Question about Kenwood DDX7029 Car DVD Player
Connecting iPod to Kenwood DDX7029?
I have the Kenwood DDX7029 DVD/stereo in my car and in order to connect my iPod I was advise to purchase cable KCA-iP300V, which I have...however, on connecting via the USB port everything works apart from getting any sound! iPod displays that it's connected tho KENWOOD, and LCD in car has iPod soung/art work etc. Can anyone help??
Thanks in advance!
3 Suggested Answers
C13295
  • 128 Answers
SOURCE: KENWOOD KVT-729DVD & KCA-BT100 BLUETOOTH + KCA-IP300V
Try this. This is the Kenwood support. Hope this helps. :)
By Phone
(310) 639-9000
or toll free 1-800-KENWOOD (536-9663)
Posted on Jan 13, 2008
  • 4 Answers
SOURCE: Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Posted on Jul 16, 2009
I have te Kenwood DDX514. How can I get it to play music videos? thank you
Car Stereo Oxnard Kenwood DDX-418 Demo - Breakers ...
? 2:59
https://www.youtube.com/watch?v=SG6bJ6RHMgQ
May 19, 2011 - Uploaded by Josh Furagganan
But I can't get my iPod to play music on it. ... You need to havethe Kendwood iPod cable to be able to do netflix, music videos, etc. and it's only ...
How to make any video file format play on most in dash dvd ...
? 8:45
https://www.youtube.com/watch?v=8V8hyvguTw8
Dec 9, 2012 - Uploaded by richboy12
How to make any video file format play on most in dash dvd systems (Pioneers, JVC, Kenwood) .... My stereo can't read mp4 so does that mean no music video for me or are there any other ways I can watch music video in my ...
Kenwood DDX770 DVD Receiver Display and Controls ...
? 2:12
https://www.youtube.com/watch?v=IHH5Jhb6O6w
Mar 20, 2013 - Uploaded by Crutchfield
You can watch video on the Kenwood DDX771 receiver's ... Hi, I ordered ddx771 and I can't get my iPhone to play music through the usb.
Dec 16, 2015 | Kenwood DDX514 Car DVD Player
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
on Aug 09, 2011 | Apple iPod touch
I want to connect my ipod to the radio
According to Apple, over 90 percent of new cars retailed in the United States are equipped with iPod connectivity.
The iPod has become such a popular device, that many car stereos are now furnished with a 30-pin dock connector cable in order to link to the portable media player.
But this built-in compatibility is not essential for connecting your iPod to your car stereo. In fact, there are numerous options for integrating your iPod with your car.
Recently manufactured vehicles can support an iPod connection through an auxiliary input.
And FM transmitters can be used to stream your iPod's audio files through an FM frequency. iPods can even be connected to much older car stereos with the use of a tape adapter.
Connect an iPod to a Car Stereo Through the Auxiliary Input
Insert an extension cable with 3.5 mm stereo connectors on each end into the headphone output of your iPod. Insert the other end of the 3.5 mm stereo connector cable into your car stereo system's auxiliary input. Press the "Aux" button on your car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With an FM Transmitter Insert the FM transmitter into the 30-pin dock connector of your iPod. Turn on your iPod to activate the FM transmitter. Select the FM frequency you want your device to stream audio to on your car stereo. Turn on the car stereo and tune it to the same FM frequency as the FM transmitter attached to your iPod. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With a Cassette Adapter Plug the jack connector of the cassette adapter into the headphone output of your iPod. Insert the cassette into the car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod.
http://www.apple.com/ipod/car-integration/ http://www.pcmag.com/article2/0,2817,1865467,00.asp
Feb 10, 2013 | Apple iPod Audio Players & Recorders
I purchased a Kenwood KDC- MP345U and my Ipod touch version 4.0.2 used to work fine in the stereo. Now it only reads and then gives me an IPOD error. I have tried other Ipod products and they work fine. I...
i had a similar issue only mine read the song title and everything but just gave no sound. i called up kenwood and the solution for me was take the ipod (5th gen nano) turn it on, flip the hold switch on then off, then press and hold both the menu and center button of the scroll wheel until the apple logo showed up and release them. wait for it to go back to the menu and plug it in. fixed my problem. they said it was something w/ the ipod not connecting properly or something. hope this helps a bit
Oct 01, 2010 | Kenwood KDC-MP342U Car CD Player
How to I use the stock radio amp to run an ipod?
You can use any of the following methods
  1. Connecting the iPod via headphone jack
    All you need is a simple Y cable, which is available from any home-electronics store. Connect the small plug to the headphone output of your iPod--or any portable audio player. Then connect the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox.
  2. Connecting the iPod via iPod dock
    To connect using the iPod dock, you first need to purchase an iPod dock accessory. Using the same type of Y cable, connect the small plug to the matching jack on the rear of the iPod dock. Then, plug the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox. This method provides a line-level connection that maintains a volume level to your stereo system and allows the iPod to recharge.
  3. Connecting the iPod via wireless FM transmitter
    You can also connect your iPod to your stereo wirelessly. You'll need to purchase a compatible wireless FM transmitter--there are several available--and connect it your iPod. Once your transmitter is connected, simply tune any nearby radio to the correct frequency, and you'll be listening to your own iPod-powered mini radio station.
Thanks for using Fixya
Proton
Sep 07, 2010 | Yamaha Royal Star XVZ 1300 A Motorcycles
Kenwood KVT 514 in dash radio. Ipod classic is connected through the usb cable. Ipod is playing and showing onscreen progress, however, there is no audio coming out of speakers. Have been unable to make...
you need to purchase the ipod cable... your ipod is connected through the usb cable which does not provide sound to the unit but everything else works
Aug 15, 2010 | Kenwood KVT-514 Car DVD Player
Play Ipod thru JVC CD car stereo using RCA cable?
JVC KD-S731R does not have the option of connecting an ipod. The RCA ports on the rear of the unit are a Line-Out. These RCA's only OUTPUT sound. Not an INPUT RCA that you require. The only other method of using an ipod with this stereo is to purchase an FM-Modulator to connect the ipod. Once purchased, you must connect the antenna wire coming from the vehicle to the module, then you must connect the antenna wire coming from the module to the stereo. The other wire will be connected to either a jack or a ipod specific plug depending on the type of modulator used.
Dec 08, 2009 | JVC Car Audio & Video
How do i connect my itouch to kenwood kvt-512???
Hi there! You need a Kenwood KCA-iP300V iPOD VIDEO DIRECT CABLE.
Feb 09, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood ddx8017 stereo
NEED MORE INFO DO YOU HAVE AN IPOD CABLE ATTACHED OR A SATELLITE RADIO ATTACHED HAVE SEEN THIS PROBLEM WHEN CABLES FOR THESE OTHER COMPONENTS ARE THERE BUT NOT THE DEVICE ITSELF. LET ME KNOW WHAT ALL IS ATTACHED.
Mar 07, 2008 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Kenwood DDX7029 Car DVD Player Logo
60 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
