Question about Toshiba Tecra M2-S730 Notebook
Tecra M2 doesn't boot is it a processor problem?
It powers up, power on good beep,  power and battery LED turn on, HD LED flash, dvd rom seems to read (LED lights and DVD turns/runs), can choose boot selector (dvd, hd,usb etc). if you continue to boot, you'll have a flashing cursor on the top left side of the screen
can not access bios.
Could you help me isolate the problem, is it the processor or a motherboard problem?
Thanks, Dave
  • Roger Gantner May 11, 2010
    How old is the laptop?
    Problem Solver:
  • 9 Answers
Given the symptoms, it points to motherboard.. if it was processor, video or ram. it wouldnt boot at all and you'd just get error beeps from your laptop. i'd first try resetting the bios, by removing the bios battery for 30 min, then putting it back in. if that doesnt work try changing it out, usually costs under 8 bucks. if that doesnt work then I would change out the motherboard, if its cost effective.
Posted on Mar 03, 2009
    President:
  • 1,223 Answers
Pls take out any cd or dvd that is in the dvd drive and see if it helps always keep ur boot device priority to hard drive
if no help then ur OS is not loading in some cases when boot sector is damaged the OS doesnt load try factory resetting ur laptop thru backup disk if the os is loaded and it works then it is ok but if problem persists then ur hard drive is giving fault kindly replace it everything will be ok
there are 2 things that are responsible for booting process
1.RAM which infact switch on the motherboard and initiate procedure for booting process if u see any type of text or diaplay on screeen then it is working ok .
2. Hard disk , when the system powers up Ram asks hard disk for OS files to load the OS if hard disk is faulty it doesnt give up these files hence the OS doesnt load and booting process stops here it seems like u have stucked here so hard disk seems like the main culprit but pls try to reset ur OS thru backup disk here see if it works if after some time system faces same fault the replace hard drive
pls rate me fixya if i have fixed ur problem
Computer will not start
It all depends how many beeps there were.
From http://h18000.www1.hp.com/products/quickspecs/12253_div/12253_div.HTML
Diagnostic LED Explanation Table Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
I have only really come across 4 beeps = order new Power Supply or 5 Beeps = reseat the memory and hope it works
Regards,
Oli
Apr 15, 2010 | HP Compaq dc7600 Small Form Factor PC...
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
Hi I have a Toshiba Tecra M2 laptop with Windows XP Pro SP3. My CD-RW/DVD-ROM/CD-ROM drive is not working. When I try to burn a disc, it says no recorder, or no disc in drive. Also, Windows doesn't seem to...
>> it says IDE #1 error when it boots up.
IDE #0 is your disk-drive.
IDE #1 is your CD/DVD drive.
So, take your computer to a qualified technician, to first check that the connectors (power, data) from the motherboard to the CD/DVD drive are good, and then, if necessary, to remove & replace the "dead" drive.
Oct 27, 2009 | Toshiba Tecra M2 Notebook
No onboard video with my new MCP6P M2+ mainboard
Try removing the bios battery for 30 seconds then boot the pc, this will clear the bios. Maybe the bios was misconfigured. Else you can jump the "clear cmos" pins on your motherboard, same affect as removing the battery. If that doesn't work try different ram, it's possible the ram is not compatible. Sounds plausible being that there were no post beeps. Good luck.
Sep 14, 2009 | Biostar MCP6P-M2 Motherboard - v6.0,...
Will not boot up
I have seen a lot of Toshiba Laptops with bad "DC Connectors" on the motherboard. It sounds like you know what your doing so here a link on how to disassemble your laptop.http://www.irisvista.com/tech/laptops/ToshibaM2/tecra_M2_disassembly_1.htm
and here is another on how to repair the dc connector. http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
May 27, 2009 | Toshiba Tecra M2-S530 Notebook
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Jan 29, 2009 | Asrock P4i65GV Motherboard
Boot problems blank screen, no beeps
no in he power supply , but on the motherboards power regulation area,
you have to be real good at soldering 4 layer board and have the right tools . its not an easy job even if your skilled,
one bit of heat too much and you fry the board.
there are techniques to this that you can only learn by doing.
the caps are apparent if you are a tech.
the most you should attempt is to just purchase a replacement board.
I see these board available on ebay for 40.00 including shipping.
Apr 28, 2008 | HP Compaq nc6000 Notebook
Presario SR1030AN Turning on but not booting or POST or no any beep at all.
Have you tried switching the power supply out with one that is known good?
Nov 26, 2007 | ASUS A7V8X Motherboard
Toshiba tecra m2 laptop wont start..
nothing happen when you press power? and when you plug energy no led?
Aug 27, 2007 | Toshiba Tecra M214-XGA (PTM20U0776X7)...
Toshiba Tecra M2-S730 Notebook Logo
497 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
