Question about Acer Aspire One PC Notebook
No display on the monitor power light indicator is on
Aspireone
  • rojan_flames Mar 14, 2009
    my acer aspire one display is dead, even when i connect a external monitor,, it doesn't work it says no input signal, please help me.... send some of you advice at my email.. crismon_1059@ymail.com i really need your help guyz.. thankz
    Master:
  • 505 Answers
Disconnect the main power and unplug the battery. Press the power button for 5 seconds. Then again turn on the notebook by connecting the battery
Posted on Mar 03, 2009
I had the same problem but here is the fix - I contacted Acer support and they steered me to this solution you need a BIOS update. Follow the directions on this page and it will work. It says it may take 1-7 minutes, mine was up and running in just 2. You will need a flashdrive though.
http://netbooks-us.custhelp.com/app/answers/preview_detail/a_id/66
Posted on Dec 06, 2009
My laptop has no display but it has power
Posted on Dec 04, 2009
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
Sudden failure - working fine then next time switched on no apparent power (no indicator light on), no display
You could have a power supply problem in the LCD monitor.
First check the power lead, make sure it is firmly inserted into the mains socket and into the monitor.
Try inserting it into a different main socket that is operating, to see if the power indicator LED lights up.
If you have determined it is the LCD monitor is faulty, then it requires repairing.
Jan 25, 2011 | Acer AL1717 17" LCD Monitor
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
Apple Cinema HD Display 30'' black screen, power light blinking
I don't know what might have happened, but a number of years ago I had an apple monitor and the power light on it started blinking, so I got in touch with apple and they told me that it's flashing an error code, so they told me what the blinking indicated and fixed it.
So I think the blinking of the power light on your monitor could be indicating an error code so I suggest you call apple and they will identify what the error is indicating.
Feb 11, 2010 | Apple Cinema HD 30" LCD Monitor
The acer aspireone screen wont light up when i turn the computer on. the power light comes on, but nothing else happens.
The screen looks to be bad.
Usually the internal lamp burnt out.
If you need to use it, change monitor and try it.
This way you make sure that the video card is working properly.
Don't forget to rate this answer if it helps
Dec 24, 2009 | Acer 22" X223w LCD Monitor
Power light on but there is no display.
I have the same problem with my acer al1617b if you get any suggestions please let me know
thanks
Nov 11, 2009 | Gateway FPD2275W LCD Monitor
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
X2 gen 17" lcd monitor, no display
This indicates either a problem with the monitor cable(ie shorted) or the display adapter. Try plugging the monitor into a different computer and if it works you will need to install a new display adapter in your computer. If it doewn't work on the new one either you can try a different monitor cable if yours isn't permanently connected. Hope this helps
Mar 29, 2009 | X2 MG17R 17" LCD Monitor
Acer Aspire One  PC Notebook Logo
841 people viewed this question
Brian Sullivan
Brian Sullivan
