Installing WIN XP SP2 in aToshiba Satellite A205-S7459 Vista original
Hi!
Just puchased a brand new Satellite A205-S7459 with a pre-installed Win Vista Home Premium. But I use some development tools (I'm a hardware engineer) that come to be incompatible with Windows Vista (after installed, the application probably conficted with the WI-FI and CD drive drivers in such a way that I had to use the recover disk to get the machine operational again).
So I decided to go back to the old and good (almost) XP SP2.
But the XP installer simply does not recognize the SATA hardware, insists that the PC has no HD to install Windows in.
Thanks a lot for any help. how to install in vista os in toshiba satellite a205-s7459 laptop
  • amtaz Mar 30, 2009
    where to download sata driver for this model of toshiba A205-S7459
    President:
  • 1,223 Answers
Problem : When Windows XP was made there was no concept of SATA drives now ur drive is SATA and ur installation disc does not contain drivers for ur Hard disk thats why it is unable to find ur hard disk as it doesnt recognize it u need sata raid drivers on ur windows inst cd
simple solution: get WINDOWS XP CD with SP3 it contains support for sata drives
Workable Solution:
this specific model of Toshiba was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from www.intel.com and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from www.intel.com select ur board and chipset either it is 945 or 965 gm and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
SATA DRIVER FROM:
http://downloadcenter.intel.com/license_agr.aspx?url=/17268/eng/iata87enu.exe&ProductID=2800&agr=Y&sType=&PrdMap=&DwnldId=17268&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
http://www.nliteos.com/
just download sata drivers from intel and nlite from the link and install the software integrate these drivers and burn ur cd incl them and then install normally as u were installing them earlier now it will recognize ur drive simple for more info how to do check this out
http://www.zimbio.com/Laptop+Reviews/articles/10840/How+Integrate+Floppy+SATA+RAID+Driver+Windows
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
after windows XP installation u will have one more task to find drivers for ur notebooks with XP support but it is the next step if ur some hardware like modem / sound/ doesnt work then i can help more
pls let me know if i can help u more
and rate me FIXYA if i have fixed ur problem
Posted on Mar 03, 2009
My audio device is not working. so i want to sound driver for it.
You can download all the drivers you need for Lenovo 3000 Y410 Laptop from the below link
http://www-307.ibm.com/pc/support/site.wss/MIGR-68104.html#audio
Just scroll down the page for Audio drivers for both win XP and Vista,click on the blue version number to download the one you want.
Note : Incase you have win XP,some people has issues installing the xp driver with sp3 installed,the driver seems to work with only sp1 and sp2.So if u have SP3 and unable to install xp driver, do one of the following.
1) Uninstall SP3 and install SP2 and then try installing the driver for XP
2) Download Vista driver and install it with windows compatibility mode set to XP SP2.
Nov 30, 2010 | Lenovo 3000 Y410 Laptop
Software upgrade
Hi!
Well, win xp is absolutly more fun as OS then win 2000:)
To upgrade to win xp will be no problem since Toshiba have drivers for ir. To upgrade to VISTA will...or can give you problem since there arent any drivers for that Tecra S1.
If u deside to upgrade to win xp, here is all the drivers u gona need to do it:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=380605&rpn=PT831U&modelFilter=S1&selCategory=3&selFamily=1073768664&selModel=380605%7CPT831U
Good luck
Dont forget to RATE me
Nic
Mar 12, 2009 | Toshiba Tecra S1 Notebook
Displays no hard drive found wen installing win xp
You have to go to BIOS setup, find HDD setup, and change the value to the other one (there are only two possibilities). That will fix your problem. The problem is caused by the fact that the lap top was designed for vista, not XP. and the lap top contains SATA HDD. when installing XP pre-installation doesn't have SATA drivers, so your OS can not see the HDD. Change it in BIOS, and you trouble is gone
Nov 14, 2009 | Toshiba Satellite A200-19501F Notebook
Have deleted vista off toshiba satelite s2276, deleted all partitions, repartitioned to single large drive, formatted, booted from floppy, win 98 se setup started and working until installing drivers then...
If your system came with Vista pre-installed it is likely there are no XP or eariler drivers available for it, in which case you will have to stick with Vista or Windows 7.
Oct 28, 2009 | Microsoft Windows XP Home Edition
How to install vista intoshiba satellite a205
If you have the Vista CD you can install by booting from installation CD. For drivers visit toshiba website.
Thanks
Mar 03, 2009 | HP Pavilion dv6000z Notebook
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Toshiba satellite A205-S4707 MODEL psaf0u
if ur WIN XP is Service Pack 3 then u will not have much problems in installing drivers it will come pre loaded but if not there is a solution , u can first make a list of component manufacturers like Board is from intel u will get the drivers any ways from Intel no prob
Sound = ?
VGA= ? is it intel or ATI or NVIDIA u will get it fromthe wesite dont worry just right down the model of ur vga
Modem = ?
LAN=
WIFI = normally intel dont worry u will get it from intel
if ur win xp doesnt come up with pre loaded drivers just install it and then download drivers from the brand names website
one more thing if u are going back from VISTA to XP u will find it sometimes difficult if u dont have WIN XP loaded with SP3 cd so if it does not recognize ur hard drive during inst and says that no drives found dont worry just check out the solution on this link below
Dec 16, 2008 | Toshiba Satellite A205-S4707 Notebook
Download win xp
sorry u can't download windows XP u should purchase it and remove vista and install windows XP after installing u should download drivers for the dell laptop Inspiron 1525 of windows XP because vista is pre installed operating system including with drivers
Jul 29, 2008 | Microsoft Windows XP Professional With...
you need to go at www.Toshiba.com and get a special driver. You need to check under support and drivers for your model.
What you do is you get the driver (depends if you a floppy otherwise burn the drive on a cd)
From Bios make the computer boot the computer from CD/DVD rom and then you need to pay attention when on the bottom of the screen it will say hit f6 if you have to install the special driver and then you can continue installation of windows.
I
Feb 01, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
996 people viewed this question
David Payne
David Payne
