Question about Zebra P330i Thermal Card Printer
P430i - Ribbon Broken / Out of Ribbon error
Hi, I have a Zebra P430i, whic will print the test card fine. However, when printing a windows test page, it will display Downloading Data, followed by "Ribbon broken" or "out of Ribbon".
  • ildarkis Mar 27, 2009
    Same problem on Zebra P330i, I think that some optrons are not functioning but do not know how fix this problem.
  • sam07_09 May 14, 2009
    hi,
    with my zebra P430i
    anytime i want to print it displays OUT OF RIBBON
    help me please
Ribbon cut again and again after put 2 or 3 cards pls give instruction how to solve the problem.
Posted on Apr 27, 2011
  • 20 Answers
Your printer might not be properly communicating with the computer, please re-install your printer driver to the latest version. The printers ribbon settings are not communicating with your computer. Go to the ribbon properties and verify that the printer has the correct ribbon setting. If the setting displays "unknown ribbon" that means the printer is not properly communicating with the computer. Reinstall the latest driver for the printer.
-- The Pros at www.DiscountIDStore.com
Posted on Feb 10, 2012
Why does zebra p430i blinks when power on
Here's the Service Manual ftp://ftp.abico.com/Zebra%20Printer/P430i/P430i_Service_Manual.pdf Section 1.2.1 Pages 4 and 5 show numerous meaning for a blinking LCD Panel
Jun 19, 2014 | Zebra P430i Plastic ID Card Printer - P/N...
How do one resolve and out of ribbon error, when there is a a ribbon present. I'm getting this error on a P430i zebra printer.
The P430 and the P330 are similar, P430 print both sides from the card, and the P330 just print one site, but the commands to send are the sane. Please try !SA command from the driver.
Sep 22, 2010 | Zebra P330i Thermal Card Printer
We have a zebra p430i printer and we have it set to rotate the card but when it does it stops about half way how do I fix this
Try cleaning kit first. If problem is same you need to calibrate sensor voltage. That can be adjusted by trained zebra technition.
Sep 01, 2010 | Zebra P430i - Color Dye Sublimation /...
Zebra printer P430i. wait for temperature check
Try reducing your printhead intensity settings at the printer driver settings.
-- The Pros at DiscountIDStore.com
Aug 12, 2009 | Zebra Printer 140-751-00000
Zebra p330i just says downloading data
The reason in incorrectly established drivers, or in the printer. Better certainly to give to repair.
http://conditioner2009.bravehost.com/
Aug 08, 2009 | Zebra Eltron P310 Thermal Printer
Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Feb 17, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
Broken ribbon message for my zebra card printer
It could mean that the ribbon sensor on the printer is broken. Sounds like you need to send back to zebra for repair. This is free if printer is still under warranty. check out zebra's website for info on how to return printers for service.
Sep 11, 2008 | Zebra Eltron P330i Card Printer
Zebra P330i Thermal Card Printer Logo
4,270 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
