Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
FOR COMPATIBILITY MOTHERBOARD TO PROCESSOR - ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
    Sergeant:
  • 190 Answers
5 Suggested Answers
NetSalem
  • 55 Answers
SOURCE: How do I know if my motherboard is compatible with my processors voltage? where do i see the voltage indication of the motherboard?
Your board supports P4 CPU with 400Mhz bus speed. You can use any P4 CPU with 400MHz such as 2.4GHz/512/400. I think you can go as high as 2.8GHz.
Good Luck!
Posted on Jun 08, 2008
Chinthakaj
  • 416 Answers
SOURCE: MOTHERBOARDS Compatibility with this processor model.
the model you have given is not the correct model Number. Please check the link below & see where it says " E2160" this is the model number for the Intel CPU. please chk on your CPU & let me know the model you have. also most intel motherboards will support most of the CPU's. anyhow if you can give me the CPU model i can recommend some intel motherboards.
Posted on May 26, 2009
Tualiapz
  • 80 Answers
SOURCE: i have intel 845gvsr motherboard so iwant to buy a new intel processor which is compatible
Although not quite what you need, but you can find a comprehensive list of the type of processors that your board support from the link below:
http://support.intel.com/support/motherboards/desktop/d845gvsr/sb/CS-026968.htm
Some further recommendations, the board is pretty old as it seems to fit Pentium 4 chips only. You may want to look at buying boards which suits a dual core at least.
Posted on May 29, 2009
roety
  • 585 Answers
SOURCE: what processor is compatible to m741lmrt
Supports Pentium III 450~500MHz ,Pentium II 233~450MHz and Celeron 266~433MHz CPUs with frequency at 66/75/83/100MHz in Slot 1/Socket 370 for MicroATX Form Factor
Posted on Aug 12, 2009
What is the processors that can be compatible for Intel motherboard
Confirm your motherboard's compatibility with the Intel CPU you want to install. Motherboards typically only support one type of CPU slot, so purchase an Intel processor that is compatible with that slot.
Ensuring your processor and motherboard are compatible is vital when choosing parts to build your own computer system. If they are both the same socket type, they will most likely work together.
Brands
There are a plethora of motherboard manufacturers, but only two main processor manufacturers: AMD and Intel.
Every motherboard, regardless of manufacturer, has a socket that will accept a processor.
Intel
Common Intel socket types include LGA775, LGA1156 and LGA1366. Older models include PGA370, PGA423 and Socket 479.
Your motherboard and processor will be generally compatible if their socket types match. ...
Intel Core 2 Quad Q9650 Processor Compatible Motherboards
Hope this will help you and please don't forget to rate me. Thanks for using FixYa
Aug 02, 2011 | Intel Motherboard
Compatible processor
Here are the compatible processor for this motherboard.
Compatible Processors Intel Pentium 4, Intel Celeron D, Intel Pentium D, Intel Core2 Duo, Intel Core2 Extreme
Dec 03, 2010 | ASUS P5L-VM 1394 Motherboard
What kind of cpu do i need ? i have asus p5nd2-sli motherboard with no cpu in it
Compatible Processors Pentium 4, Celeron D, Pentium Extreme Edition, Pentium D 64-bit Processors Compatibility Yes Processor Socket LGA775 Socket
Seems that you need Socket LGA775,and CPU: Pentium 4, CeleronD, Pentium D, Pentium Extreme Edition. For more Details go here:
http://www.google.com/products/catalog?hl=en&q=p5nd2-sli+motherboard&cid=13414569805758042878&os=tech-specs
Nov 16, 2010 | ASUS P5ND2-SLI Deluxe Motherboard
Is e intel core 2 duo e6550 compatible with 945g-m3
Yes this motherboard is compatible with the Intel Core 2 Duo E6550 processor since the maximum processor support of this motherboard is core 2 duo LGA775 Socket so everything should be fine between these motherboard and processor.
Oct 02, 2010 | EliteGroup 945G-M3 Motherboard
Compatible upgrade processor for intel pentium
The E5200 would be a nice upgrade. It retails on Newegg.com for 65-69.00 and usually has free shipping. And if you have a compatible motherboard and purchase a nice heatsink, it overclocks very nicely.
Aug 07, 2009 | Intel Pentium Dual Core E2140 / 1.6 GHz...
Is assus p4s533 campatible with a 3.2 GHz processer with 800 MHz FSB?
No it is only compatable 533 mhz front side bus processors not 800 mhz sorry fastest processor has to be 5333mhz fsb
Aug 02, 2009 | ASUS P4S533 Motherboard
Compatible processor 3.0 HT with 845gvsr board
if the processor you have is a pin type one or rather socket 478, yes it will be o.k
Jan 21, 2009 | Intel Motherboard
Good Luck!
Jun 08, 2008 | EliteGroup P4VMM2 Motherboard
Yes, if you overclock you computer, I believe if you enter your bios of the motherboard, asus already has a pre overclock options. That is if your using a p4 2.8 ghz processor. You can not put a 3ghz processor and overclock it to a higher fsb, your motherboard will literally smoke up but, most motherboards probably can easily detect a non compatible CPU.
Sep 16, 2007 | ASUS P4GE-MX Motherboard
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
