Question about HP Computers & Internet
Hp/compaq nx7010
Hello guys i need help. i have an hp/compaq nx7010 HDD crash i boughtnew HDD/xp pro with sp2 in the process of installations at the 34minsmark the laptop reboot it self over and over again. please help..thankyou
  • sing50177 Mar 04, 2009
    I have 4 rams 256MB each. i tried all, all in different slots. i be able to get my hp recovery cd to work but now in the windows mode rite after everything completely loaded it reboot again. CPU fans is spinning just fine, heat sink is clean.
    President:
  • 1,223 Answers
Pls check ur RAM it seems like ur RAM is giving u problems pls consider changing it with different one or try if u have 2 chips installed try each one individually and see if helps otherwise if it happened on 34 min mark specifically during the installation then it is more like software issue try replacing the installation cd and see
Posted on Mar 03, 2009
Can i replace the hdd of my compaq nx7010 with an ssd drive
Yes. as long as the interface of HDD matched with mainboard of laptop interface. compaq nx7010 use SATA interface so you should use SSD drive with SATA interface . :)
Oct 03, 2012 | HP Compaq Business nx7010 Notebook
Hello! I recently did a clean install of my Compaq NX 7010 notebook as I am planning on selling it. I have the original install discs of XP Pro, then I downloaded SP2 as that was what I had running on...
old laptop , is HP compaq now, there is no COMPAQ now.
XP is 3 years, dead OS ,and a virus magnet.
that BSOD? is bad memory in most cases but XP loves to do it.
i have org install disc from
  1. Microsoft
  2. HP
  3. or Compac long ago..
this lap to is so old most have been scrapped now.
why not get a newer one from GOODWILL, this one they would not touch its so old (savvy them no?)_
why not get a 10 year or less LT. which can run Win7
at least
then it has value,
yours is like $20 as parts on EBAY, scrap.
who'd buy a XP relic lap top, only the desperate is my guess.
Its like buying an old YUGO car, (ouch)
so why put cash money in a box that has no value. why?
what if memory is bad,or HDD or CDRom.
are you going to buy parts for that? really?
XP need SP3 or is useless forget SP2,
MS does not support XP
HP does not support over 10 year hardware.
so, why mess with things not supported>?
I do but I have expensive APPS that only run in XP or vista
and have near new, LT very old that run that when needed,
like 1hr a year.
if not for that, id donate them to GOODWILL where they belong.
most old gear like this is sent to the 3rd world as a gift.
or scrapped.
ah I lied , 2005 support, at HP, 12 years old.
get them before they pull the drain on it
http://h20566.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=380680&swLangOid=8&swEnvOid=1098
for install disk only these work.
from HP, HP owns compaq for 16 long years.
media kits real matching only your LT. !!
http://support.hp.com/us-en/document/bph07143
Mar 29, 2017 | HP Compaq nx9020 Notebook
Windows XP crashes after about 2 minutes. New window XP installation crashes while installing devices with 34 minutes to go.
So do mine , I have narrowed it down to have something with the
GPU to wrong drivers beeing installed or setup for the AGP.
Its possible for example to Run Linux standalone , but not possible to install any OS whatsoever.
Jan 17, 2011 | HP Compaq nx7010 Notebook
Installing XP SP2 on Compaq Presario R4000, after
Run a HDD Test
Restart Computer -> Immediately keep tapping F10 Key which is on 1st row of Keyboard
Go to diagnostics with your arrow keys
Go to Primary HDD Test -> Press Enter ->
See the Test result
If Fail then Contact HP for Replacement of HDD or Service
Jun 01, 2010 | HP Compaq Presario R4000 Notebook
I unable to install Xp in my compaq cq61-132tu. The install option just doesn't get highlighted. Also, i don't have another computer.
I assume you are attempting a "downgrade" to Xp from Vista, since this laptop does not come with XP.
From the Compaq information page:
  1. HP does NOT support XP for consumer notebooks, so if you have any difficulties regarding XP, do not expect HP will help you.
  2. HP may demand you to install back VISTA if you have hardware problem to troubleshoot it.
    An option to consider-put your original Vista hdd away and install new one for XP.
  3. Some of the notebook features may not work in XP due to uncertified licenses pointed in this guide.
  4. Microsoft has released three (3) Service Packs for XP, use only SP2 for the first trial. Why? Since many of XP drivers are released based on XP-SP2.
  5. Always make Vista Recovery cd/dvd before downgrade to XP. see it here
  6. You have a folder with drivers & programs that may prove very helpful after XP downgrade.
    Copy folder C:\Swsetup to DVD Before formatting your hdd.
  7. If you have a pre-SP2 XP cd, get the full SP to Integrate with Nlite: SP2 Nlite HERE
The help guide for downgrading is here. There is a lot of information on this process written there.
However, if what you want is a an XP look and feel so you can compute the way you used to, change the Vista to look like XP in the display properties.
If you are trying to run non-Vista software, try running it in compatibility mode. To do this, right click on the program files and select properties and then locate compatibility..
Jan 04, 2010 | HP Presario CQ60-204NR PC Notebook
HP Pavilion laptop freezes daily and i force manual shutdown
It sound's like there could be a compatibility problem, maybe corrupt file's, or missing start up file's, have you tried doing a window's update, or doing a disc check on the hard drive, go to my computer right click the drive then go to propertie's, click on tool's then click check now for drive error's. if that do'es not work you may need to reformat back to the original xp os.
Apr 16, 2009 | HP Pavilion dv1000 Notebook
Hp/compaq nx7010 keep rebooting it self over and over again in the process of windows installation.
This may happend in two situations. 1 Whend OS is corrupted and 2nd is if the RAM problem. Just change the RAM to another slot and try to boot again or repair the OS if it is XP SP2
Mar 03, 2009 | HP Computers & Internet
Hp/compaq nx7010
bad CD installation, get a new clean CD
Mar 03, 2009 | HP Compaq nx7010 Notebook
Drivers not found.
Your Compaq came with Vista installed. Finding drivers for XP Pro with SP2 seem to be very troublesome. Somewhere HP Compaq has these drivers for you laptop. If you call them & they find out you bought XP Pro they will not support you in finding the proper drivers for XP Pro. How ever you can call & ask what it will cost for a recovery CD for XP Pro w/SP2.
Click the link to Compaq & listed is your laptop & what software & drivers are listed. If you need other drivers that are not listed, post what you want I'll try & find them for you. Please be as detailed as possible.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=3641194&lang=en
You may find some here.
http://search.hp.com/query.html?sh=1&charset=UTF-8&la=en&qt=drivers%20for%20XP%20A902TU%20Notebook
Feb 19, 2008 | Computers & Internet
Computers & Internet Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
