Question about Kodak i260 Duplex Color Scanner
Check kds.log -this is my massage error when i press scan option at canner kodak i 260
My scanner i260 do not scan properly, it present a distortion in the image, Could you help me?
Thanks a lot
Posted on Oct 18, 2010
  • careduc May 23, 2011
    Hi, I have the same problem with my scanner, you could find a solution?
Hello ,i have a problem while connecting my kodak scanner i780 ,there is a message<<unable to start scanner,please read the kds.log for more information>> so plz help me so
Did you use the installation software CD-rom before running it on your new computer? Most scanners comes with an installation CD that you have to install before using it. You may also have to restart your computer before using it after the installation. Good luck.
Nov 06, 2014 | Kodak Scanners Kodak I600/I700/I800 Series...
Comand faild check the log error comes while scanning In I2400 scanner
Try updating your drivers from Kodak.com. Do not uninstall your current drivers, install the newer version on top of your existing install. Ensure you download the drivers and smart touch.
Jun 03, 2014 | Kodak I2400 Scanner
"cycle error" - scanner powers up ok but will not scan due to this error ID=055
Error 55: "Lamp I2C error reading from DAC". Operator log message: "Cycle power, if problem persists, call service.". This error is involves communication errors between the LED AY and the DAC. A couple things can be done to alleviate this issue but unfortunately, as a user, you can only perform the first step. The other steps require a Kodak Field Engineer to complete. First step, upgrade your Firmware. Firmware updates can be found at the following web page: http://graphics.kodak.com/DocImaging/US/en/Support_Center/Document_Scanners/Production/i5200_Scanner/Support/Drivers_And_Downloads/i5000_Series_Scanner_Firmware/index.htm. If you still experience issues following the firmware upgrade, call Kodak Service & Support to schedule a field engineer to be dispatched to your site.
Mar 03, 2014 | Kodak i5200 Document Scanner
Cannot save scans (HP F2180 on Windows XP)
This happened to me (on XP) when I wasn't logged in as an administrator.
Logging in as an administrator should solve the problem.
Peace, Robert.
Apr 27, 2009 | HP Office Equipment & Supplies
Check kds.log -this is my massage error when i press scan option at canner kodak i 260 "check KDS log" messge error appears when scan option chosen on i40 Kodak Scanner.
Try Calibration routine. If it fails check optics are clean and not scratched. If it still fails change the lamps.The KDS.log is encrypted and can only be accessed via a license key. This is only Available to Kodak reps or through RTS ltd service calls.
WWW.Responsets.co.uk.
Mar 25, 2009 | Kodak i40 Path-Through Scanner
Tdd: 89
This sounds like a sensor issue, try cleaning the sensors, DO NOT use compressed air. Also try recalibrating the scanner. If all fails it may be a bad sensor, call kodak 800-822-1414 and they should be able to assist you.
Feb 25, 2009 | Kodak i260 Duplex Color Scanner
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
I280 won't scan!
ImageCalibration means the cameras don't get enough light during their self test.
Please check the following points:
Are both lamps on or one lamp in case you have a single page scanner?
Are the imaging guides (the clear sheets above the cameras) clean?
Are the little white tags on the imaging guides present?
One tag on each imaging guide.
Without this small white tags the cameras are not able to check themself.
For emergency you can apply a small white paper or white insulating tape instead of missing tags to test the scanner.
If the lamps are light, both tags are present please calibrate the scanner with the kodak calibration sheets. You will find the calibration menue in the scanner validation tool. You can get this tool from the Kodak home page.
Jul 15, 2008 | Kodak i 280 Path-Through Scanner
900 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
