Question about Panasonic SA-HE100 Receiver
Panasonic SA-H175 When the DSP is defeated  the Tuner picks up signal and amps it OK but outputs to only one speaker (both speakers are OK). Nothing else works! When the DSP defeat is turned off, ie., DSP is on, nothing works, and  the machine quickly  displays "F70" and says turn off power. I opened it up, lifted out and tested the five fuses (three 8 amp, one 4 amp and one 1.6 amp) with a continuity tester. All OK.  Any suggestions?  Thanks in advance
SOURCE: Panasonic SA-HE100 5.1 system error code F70
I was able to fix this problem by replacing a fuse. Remove the cover (7 screws). Directly behind the fan are 2 boards with 5 fuses on them. The boards are 1 over the other. The fuse I replaced was labeled F5 and on the top board with the fuse facing down on the underside of the board.
Posted on Jun 23, 2008
tvservice306
  • 458 Answers
SOURCE: My Panasonic sa-he200 unit is giving me an
if unit in warranty send to service
http://www.pstc.panasonic.com/WhereTo/FindServicer.asp?ValidJS=1&Pass=1
Posted on Nov 11, 2009
SOURCE: Intermittent F70 Error
I now also have this problem. I don't fully understand the instructions given above, can someone please give more detail?
Posted on Dec 11, 2009
SOURCE: Panasonic SA-HE9 amp / Sky+ optical
i Have a Panasonic SA-HE9 and i cant get the optical cable too work on my Playstation 3 to get sound from there. can any 1 help me with this?????
Posted on Dec 30, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have an older Panasonic
What does the TV really need from the receiver in all of this? Minimally, Component video for the DVD and managing the SA-HT920, not much else.
A TV is not normally an optimal source of audio.
Your broadcast TV-related sound would be higher quality and easier to obtain if you got it from the Cable or Sat box you probably have. Route ITS BEST (digital multichannel) audio directly to the SA and and its BEST (HI-DEF) VIDEO directly to the TV. You could also run vanilla analog audio to the TV so you can watch news in lo-fi audio on the TV.
The exact model of TV would be helpful to know as audio capabilities may vary.
Should you still feel the need to run TV-originated audio to the SA from the Viera through its headphone or audio output, connect that to any available analog RCA input.
Connection of a jack into the audio output will pass unmodified TV audio to the SA. That's a good thing as the REAL audio electronics needs an unmodifed source for best results.
Posted on Feb 13, 2011
Testimonial: "It worked, I went straight to the cable box from the surround sound system, unplugged the audio cable from the tv and I have my sound surround back! "
HOW CAN I CONECT THE BOSE TO MY YAMAHA AMP THE ONLY WAY TO CONECT THE BOSE IS TO BANANA INPUTS ON MY AMP AND THEY ARE FRONT SPEAKERS BUT THE AMP HAS A SUB OUTPUT
To enable the full potential of a SUB for Yamaha DSP A5 ,
you need to have
a separate amplifier for your Bose Acoustimass System.
The SUB out should be connected to an active subwoofer.
Sep 30, 2012 | Bose Acoustimass 3 Series IV - 2.1-channel...
I think my receiver just blew. hissing noise from all speakers, now i get no sound - but the display still works...help
unplug the receiver, Everything- speakers, input/outputs. The only cord to the device left should be the power cord.
Power up the receiver, set the tuner on a strong station. check sound quality with headphones only.
If that was ok, now pick one speaker to test all channels with. Follow the procedure above with the
speaker. check each output channel with the tuner as a source using the one speaker. Good Luck!
Sep 03, 2011 | Kenwood VR-8050 6.1 Channels Receiver
How to hook up external amp need to know how to run jacks to the amp and speakers which out put for amp to run the front speakers on a panasonic sa-he70
Manuals help.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SA-HE70K-Receivers-manual/id/312ag701/t/2/
Not knowing anything about your 'external' amp or how you want it to function the only thing you could do is feed it the analog stereo output of the SA-HE70 from one of its OUTs (Tape or VCR). It won't be volumed-controlled by the SA-HE70.
Jun 01, 2011 | Panasonic SA-HE70 Receiver
My tuner will not work! I've had this unit for 4 years & it's always worked perfectly. Then yesterday, the tuner stopped working. "Tuning" flashes on-screen intermittently & no...
1. Verify the source of the signal - Look for any antennas that may have been hooked up, and verify connection has not been moved or removed.
2. Test with a different output by plugging in some headphones, and recheck the volume through the headphones.
3. Check that the A/B switch for the speakers has not been moved, and that they are switched to the correct speakers.
4. Try AM and FM for any signals both with speakers and then headphones.
Bruce
May 05, 2011 | Audio Players & Recorders
Theres no sound coming through the speaker ports .
At first consideration, the question appears a little vague. Any sound amplifier other than a simple two channel stereo system requires the appropriate driver signal(5.1, 6.1 et al ) in order to output sound to all speaker ports. If a stereo signal is fed in you will not get 5.1 or 6.1 or any other of the multiple speaker channel outputs from the speakers. The 5.1 or 6.1 etc. source signal must be provided on the medium you are playing or receiving for you to be able to hear it outputted on all speaker channels.
If on the other hand you mean that "There is no sound whatever coming through any of the speaker ports no matter what you play into the amp" then the whole thing would need to be checked from input to output by a Technician to determine at which point the source signal is being lost on its way through the entire circuitry.
In this case I would recommend you arrange for an fixed fee inspection which might include a minor repair up to that amount if that is what is found to be necessary.
Feb 27, 2011 | Yamaha DSP-A1 Receiver
OVERLOAD
First of all the KEF is a powered sub which means that it wants a line level signal NOT a speaker level. Send the signal from a tape output or pre-amp output to the sub input. The overload is because the impedence load for the speaker output is too low and looks like a short to the amp. Continued attempts to connect the system as described will result in damage to the output section of the amp.
Please let me know if you need more info.
Dan
Feb 03, 2010 | Technics SA-DX750 Receiver
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Panasonic av control receiver sa-he200
On any 5.1 system without 2 zone capabilities when you press speaker "B" the receiver uses the rear channel amplifiers to send signal to the remote speakers. As a result the receiver cannot output signal to both the rears and the remotes at the same time.
Feb 26, 2009 | Panasonic Audio Players & Recorders
Panasonic SA-HE100 Receiver Logo
137 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
