplugged.
* Nothing is blocking the drain.
* All connections and board components seem okay visually.
Could it be:
-- Broken rotor bolt?
-- Ball sensor problem?
-- Bad sensor switch?
I want to take the back bolt off to check out the rotor but am a bit worried that I won't be able to get it back together the right way.
Any advice would be appreciated!
  • slmg Mar 03, 2009
    The washer does spin sometimes but not always and makes an unusual noise when it does not spin.
  • 1294 Answers
SOURCE: LG 2277 Spinning intermittently "growling"
Followup: (of techwannabe)
After researching a bit further it was worth the investment to replace the sensor assembly and see if this would fix the issue. Viola! runs like a champ. The part was located locally for a mere $ 25.00 and with a few tools, strength of a gorilla to move the machine I repaired it. Yes a mother of four can complete the job! The unit works beautifully.........................
Posted on Jan 04, 2008
  • 351 Answers
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Posted on Mar 04, 2008
charcois
  • 763 Answers
SOURCE: Problem: LG WFT802
sir
as youve said your machine was 8 yrs old and it had a problem with the motor. i think the machine is need a replacement for doing on that long years. if you think youll going to repair with a technician it might cost you a lot of money. my advice is to buy a new one since your machince is old.
cheers
CHARCOIS
Posted on Sep 01, 2008
stuarttx
  • 15 Answers
SOURCE: LG WM12225
I have gone around and around with my LG washing machine. I have the same model and the same LE code. I have replaced the hall sensor twice. each time the problem returned about three weeks later. I have also disassembled the drain pump and housing and cleaned it all out. I'm pretty sure that the hall sensor was never bad- I think that simply unplugging and letting it sit while the parts was being shipped caused something on the main board to reset. I don't if I have some corroded contact somewhere or a stuck latching relay. I have gotten the LE code about four times now. I got it on friday again and fixed it in less than five mintues. I have no idea if this will help or not:
Unplug the unit.
Remove the four screws all the way at the top of the back of the unit.
Slide the top cover rearward about 1 inch and then lift the cover off and set it aside.
Sliding the top cover may require some effort.
Once the top is off, look for the PCB or primray control board. It is encased in an almond colored box on the inside of the back wall.
There is one plug with three wires that plugs into the board through a hole in the front cover of the PCB case. Unplug it and then plug it back in.
Once your fingers are clear, plug it in and see if it works.
Here is an additional tip: if the unit stops again with the LE code you can get the drain pump to empty the machine for you by using the quality control functions as follows.
Turn off machine completely.
Hold "soil level" and "spin speed" buttons at the same time. While holding those two buttions reach over and hit the power button (not start button).
All lights on the front should illuminate and after about five seconds the door will latch closed.
Press the "start" button eleven times. The number displayed will be the water level and the pump will pump the water out for you. BTW: 62 is empty and 27 is full (approx.)
Hope this helps.
Posted on Dec 08, 2008
SOURCE: drum does not spin
We have an LG TROMM with the same problem, 3 years old as well. We bought the extended warranty (Huge waste of $$$$).  So far they have determined it is not the motor or either of the control boards.  We think it might be a relay switch or possibly the brake.  Good luck with yours, we just went out and bought a new washer.
Posted on Jul 03, 2009
Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
I have an LG WM-0532HW Front Load Washer. upon trying to fix a diffierent problem, something popped. I couldn't find anything broken. However, the inside metallic tub is not longer stable. During the...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jun 26, 2011 | LG WM-0532HW Front Load Washer
My washer started by spining faster then normal and then it started makeing a loud knocking noise and now sounds like metal rubbing metal. Everything else works fine just can't spin anything.
SOUND LIKE INNER TUB AND BEARING AND SUPPORT SHAFT...# W10250573 $364.00 INNER TUB AND SHAFT..REAR TUB AND SEAL#8181912 $224.00 VERY TIMELY AND EXPENSIVE REPAIR CHECK WARRANTY ON WASHER
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
LG washing machine WM2277H tub off center does not spin electronically, manually its spins but rubs sides
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Sep 02, 2010 | LG WM2277H Front Load Washer
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Lg washer 2277, spin cycle
The humming noise is probably the drain pump working to remove the water out of the tub.  It is normal.
Apr 26, 2008 | LG WM-2277HW Front Load Washer
Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
Jan 15, 2007 | Crosley CAWC529JQ Top Load Washer
LG WM1814CW Front Load Washer Logo
1,400 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
