Question about Microsoft Computers & Internet
MySQL database backup Create backup at remote m/c Prepare a scheduler to perform this task every Saturday at mid-night.
    Champion:
  • Microsoft Expert
  • 401 Answers
Backup and restore mysql data you may perform owing to http://www.mysql.repairtoolbox.com application starts under Win 98 and higher
Posted on Jun 22, 2012
  • 8 Answers
SOURCE: Rename a mysql database with phpmyadmin
Yes. In the SQL tab,
RENAME DATABASE test TO new_test ;
Posted on Nov 26, 2008
SOURCE: mysql database tables+find new inserted or update row using java
After you add the new record into table A, you can use the LAST_INSERT_ID() function to retrieve the value of the auto_increment PK field. Look here for more information on this function: http://dev.mysql.com/doc/refman/5.0/en/information-functions.html
Posted on Mar 02, 2009
frcs68
  • 1605 Answers
SOURCE: Windows 2003 Server Task Scheduler Exit Code (1)
the exit code of 1 or 0x1: Incorrect function called or unknown function called.
check your backupRBase.cmd file. one of the URL or function need to be modify.
Posted on Mar 04, 2009
leecom72
  • 4806 Answers
SOURCE: unable to create a system restore point
Hi there.
There a few alternatives for you you do, lets try the best known one,
Click on the start menu (orb), then click on all programs, from the list click on accessories and then click on system tools and in that list you will see system restore, click on that and you should be able to create a restore point from that window.
Good luck and thanks for choosing FixYa!!
Posted on May 30, 2009
  • 10406 Answers
SOURCE: unable to create system restore point
GOOGLE found:
Run services.msc and make sure Volume Shadow Copy is stopped. Then locate and delete any System Volume Information folders on the root of any volume that was previously being monitored by System Restore. You may need to alter
Folder Options/View tab/Advanced in order to see these protected system folders. Reboot the system and retry turning it back on.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
Posted on May 31, 2009
How can I restore my SQL database from .frm files?
You just copy the .frm files to the to the databse folder but you also need to copy the ib_logfiles and ibdata file into your data folder. I have just copy the .frm files and copy those files and just restart the server and my database is restored.
Best Professional Resume Writing Service Online from Washington USA...
Oct 22, 2015 | Oracle MySQL Enterprise Ed 1-4 Socket...
How to restore MySQL database Windows tool?
You can restore corrupt and delete SQL database file in few steps for MySQL Restore Toolbox. With this software you can also recover triggers, keys, indexes and table. Software support multiple MDF file recovery option. Software is supported by all Windows operating system. Get more ideas and download free trial version from -http://www.filerepairforum.com/forum/databases/databases-aa/mysql/1162-dump-mysql-database-file-is-error
May 29, 2015 | Sun MySQL
How to fix mysql error 1046?
For the database import, before you attempt to import the "flat" file data in, you need go to your local DB (MySQL) and create new database
After that you can import!
Also check this links:
http://www.repairtoolforsql.fixtoolbox.com/ Fix Toolbox for MySQL
http://www.sqlservercentral.com/Forums/Topic1618894-2893-1.aspx
Apr 09, 2015 | Quest Software Toad for MySQL
How to fix mySQL corrupt databases?
you should follow two steps:
Create an appropriately named database on the target machine
Load the file using the mysql command:
$ mysql -u [uname] -p[pass] [db_to_restore] < [backupfile.sql]
Have a look how you can restore your tut_backup.sql file to the Tutorials database.
$ mysql -u root -p Tutorials < tut_backup.sql
To restore compressed backup files you can do the following:
gunzip < [backupfile.sql.gz] ' mysql -u [uname] -p[pass] [dbname]
If you need to restore a database that already exists, you'll need to use mysqlimport
command. The syntax for mysqlimport is as follows:
mysqlimport -u [uname] -p[pass] [dbname] [backupfile.sql]
Or make use of Repair Toolbox for MySQL
Demo version is here-: http://www.sql.repairtoolbox.com/
Feb 08, 2015 | Microsoft SQL Server 2000 Standard Edition...
How to move one mysql database to another machine
After logging into MySQL via command prompt, use the below commands.
Backup :
databasename > dumpfile.sql
Restore :
source dumpfile.sql
If you have an IDE like HeidiSQL or SQL Yog, they can make tasks easier through visual interfaces.
