We here that there is diognostic card for motherboards
We here that there is diognostic card for identifying the problem and show the problem on th screen its an imax compny card. is it exist or not. just it is a card to test the problem of computer motherboards i expect early reply from u
    Master:
  • 404 Answers
Yes but it only tests the processor. it gives you a code and you read the manual what that code means. i have 3 never worked for me.
Posted on Mar 03, 2009
Peugeot 306 52 plate,pulled out the garrage one morning all perfect,left for 30mins tried to start to go to work turns over but wouldn't start,tried everything even diognostic machine of mine and the
Did you check for fuel pressure with a gauge on motor
or scan tool, if that data is avail?
Did you put one of those HEI Spark Plug testers in a plug wire
or cop coil
Do the cams turn
I'm not into the Peugeot, but is expect you may have a timing
belt ?
You may not have data on the ignition switch & its contacts
Do you have battery voltage to the ignition & injectors with key on
Injector pulse when cranking ( crank sensor !!)
Jul 26, 2013 | Cars & Trucks
Th-g31j
Please describe your problem briefly.So that i can identify it and then i can solve it.
Feb 07, 2012 | Computers & Internet
I have a problem with sound on m3a-h/hdmi motherboard with XP Pro. There is sound, every thing else is working ok, volume icon doesn't show, Sound and Audio Devices Properties window in Control Panel is...
Try visiting manufecturer's website and download the drivers of sound card from downloads or support section. You can also find the drivers from http://www.opendrivers.com if you exectly know th model number of your sound card. IInstall the drivers and your problem may be solved. (ehteshamhusain@gmail.com)
Jul 10, 2009 | Computers & Internet
Ati radeon 1650pro + asus P4V8X-X no match
first have you on board graphic card?
second what kind of sound is comming out (did you mean system is started but you can not see it or only is caming some beeps from MB)
if no graphic card onboard, try to identify is startin your system or not if yes you have problem with monitor , if no change your vga and take other one because is blowed or defective.
Apr 08, 2009 | ASUS P4V8X-X Motherboard
Can you have to much Ram for a processor?
You'll be fine. If you have been on crucial you know then whether the modules need to be in matched pairs, which is what it looks like you are doing. The only limitations on RAM are when you go to 4GB using 32-bit processing. It will most likely not all show. But with 2.5GB, you should be humming along quite nicely.
Jan 13, 2009 | Gateway Computers & Internet
How i can identify my motherboard version
dear sir
do the following to know ur motherboard
start> run >
please type DXDIAG >enter >
it will ask YES & NO
please press on YES
automatically one program will start named as DirectXDiagnostic Tool
it will show ur entire system information
regards
murali
Dec 10, 2008 | Microsoft Windows XP Professional With...
Sound not coming
You will find the correct drivers by browsing to Compaq's home page and submitting the model number of your Compaq
Nov 29, 2008 | Compaq Audio card Sound Card
My desk top hv no sound
ur motherboard has a disk containing the drivers needed for components like the vga card.. sound card (if integrated onto the motherboard), local area network (LAN) etc..to work.. this disk probably came along with ur computer.. unfortunately.. when you formatted th hard drive and reinstalled windows u got rid of all these drivers and they must be re-installed in order for these components to work..
if there is no disk present you can download drivers straight from the manufacturers website by typing in th make and model name of the sound card..or of the motherboard if p.c has a soundcard integrated onto the motherboard) into the address bar (the bar at the top normally..this begins with http://) you can find these details by going to start > all progs > system tools > system information > components > sound.. this will display the name and model etc of th card.. once on the manufacturers website there is usually a link for downloads to follow..
alternatively go to start > control panel > system > hardware > open "device manager" > once open look in the list for any yellow explanation marks anywhere..right click on any item showing this and delete..then restart the pc.. once it has restarted th pc will automatically detect new hardware and look for drivers.. often the best move now would be to rollback the drivers when given the option but this wont work after a disk format because th format clears th hard drive of everything..including updates and drivers so.. if you DO have a disk supplied with your pc carrying the required drivers (most new pc's will have this supplied with several other disks required to install software or applications...... this is far the easiest method of installing drivers
Nov 23, 2008 | Trust Ever 32bit 4-Channel PCI Sound Card...
IDE solt promblem
i have mercury board (pvm890m) but i can't play sound in vista o/s system plz help me out. thanks vivek
Aug 18, 2008 | Mercury P4VM800M7 Motherboard
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