Mar 12, 2013 | Computers & Internet
Can you give sample source code of visual foxpro program using mySql as database flatform
Create a connection: lcStringCnxRemoto = "DRIVER={MySQL ODBC 3.51 Driver};" + ; "SERVER=200.1.1.1;" + ; "PORT=3333;" + ; "UID=booking;" + ; "PWD=booking;" + ; "DATABASE=booking;" + ; "OPTIONS=131329;" lcStringCnxLocal = "DRIVER={MySQL ODBC 3.51 Driver};" + ; "SERVER=localhost;" + ; "UID=root;" + ; "PWD=clave;" + ; "DATABASE=booking;" + ; "OPTIONS=131329;" SQLSETPROP(0,"DispLogin" , 3 ) lnHandle = SQLSTRINGCONNECT(lcStringCnxLocal)
Accesing data:
SQLSETPROP(0,"DispLogin" , 3 ) lnHandle = SQLSTRINGCONNECT(lcStringCnxLocal) IF lnHandle > 0 cmd = SQLEXEC(lnHandle,"select QuantityRooms from roomtype","cur_roomtype") IF cmd > 0 BROWSE ELSE AERROR(laErr) MESSAGEBOX("Can't connect to mySQL. Error: " + CHR(13) + laErr[2]) ENDIF USE IN cur_roomtype SQLDISCONNECT(lnHandle) ELSE AERROR(laErr) MESSAGEBOX("Can't connect to mySQL. Error: " + CHR(13) + laErr[2])
ENDIF
Creating complex sentences:
TEXT TO lcSQLcommand NOSHOW SELECT Inventory.inventoryid, Inventory.date, Inventory.roomtypeid, Inventory.sold, Roomtype.descrip, Roomtype.rooms FROM inventory Inventory INNER JOIN roomtype Roomtype ON Inventory.roomtypeid = Roomtype.roomTypeID ORDER BY Inventory.date DESC ENDTEXT cmd = SQLEXEC(lnHandle,lcSQLcommand)
Passing parameters to a query:
nValor = 12 cmd = SQLEXEC(lnHandle,"select QuantityRooms from roomtype where roomtypeid = ?nValor","cur_roomtype")
Calling a Stored Procedure:
SQLEXEC(lnHandle, "call myStoreProcedure(@param1)")
GOOD LUCK!
Mar 17, 2011 | Microsoft Visual FoxPro Professional...
Choices available to create database of c++ program
You should use the MySQL database as it is free to use and has great functionalities.
go to the belo link to get details about creating database and using in ur c++ code.
http://c-programming.suite101.com/article.cfm/using_a_mysql_databases_with_c
Thanks!
Mar 31, 2009 | Computers & Internet
MySQL Database
THE SYSTEM REQUIRMENTS ARE
MySQL Tools
1. A SQL server : This is an engine which provides access to your databases.
2. Client programs for accessing the server : A program allows you to enter queries directly and view results
3. A client library for writing your own programs : You can write your own programs into the client library using C.
Recommended Hardware Requirements For Mysql Installation
  1. Pentium V processor
  2. 128 MB RAM
Note that MySQL can be installed on a platform with as little as 32 MB
RECOMENDED SOFTWARE TOOLS for better performance
IT is recommended to have at least 128MB memory.
You can freely download MySQL from the website http://www.mysql.com MySQL runs on many varieties of UNIX, as well as on other non-UNIX systems, such as Windows and OS/2. MySQL runs on hardware from home PCs to high-end server. MySQL can be installed on Windows XP, Windows Server 2003, Red Hat Fedora Linux, Debian Linux, and others
Sep 08, 2008 | Sun MySQL
Automatic database backup
These instructions are for Microsoft SQL Server Standard.
Go into the Enterprise manager.
Select your server on the tree view on the left. Go all the way down to "Management" and click on "Backup".
This will allow you to set up the backup.
Check the box called "Schedule". This will allow you to select a schedule for automatically performing the backup.
Good Luck.
Oct 18, 2007 | Microsoft SQL Server Standard Edition for...
Open Questions:
What is Microsoft office applications? Microsoft office is a set of interrelated desktop applications, servers, and services, collectively referred to as an office suite, for Microsoft Word: a word processor included in Microsoft Office and some editions of the now-discontinued Microsoft Works Microsoft Windows and macOS operating systems. Microsoft Excel: a spreadsheet. Microsoft released the first version of Excel for the Mac OS in 1985, and the first Windows version (numbered 2.05 to line up with the Mac) in November 1987. Microsoft PowerPoint: a presentation program used to create slideshows composed of text, graphics, and other objects, which can be displayed on-screen and shown by the presenter or printed out on slides. Microsoft Access: a database management system for Windows that combines the relational Microsoft Jet Database Engine with a graphical user interface and software development tools. Microsoft Access stores data in its own format based on the Access Jet Database Engine. Microsoft Outlook: a personal information manager that replaces Windows starting in Office 97, it includes an e-mail client, calendar, task manager and address book. Microsoft OneNote: a notetaking program that gathers handwritten or typed notes, drawings, and audio commentaries. Notes can be shared with other OneNote users over the Internet or a network. Microsoft Publisher: a desktop publishing app for Windows mostly used for designing brochures, labels, calendars, greeting cards, business cards, newsletters, website, and postcards. Microsoft Project: a project management app for Windows to keep track of events and to create network charts and Gantt charts, not bundled in any Office suite. Microsoft Visio: a diagram and flowcharting app for Windows not bundled in any Office suite
Dec 28, 2017 | Microsoft Computers & Internet
Computers & Internet Logo
91 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
